Question about Bonaire Air Tools & Compressors
Evaportive cooler bonair motor stops running after 30mins or so
4 Suggested Answers
  • 340 Answers
SOURCE: how do I change the bearings in a Mastercool 2
take it apart if it's all rusted your going to use a lot of bad words my self to get the old ones off i use a grinder cut them off careful not so cut the shaft and clean real good good luck. Tom
Posted on Jun 30, 2009
  • 1456 Answers
SOURCE: I have a bonaire VSM65
Check the Room Thermostat Temperature Setting: Set the thermostat to at least 5 degrees below room temperature.
Check that the Room Thermostat is set to "Cool" not "Off" or "Heat". If the thermostat is not set to "cool" it is simply turning off your A/C.
Check that electricity is on for the equipment. Check all switches and controls, including service switches, including outside by the compressor, inside at the air handler, and fuses or circuit breakers in the electrical panel.
For example, condensate spilling into an overflow pan that uses a sensor switch can be enough to shut down your air conditioner. There are several switches and controls, both manual and automatic that can leave an air conditioner or heat pump turned "off" such as a blower compartment door interlock safety switch, an electric motor overload or overheat switches, and a condensate tray spillage detector switch.
Go to AC HEAT PUMP CONTROL AND SWITCHES to be sure you have found and checked every manual or automatic electrical switch on the system. A bad or failed starter capacitor could also be leaving your system shut down, failing to start a blower, fan, or compressor motor.
If the air conditioning system is still not working, or if the A/C system is running but cool air is not coming out of the supply registers you probably need to call a service technician.
Posted on Jan 30, 2011
SOURCE: Our Bonaire Evap Cooler stopped after power failure
you need to turn off power supply to unit that works ok and leave other unit switched on and code it and test it then switch other unit back on
Posted on Jan 30, 2012
Odor coming from a new bonaire evaportive cooler----have run for 5 days but odor [musty] persists
New evaporatives will smell for a fair amount of time. Its the preservative and glues which are used in the manufacture of the filter pads. Using the machine on cooling for 5 or 6 hours should normally clear this. If not, you can mask the smell by pouring a small amount of disinfectant into the machine whilst on its cooling cycle. (You will have to get on the roof for this if its a roof mount) The machine should dump out the water and refill with fresh water in 2 ways. Manual bleed off will have the machine dribbling water out the drain pipe all the time the machine is working or an auto drain will let all the water out immediately you switch off or after a preset time depending on what type of auto drain has been fitted.
Mar 20, 2017 | Washing Machines
New fan motor gets hot and stops after an hour have new computer
Sounds wired wrong, possibly wrong wires on capacitor.(if there is one of course) need to have wuring schematics and make sure its wired right. Hopefully its the right motor!!
Dec 22, 2016 | Heating & Cooling
My Bonaire evap cooler keeps tripping the fuse when I turn it on
there is an electrical short in the unit that is causing the fuse / breaker to trip
could be insulation, moisture in a junction connection or failing motor
Call in an accredited electrician to find / fix the fault
Mar 12, 2016 | Dryers
Bonaire vulcan evaporative air conditioner
check your filter for dirts, clean or change it, check your evaporator and condenser coil and clean....
Jan 29, 2014 | Heating & Cooling
Bonaire evaporative water keeps running whne the unit is turned off
I would check electric solenoid valve on water line to make sure it is shuting when power is off to blower. Some of these valves can be taken apart and cleaned if it has debris stopping valve ffrom fully closing. To do this shut power off to unit, shut main water supply to cooler. Usually there are four screws holding top cover on valve remove these,remove cover and clean valve. Reassemble making sure that cover gasket is in good condition and properly placed. Turn water and power back on and try unit. Hope this helps you. Thanks
Nov 11, 2010 | Mastercool 67471 Evaporative Cooler Air...
Turn the power of to both the heater and the cooler. Turn the power back on to the heater and the cooler at the same time then reset codes on controller.
Feb 07, 2010 | Mastercool 67471 Evaporative Cooler Air...
I have an evaportating cooler omega it only works on fan.
I would have the unit looked at. The auto section on the motor is turned on by the cooler automatically so there seems to be a problem there at that switch.
Good Luck on your repairs hope this helped some
Nov 09, 2009 | Heating & Cooling
We bought a Bonaire cooling system at yard sale, it leaks water after it is running for awhile, plus it sprays water out the front
I take it this is a window Unit , the water is coming in the room because the Unit has to be pitched about 1/2 into the back ( outside ) or the drain line is clogged ( dirt) stopping water from flowing to condenser ( that cools the coil)
The water is condensation from warm air hitting the cold coil .
Jul 17, 2009 | Mastercool 67471 Evaporative Cooler Air...
Vulcan-Bonaire : summer breeze
This unit is a cooling unit only. I don't know what switch you are looking at but I don't think it's for the evap. cooler(swamp cooler). I am in the Phoenix, Arizona area and it's very common to have a evap. cooler and a seperate heat/cool system as on the hottest days the evap. cooler doesn't cool enough. I hope this helps. Please give me a positive rating. Thank you.
Jan 27, 2009 | Mastercool 67471 Evaporative Cooler Air...
Air Tools & Compressors Logo
79 people viewed this question
Top Bonaire Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Bonaire Air Tool and Compressor Expert? Answer questions, earn points and help others
