Question about Building Materials
I'm trying to program a chamberlain remote to a sears craftsman garage door opener but cannot get them to sync I need your help please
  • 11 Answers
SOURCE: Sears Craftsman Garage Door Opener Wireless Keypad Model and a LiftMaster Chamberlain Professional Garage Door
I had the same frustrating dilemma with my Craftsman LiftMaster garage door and Keypad, Model 139.53754-01 (dated 10/06; and has the # 315 MHz).
To resolve “the dilemma”, grab your keypad, climb up on a ladder to access the garage door opener’s motor unit. On the right side of the motor unit, remove the white plastic casing by pressing buttons on each side and pulling down. This will expose the programming area, and for our purposes, the “Learn” button.
1. On the motor unit, press and release the “Learn” button. The Learn indicator light will glow steadily for 30 seconds.
2. Within 30 seconds, enter a four digit personal identification number (PIN) of your choice on the keypad. Then press and hold the ENTER button.
3. Release the ENTER button when the motor unit lights blink. The code has been “learned”/stored/activated.
Good Luck, and I Hope this Helps!
Gail
For possible future reference:
How to change an existing, known PIN
(Changing an existing PIN can be done with the wireless remote keypad, and does not require access of the motor unit.)
From the keypad:
1. Enter the four digits of the present PIN, then press and hold the # button. The opener light will blink twice. Release the # button.
2. Enter your new 4-digit PIN and press Enter. The motor unit lights will blink once when the PIN has been “learned”/stored/activated. Test by entering the new PIN, and pressing Enter.
Posted on Jun 24, 2008
lobsterman72
  • 91 Answers
SOURCE: Door will only close when held down
That normally happens when the sensors aren't aligned. Both sensors have led lights on them the yellow/orange one will stay on all the time the green one will go out if it cant see the other sensor. Possibly theres a wire that's broken or the other sensor is really out of alignment. Check every inch of wiring from the sensor to the opener, remove wire nuts if present and check the connections. The wires that are used are small, solid and can break easily. Also see if there's a staple that's too tight, move the wire abit where it's stapled and look for damage.
Posted on Jun 27, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: Programming kepad for Sears Craftsman Garagedoor opener 1/2 hp
The only procedure I have ever followed is to press the learn button and then enter the code, and not do anything else. I think your last step of holding the button until the light goes out is clearing codes as fast as you enter them. Just stop after you enter your code and let the learn mode time out on its own. That should do it.
And don't put your head through the wall. It just causes more headaches.
Posted on Feb 21, 2009
glenmann62
  • 91 Answers
SOURCE: Chamberlain garage door opener unit-is it compatible with craftsman keypad?
Hello,Linda well this is your lucky day ,I have installed garage door openers for sears for 10 years and i can tell you that craftsman,chamberlain ,and liftmaster are all the same machine and manufactured under the liftmaster name , if you buy it from home depot it will be a chamberlain ,if you buy it at sears ,it will be a craftsman, and if you go to commercial building supplier it will be a liftmaster! now getting that out of the way even though they are all compatible ,there is one thing that stands in their way and that,s time ,For example if your chamberlain machine is 5 years old and you went to sears last week ,the chances of the frequency being the same are not good , most likely you have the wireless keypad , one way to test the sears keypad against the chamberlain machine is to locate the smart button on your machine ,this button allows for programming of remotes and keypads , to test and see exactly what im talking about take your remote and locate the smart button ,if you have three buttons on the remote press one of the buttons that are not being used on the remote ,above the smart button their will be a blinking light ,if you press your remote button you will notice the light go from a blink to a rapid flash , This is telling you that you are sending a signal for programming to the machine , well the keypad is exactly the same all you have to do is push the enter button on the keypad and have someone watch for the rapid blinking light ,if they are compatible the light will blink rapidly on the machine so all you have to do now is have someone press the smart button once on the machine your indicator light will now be a solid light you will have approx 60 seconds then to put a 4 digit code in the keypad and then press and hold down the enter button on the keypad , at this point you will notice the lightbulbs on the chamberlain machine to shut off and come back on this is to tell you that the machine accepted the code , after thats been done you can use your keypad , you can also find the owners manual to the chamberlain and follow the same instructions to programming the remote , they are identical in programing , if your keypad is not the same frequency you can also tell by looking at the frequency code on the backside of the keypad and also the chamberlain unit usually where the light bulb is will be its code
Posted on Mar 04, 2009
glenmann62
  • 91 Answers
SOURCE: programing garage door opener remote
ok crystal,calm down this is an easy one! first locate the smart button on your openers , next you will press and hold down the smart button until you see an indicator light above it shut off, while your holding that button the light will be solid ,Now your ready to program your remotes ,first programm one side by taking each of your four remotes and pressing the smart button on machine then pressing the button on the remote you want to program,by doing that you will notice the lightbulbs on your machine shut off and go back on , This is an indicator that your machine has accepted the code , now do it with the other three remotes , after you,ve programmed all four ,go over to the other machine and repeat the process but this time you have to choose another button on your remotes since you,ve programmed all four remotes to the same button on each remote ,just choose the bottom button on your remotes this time to keep them seperated , hope this helps you and it is as easy as 1-2-3 your owners manual will describe exactly the same ,i know because i,ve installed over 27,000 machines working as an installer for sears, please leave a nice feedback rating if i was able to help you, good luck,Sincerely Glenn Mayer
Posted on Apr 01, 2009
With my door closed, i push door button to open and the chain and opener continues inthe closing mode. any help?
Shop for sears craftsman liftmaste... on Google
Garage Door Opener Gear...
$31.45
Sears Parts D... Liftmaster 41C4220A Ge...
$21.75
Preferred Do... Chamberlain/l... Sprocket, Gea...
$17.95
eBay Direct Replacement f...
$20.95
Moving Up G... Liftmaster 41c4220a gea...
$31.67
North Shore... Search Results
    Liftmaster Gear And Sprocket Kit 41c4220a Chamberlain ...
    www.sears.com/search=liftmaster%20gear%20and%20sprocket%20...
    Searsmore info. + -. Chamberlain LiftMaster 41C4220A Gear & Sprocket Assembly Kit. $31.40 ... Chamberlain Sears Craftsman Liftmaster 41A2817 Gear Kit. $27.65 ...
Jan 10, 2016 | Sears Craftsman LiftMaster Chamberlain...
Sears troubleshooting
craftsman garage door openers are made by chamberlain.. Give them a call on their 800 number with your craftsman model number and they will help you
Aug 23, 2014 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener Chamberlain - programming problems
I bought a new keypad and 2 VISOR remote (30498). As to programming garage door opener, I did like here:
- it tooks me 20 minutes and works great
Feb 07, 2013 | Sears Craftsman LiftMaster Chamberlain...
I'm trying to program a remote to the sears craftsman garage door opener model 139.53513
The model number for the remote that works with this opener is 53778. Make sure the dip switches are set exactly like the switches on the end of the motor unit.
Oct 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
Can't get my Craftsman Garage Door 139.18190 remote to sync properly with motor. The light flashes on the motor like it is receiving the signal when I push the button on the remoter but the motor does not...
If it is the right remote for your opener try programming like this. Press and hold the button on the and then press and release the smart/learn button. If this doesn't work you have a bad remote.
Aug 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
Door opener remotes not opening garage door.
You have to sync the remotes to the new code. For older remotes, you can open the remote and match the pin settings.
For newer remotes there's a button that you push in the back of the opener that sets in program mode (for Chamberlain). When you push the remote button, it will acknowledge the remote is programmed.
If this doesn't help, comment back on your particular model and we'll help you with the solution.
Jan 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
48 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
