Question about Garden
Onga fofuntain pump 950 called harmony duo
Looking for an onga fountain and waterfall pump for fish pond. What I have is a 950 called harmony duo
Bloomingidoi
  • 49 Answers
SOURCE: Pond pump not working
Well first thing is to locate pump and then check to see if the screen is plugged. turn power off and check inlet tub of pump for sticks, rocks,or leaves in it that can plug the suction on it
Posted on Nov 28, 2008
SOURCE: what cheap fish can i put in my pond
It depends on your climate. I would not recomend the same fish for Minnesota that I would for Nevada.
Posted on Dec 29, 2008
clyde2j2
  • 137 Answers
SOURCE: How do I prime my outside of the pond waterfall pump?
I would take the intake hose off the pump and fill it with water and with the pump running I would hokk upthe intake hose.
I also would if possible have the pump lower than the pond.
Posted on Mar 28, 2009
SOURCE: savio waterfall pump not pumping strong enough
This might be like the problem I experienced ... the 3600 gph SAVIO pump I have needs to be primed to get rid of the air in the pipe.
Posted on Jun 10, 2009
Mackmech11
  • 122 Answers
SOURCE: Tsurumi submersible pump with a bad bearing.
Mostly likely no.. These pumps have a sealed bearing that can not be serviced.
Posted on Apr 18, 2010
Where sale a impeler for beckett w3500.
http://www.homedepot.com/p/Beckett-3500-GPH-Submersible-Waterfall-Pump-W3500HD/100024869
Or if Home Depot can't help you in ordering an impeller for a pump they carry, try sending an email directly to Beckett and ask for assistance on where to get one...
customerservice@beckettpumps.com
Good Luck
May 09, 2014 | Beckett Corporation Beckett W3500 7114310...
Waterfall pump hums but won't pump
this sure sounds if the impeller is blocked and not being able to turn ,Dont let it run this way , can dammage motor of pump , remove intake cover (unplugged) and wash out with garden hose real well , see if impeller (black plastic blade) can turn with your finger (unplugged) , should move easy ! this might be an indacation of need for a filter on pump inlet !!!
Oct 14, 2012 | Little Giant Submersible Fountain Pump
Beckett waterfall / fountain pump W1800 pops breaker everytime you plug it in, consequently it won't run.
Sounds like there are too many things running on the same breaker. Try unplugging some of the other things on that breaker.
Oct 09, 2012 | RTO Beckett W1800 Waterfall Pump
Does a waterfall in my coy pond work the same as a water pump?
Yes and no. Waterfalls in outdoor ponds do providecirculation by moving the water around and keeping it from becomingstagnant. This does however, create acurrent which is not always ideal when trying to grow plants or if you arehousing small fish in your aquarium. Astrong current can make it difficult for plants to take root and can be tootiring for small fish to succeed in.
May 13, 2012 | Fish
My waterfall pond pumps keep burning out. The
I found that little giant pump are oiled filled and if it gets hot it frys itself... As for submersible pumps Magnetic drive Beckett Pumps are nice. My Beckett pump has been going for 4 years now it pumps 4800ghp. the cost $269 last I looked.
Oct 14, 2009 | Little Giant Submersible Fountain Pump
Savio waterfall pump not pumping strong enough
Apr 06, 2009 | Savio Water Master Solids Handling Pond...
Mar 28, 2009 | Max Flo Waterfall Pump 2900 Gph
I have a pondless waterfall and have a problem with excessive foaming.
Here is some info I looked up. Hope this is useful
Don't forget to rate the answer
Kurt
Definition:
Whenever proteins build up in pond water it causes the water to create foam, especially around the area at the bottom of the waterfall. One of the most frequent causes of protein build up is when the fish spawn so we see more foam in ponds during spring when spawning most often takes place. It's not dangerous but can be unsightly. Use fish-safe de-foaming agents to clear water.
What to Use to Clear Up Foam:
go_button.gif Doc's DeFoamer
Mar 18, 2009 | Gard Aquascape Black Waterfall Foam...
Diagram to repair onga house water pump
Got an Onga Riva-Flo water pump, model number TF30, its not working, can you suggests why and how to fix it please.
Feb 20, 2009 | Northern Tool 12 Room Purple Martin House
Drive systems difference
Magnetic Drive: In a magnetic-drive pump, an electrical charge creates a magnetic field that causes the magnet on the impeller to rotate and pump water. Magnetic drive pumps are completely sealed and do not require lubrication. Because they do not contain oil, magnetic drive pumps are safer for ponds with fish as oil leaks do not occur. This type of pump does not generate high head heights, meaning it is unable to lift pond water vertically, which you might need to supply water to a fountain. Work best in cleaner environments with little or no debris Highly efficient, cost-effective operation Since they have no seals to wear out, they require little maintenance Occasionally clean the impeller and its chamber to ensure efficient operation Direct Drive: Direct-drive pumps have an enclosed motor that is powered by electricity, which turns the impeller shaft. Direct-drive pumps achieve significant head height so they tend to work well for fountains or waterfalls. Some models seal the motor in an oil-filled shell with seals around the cord and impeller shaft. These are risky to use if you have a pond stocked with fish as there is an ever-present danger of water contamination if a leak occurs. Many newer pumps, however, feature alternative lubrication over oil that is safe for fish. Look for oil-free models if you house fish or other aquatic life in your water garden. Typically more expensive to operate Ideal pump type for fountains or other accessories Pushes water rather than pulling it Not easily repaired by the user
Aug 27, 2008 | VIA Aqua Pump 4900
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
