Question about Radio Communications
I have a JAM HXW 4901. HOw do I set up the paring mode? There is NO instruction manual, and all I can find are cutsey writeups on line for orhwr models. I am trying to pair it to an echo (Amazon)
  • 5 Answers
SOURCE: How do I pair my Jabra Bluetooth -48D
well what you have to do is to go to the bluetooth menu turn  it on and select add new device now on you jabra headset it has an answer button wich you can press untill the blue light stays on that when the env can find and paire the device
Posted on Nov 01, 2007
tat4u
  • 520 Answers
SOURCE: blue tooth device pairing code
open bluetooth and search for new device,when you find new device you can configure it so as no code is required and pair auto
Posted on Feb 22, 2008
SOURCE: paring
you simply pair two phones together. did it work? let me know.
Posted on May 14, 2008
  • 239 Answers
SOURCE: Pairing H700 with Blackberry
try these paswords
1234
0000
9999
9876
4321
6789
the correct one should be (0000)
if not try the others.
hope this helped.
please remember to rate me.
Posted on Mar 02, 2009
SOURCE: I am trying to pair Visor Blade,Supertooth-Lite with mobile phone
Try holding down the green button release the mike then enter 0000 the phone should then pair. This worked for me so I hope it will work for you.
Posted on May 21, 2009
My bluetooth jam classic wireless speaker has been working for a few days and now its showing this red light under the Bluetooth part. Can I fix it?
Unpair the same from your device. Reboot the device and the speaker. Put your speaker under paring mode and check if the same is showing up on your device. This should ideally help.
Dec 29, 2014 | Radio Communications
Can sync earpiece to base. Please help.
Here are the pairing instructions for your Plantronics Voyager 500A base:
On the base, press and hold both speak volume fine adjust buttons until the blue talk/on line indicator light and red power indicator light start to flash.
Now put the headset into paring mode that you will be using with the base.
Pairing is complete when the talk/on line indicator on base illuminates solidly.
Here is the link to the 500A user guide:
Plantronics Voyager 510S User's Guide
Good luck from Headsets Direct!
Jun 20, 2011 | Plantronics Voyager 500A Deskphone Adapter...
I got a GameOn bluetooth from asda but no instructions? can u help
Setting up the gameon Bluetooth headset is like configuring any other Bluetooth accessory with your game console.
Depending on the type of console you have you basically need to pair the device with your console.
In order to get the headset into paring mode you will need to hold down the button that turns it on for a longer period of time than is required to power it on. For example if you need to hold down the power button for 2 second for the headset to turn on you will now need to hold it down for 5 seconds or more for it to activate paring mode.
Once paring mode is active your game console should pick up the headset and ask you for a pass code in order to create a secure wireless connection between the game console and your headset.
The default passcode is 0000. This is the code you enter when the console asks you for the code.
Feb 28, 2011 | Video Game Consoles & Games
On Intermatic HB65R Timer, how do I set AM/PM or 24 Hour cycle ?
HB65 manual is not available.
Intermatic has pared-down it's timer line recently.
Some old manuals still show, but those are disappearing because timers don't last forever.
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers.aspx
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
HB61 manual:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/hb61rc%20-%20english.ashx
HB61 timer has a photo-cell switch and automatically turns ON at dusk, and then you set timer for how many hours it will operate before turning off.
Nov 23, 2010 | Hardware & Accessories
How do i connect the bluetooth to my ps3
You need to put both devices into "pairing mode" Follow the instructions in your manual on how to do this. When both are in paring mode your headset will detect your Ps3.
Apr 21, 2010 | Plantronics Explorer 220 Bluetooth Headset...
How do I connect my IPOD nano to my Motorola S9 HD Headsets
I downloaded the instructions manual for the Motorola S9 HD and implemented them. It worked fine!
Jun 19, 2009 | Motorola Mobility MOTOROKR S9 Wireless...
HELP....
Well my user manual for HBM-550 says:
Prior to using the Headset for the first time, you must pair it with a Bluetooth enabled handset.
With the HBM-550 off, press and hold the Pwr/End button for 5 seconds,
You will hear two short beeps and the LED indicator will flicker in red and blue alternately, when the divice enters Paring Mode.
Using your Handset, find the Bluetooth Menu and "search for" or "add" new devices.
Select "LG HBM-550" from the list of devices and pair it with your handset.
When asked for the pass/PIN code during the paring procedure, please enter "0000" (4zeros).
Once paring has completed successfully, you will hear a beep.
After paring successfully, be sure to "Connect" to the HBM-550.
If you want to pair with other devices in the future, the headset must be placed in pairing Mode.
If the HBM 550 is in "Paring Mode" for 3 minutes, without being paired to a device, the Headset will automatically turn off.
Aug 13, 2008 | LG HBM-550 Wireless Headset
Paring
May 14, 2008 | LG VX8300 Cellular Phone
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
