Question about Locks & Locksmithing
Need to reset small safe entry batteries died put new ones in but it won't lock no name on safe just EX-1057580
  • 113 Answers
SOURCE: small floor safe Sentry Model 3877 electronic lock and key
This manual will answer both of your questions.
Posted on Mar 05, 2008
  • 365 Answers
SOURCE: mazda 3 yr 2004
Fords "better idea"...go to an automotive stereo shop that does keyless entry install for around $'s the cheapest way to go anyway. Dealer will have to reprogram the FOB, you're looking at $100+
Posted on Jun 14, 2009
  • 26 Answers
SOURCE: Batteries died. Put new ones in (red light comes
there is one red buton press two min then try
Posted on Dec 03, 2009
SOURCE: my 2000 licolin battery died
The key has to open the drivers door
Raise the car up,support it,& put your battery
charger on the starter battery cable terminal
& ground the black clip
Try charging the battery for 4 hours or so
Posted on Jul 03, 2011
  • 135 Answers
SOURCE: my keyless entry is not
probably sensor for keyless entry,but would not advise u too get this from a junk yard as the sensors are vin specific,will put ur car into anti-theft mode then u will have to replace the body control computer,have a dealer order u a keyless entry sensor vin specific for ur car,these are usually under dash up top middle area its a little black box,will have to remove dash pad or dash to replace.
Posted on Aug 21, 2011
The battery is flat and the safe will not open??
All safes which have internal accessed batteries have a hidden key entry, generally found behind a blanking plate on the front of the safe. keys would have been supplied with the safe when purchased.
flat battery and no keys = Useless safe.
If you are in that position you have two choices:
If there is nothing in the safe buy a new one.
Valuables in the safe, take it to a locksmith.
If the safe is of the readily available small sized mass produced types the key lock is between the rotary door knob and the keypad behind a flip off blanking plate, this type of key lock is very cheap easy to replace and very very easy to pick so it won't cost much.
Feb 22, 2017 | Home Security
My safe, a Cathedral EA15 Will not lock. Any suggestions people?
  1. 1
    Enter your code on the keypad located on the front of the safe. Some electronic digital safes require you to input a special character like "#" before and after your code. The safe should either beep, have a LED turn green, or display "OPEN" if you have correctly entered the code.
  2. 2
    Turn the handle to the right within five seconds of correctly entering the code. If you wait too long, the safe will lock and you will have to enter your code ag
Open the safe with a key. Use your emergency key that came with the safe to open it if you forgot the code or if the batteries have died. Remove the key cover from either the handle or the control panel to reveal the lock.
  1. 1
    Enter your code to open the safe.
  2. 2
    Place the electronic digital safe into code reset mode. On some models you need to hold the last digit of the code or press the "*" button to get into code reset mode. Other safes require you to open them and press a small red button on the inside of the door.
  3. 3
    Enter your new code on the keypad and press "#" to finish. Some safes may require you to press "*" or a letter to finish the code. If the safe requires it, enter the new code again to confirm that you entered it correctly.
  1. 1
    Use your code to open the electronic digital safe's door.
  2. 2
    Locate and remove the battery cover on the inside of the door.
  3. 3
    Replace the used batteries with new ones. For most safes, this will require two or four AA batteries.
  4. 4
    Test the batteries. Use your code while the door is open to test the batteries before closing the safe.
Feb 08, 2015 | Locks & Locksmithing
My battery died in my remote lock/unlock. so I put he new battery in and now my locks don't work
You have most likely 'Lost' the electronic code that the key fob held. Your dealer will reset the key fob code for you.
Dec 23, 2014 | Cars & Trucks
How to reset the entry code to homcom 12"x14"x10"
Most of these Chinese safes have a reset button inside the safe. Open the safe, press reset and enter your new combination. Then check it before closing and locking the safe.
Jul 12, 2014 | Safe International Digital Electronic Safe...
Cannot unlock doors and reset alarm
Go on youtube and put in how to reset your car key after renewing key fob battery good luck colin
Jun 30, 2017 | 2005 Mercedes-Benz Mercedes Benz E320 Cdi
I want to reset the entry combination
Try and use default code 159a then try and reset if not go to put in safe it has instructions on how to change all these are the same even if name is different
Oct 02, 2009 | Safe International Digital Electronic Safe...
I forgot the safewell electronic code and didnt have the key
NOTE: The safe needs to be upright and right side up or the locking mechanism
won’t work.
To open an electronic safe the first time, press the following numbers/letters on the
electronic keypad –159B. (These numbers are preset. You should change the code as soon
as possible after opening the safe to insure proper security). After you have entered the
factory set code, you will need to turn the knob on the faceplate to open the door. You will
have 5 seconds to turn the knob before the locking mechanism is reactivated.
To enter your own security code you will need to follow the steps listed below:
1. After opening the electronic safe (with the pre -set factory code of 159B) locate the
small red button on the inside of the door near the hinge.
2. Press the red button and then release it, you will hear a beep.
3. With the door open, enter your own personal security code, which can be 3- 8 digits
long, and confirm your new code by pressing the letter “B” on the electronic touch pad.
Before you close the door, try the new security code to make sure the lock release the
knob so you can turn it and retract the live action locking bolts.
If you can not get this open more then likely you will have to cut it open.. One last thing to try is to email safewell
Good luck
Sep 14, 2009 | Locks & Locksmithing
Small floor safe Sentry Model 3877 electronic lock and key
Feb 21, 2008 | Sentry Fireproof Safe
Locks & Locksmithing Logo
91 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
