Question about Vicks Humidifiers
Where do I put vapo pads in a vicks v3100 humidifier
SOURCE: Vicks V3100 1.2 Gallon Humidifier leaking
Check if the cap has a gasket or o-ring and is not worn. There are two designs for this model. The older model has the fill cap and valve together. The new design the fill cap and valve are at different locations. The new design has no hole in the bottom of the unit.
You can fixed the problem using a 1-1/2 inch washer for brass tubular found in the plumbing isles in HD or L. The rubber washer is 1 or 2 mm smaller then the grooves in the fill/valve cap. You can stretch the washer and it will fit perfectly in the grooves. When putting the fill/valve cap back with the washer, it will be tighter then before. Firmly turn and you should not have any leaks and make sure unit is level. You can plug the hole because the new design does not have a hole in the bottom of the unit.
Posted on Feb 05, 2009
SOURCE: Vicks V3100 Humidifier
http://www.kaz.com/kaz/support/manual/?ProductManualAction=renderProductManualById&ProductManualId=285ef863f85db2982e6f095560687917
  • 114 Answers
SOURCE: where do i put the
you have to open the lid to the scent pad heater tray. the vicks pads go inside of there. now if you touch them with your hands you need to immediately wash hands after. cause of the fumes will be very strong. then close unit and turn on and it should work properly
Posted on Aug 20, 2009
  • 114 Answers
SOURCE: Owners Manual for 2005 Vicks V5100N Humidifier
www.kaz.com/.../manual/?ProductManualAction=renderProductManualById&ProductManualId
here is the manual for you unit. if you have any moe questions please let me know
Posted on Aug 21, 2009
SOURCE: Humidifier Leaking over floor, not retaining water, excess bubles
My humidifier is leaking. I is a Vicks V3900 Germ Free Cool Mist Humidifier. How do I solve this problem
Posted on Feb 10, 2010
How do i take apart and clean my Vicks V3100 cold air humidifier?
couple of screws on the bottom, but why take it all apart when you can probably run vinegar through it and let that do the work, smells a little, so maybe on the porch...
Feb 27, 2010 | Vicks V3100 1.2 Gallon Humidifier
Feb 09, 2010 | Vicks Humidifiers
Part of the cap on my filter free humidifier is broken. Can I buy a replacement?
go to kaz.com and search using model # (usually found on the bottom of the humidifier)
Oct 20, 2009 | Vicks V3100 1.2 Gallon Humidifier
Just bought a Vick's V3100 Humidifier. When I turn it on the fan starts up but then sounds like it bogs down and stops.
the fan is not working properly it is defected,return item back to store or factory,if can you will have to repair but cost more then item.if my info was of help to you please leave a comment,vote,note.thankyou
Sep 09, 2009 | Vicks V3100 1.2 Gallon Humidifier
Vicks V-3100E Filters
Here is a site that stocks the filters you require, but needless to say it is main order.
http://www.healthcare4all.co.uk/vicks-filter-aca3e-v3100-p-330.html?osCsid=168dab22ab1bfeb75a4095d3d6e51127
Vicks Kaz Filter ACA-3E for V-3100
Availability: In Stock (for immediate despatch)
[ACA3E]
£9.79
(incl. VAT at 15%)
Regards
Alan Hood
ami-man
UK
Jun 16, 2009 | Vicks V3100 1.2 Gallon Humidifier
Sep 18, 2008 | Vicks V3100 1.2 Gallon Humidifier
Missing part
http://homeappliance.manualsonline.com/manuals/mfg/vicks/v3100.html
This is a link to the manual for the humidifier you bought.
It shows how everything comes apart and how it all goes together with the filter.
Hope this helps.
Good Luck.
Apr 18, 2008 | Vicks V3100 1.2 Gallon Humidifier
Filling humidifier
On the Vicks v-3100 the water tank should lift off of the unit. Flip it over and there is a lid. Open the lid and fill the tank. Once you've filled it back up, put the lid back on. Flip the tank over to make sure there are no leaks, then put it back on the humidifier.
Note: It's very important to check to make sure the tank isn't leaking before you put it back on the humidifier, if it is, it will flood the reservoir, in turn causing water to leak out of the bottom of the humidifier (which is one of the major complaints about the 3100).
Sep 11, 2007 | Vicks V3100 1.2 Gallon Humidifier
Humidifiers Logo
112 people viewed this question
Top Vicks Humidifiers Experts
paulcarew
Robert
Are you a Vicks Humidifier Expert? Answer questions, earn points and help others
