Question about The Home Security
Our cctv camera just suddenly stop working..on the screen it says check the video cable connection with the PC.
3 Suggested Answers
  • 635 Answers
SOURCE: I have a sentient 4
Make sure the CCTV recorder is on and then connect the USB cable from the device to the PC. After a few seconds your PC should show a pop up notice that a new device is found and the PC is loading the appropriate software for it.
Go to My computer and see if the device logo has come on the screen other than all the PC devices ( such as C drive , DVD Rom drive etc: )
Double click on the CCTV icon and the PC will open the the contents. There will be several folders and open them one by one . One of them will contain your camera recordings. Just copy and paste them in a new folder on your PC.
Revert back if you have any difficulty.
Posted on May 18, 2011
  • 133 Answers
SOURCE: DVR recorder for CCTV camera. Is not working. It says on the monitor cable not connected and no display. Monitor, cameras , DVR, adapter for cameras all working. I tried every thing.
try to change to VGA monitor or you could hold 5sec on ESC ,F1 or exit button
Posted on Feb 25, 2016
I have a wireless surveillance system, 4 chanel. came with 2 cameras. have purchased additional camera. How do I get the system to accept camera?
I am going to write a short discussion because I feel this subject is best handled by a person that knows what they are doing. There are plenty of Youtube videos that shows you how to install a CCTV system. As you didn't mention what type of CCTV camera it is, can this topic become very lengthy.
Please look at this tutorial on youtube,
The old systems is not difficult to do it yourself if your technical minded, although the newer systems will require some IT background. I recommend a certified installer to assist you, you can damage the camera if you don't know what your are doing.
Get the correct cabling and connectors.
The easiest are the pre-crimped cabling for DIY and it is plug and play. No setup is usually required for the CCTV recorder to work unless the recording on the CCTV was disabled. Any other setup will require special tools.
You get 2 kinds to wired CCTV camera systems.
The old tech is analogue with a thick data cable and set of wire for power.
The professional installed cabling will require a technical person to crimp the CCTV cable with a special BNC crimping tool. The
The old systems needs to have
The newer systems uses LAN cables.
The newer systems requires an IT/CCTV tech person to set it up.
Sep 19, 2017 | Came Home Security
I've got a problem with my cctv cnm 160GB H 264 4 channel DVR I have 3 cameras set up on it and 1 of the cameras have stop working I've checked all power and cables and they are all working fine the...
Remove all the cameras then reboot. If it boots up normally then shut down dvr and add a camera and repeat. If it doesn't solve the problem, the issue is probably a video card or motherboard issue and will need to be repaired or replaced.
Mar 20, 2014 | Televison & Video
use the USB cable to connect the camera to the PC .PC also has audio video out cards to be connected to the TV monitors.
The CCTV cameras are cheaper and easy to connect as they all come with Audio Video out.
Feb 26, 2014 | Sony Cyber-Shot DSC-W560 Digital Camera
Sure. There are many CCTV cameras that can be connected by RCA cables.
Feb 03, 2013 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
How to set up cctv camera video output to Alba 19880HDF via vga input
vga input is a 15 pin D shape connector. find vga out put in your cctv camera. note that cctv camera's vga out & Alba's vga input are male or female connectors. get the appropiate vga cable & connect to input & output.
Aug 24, 2011 | Televison & Video
I have a Sentient CCTV System and now all the screens on the monitor have lines going across them as if there is some sort of interference, do you know how to stop this ?
Look for Totally tight cable connections. A break in the grounding causes the interference, usually. It only takes a slight loose connection to have issues.
Jun 28, 2011 | Home Security
How can i connect a dome ccd to tv
just connect BNC Connector in the one end of the video cable and AV Pin on other side.Then connect BNC end to camera and AV pin to TV video port
Feb 15, 2011 | Dome 4 CCD CCTV Camera Surveillance...
Camera suddenly will not record
This looks like a relay or micro switch has gone, camera needs looking at.
Jun 20, 2010 | Panasonic NV-DS65 Mini DV Digital...
No signal
how do i connect a usb stick for a ch usb dvr to a video player
Jan 29, 2009 | Cyberhome DVR 1600 DVD Recorder
My PC Not Work With my CCTV Systems
what kind of error display
which card use 4 channel , 8 ,16
Feb 26, 2008 | Intel Motherboard
Home Security Logo
Top The Home Security Experts
Lawrence Oravetz
Are you a The Home Security Expert? Answer questions, earn points and help others
