Question about PRINTER Office Equipment & Supplies
I have had my printer for some time but rarely use it. I first lost the wireless feature and have to use a usb cable in order to print a document and now the screen on the printer is blank?
Jowinson
  • 16 Answers
SOURCE: hp laserjet 1300 prints extra blank page
Before you get a better answer to me , I hope you would have told us if you are the first person that used it so that we can know if this problem started from the initial point or at the middle time of using the printer
1) Did you add additional memory to the Printer?, if Yes remove and try back.
2) Try you use this printer in another PC
3) Look for HP1300 printer software.
4) It may be a mechanism/paper carriage error which can not be corrected by software unless you change mechanism/paper carriage.
Posted on May 08, 2008
SOURCE: Lexmark X4850 wireless set-up
I have a Lexmark X4850, every time I print a job it prints a blank page first then the document. I have tried to tell it to print 1-1 or 1-3 but it continues to print that blank page first. any suggestions.
technotech
  • 183 Answers
SOURCE: Printer is online and says ready but won't even attempt to print
Click on Start,
Go to Control Panel,
open Printer and Faxes
look for the Printer which is HP C5280 or any icon related to same,
Right click
Choose set as default
Close Everything
Shutdown your computer and Printer
Check and make sure that the USB cable is connected propely
Restart the Printer first and then the computer,try Printing some thing.
if this doesnt resolve you issue then i would suggest you to uninstall the printer software and reinstall and update it from HP.com.
Please let me know about the resolution
Posted on Nov 01, 2008
SOURCE: "Off-line" error message
Go to control panel - printers. Right click your printer icon - select delete printer. Reinstall the software and drivers via CD supplied. May have to restart your computer when complete. Go back to control panel - select printers - select add a printer and follow the instructions. When finished print a test page.
Posted on Nov 07, 2008
  • 103 Answers
SOURCE: Printer only printing a blank page
Try to reset the printer and print the demo page
Posted on May 05, 2009
I how do I connect my pixmamx922 with my ohone
Apple Airprint:
AirPrint allows users to wirelessly print photos, emails, web pages and other documents without the need to install device drivers, saving time and making for a seamless experience. Both your Apple device and your Canon wireless printer must be connected to the same wireless network connection.
A firmware update for the printer may be needed to support AirPrint. You will need a PC (Mac or Windows), a USB cable and the Firmware utility (available through the Drivers & Software link above) to perform this update.
Google Cloud Print:
Google Cloud Print allows you to print to your Canon wireless printer whether you're in the same room as your printer, or on another continent. You may need to register your Canon wireless printer before using this function.
A firmware update for the printer may be needed to support Google Cloud Print. You will need a PC (Mac or Windows), a USB cable and the Firmware utility (available through the Drivers & Software link above) to perform this update.
Printing from Email
Print from E-mail allows you to print attachment files easily. You only attach a picture or a document from your computer or smartphone and send the e-mail with the attached file.
Aug 07, 2017 | Cell Phones
I have a very old HP LC3 netserver. It was in my office, and I have moved it to my home. I would like it to communicate with my printer in order to print out documents. Can it be connected directly to my...
Add the printer to the wireless router as another node via DHCP. Then add the printer by the IP address. Your server does not have wireless so it will need to be connected to the router via network cable.
Or, you attach the printer directly to the server via parallel port (RS-232) cable. Or upgrade the server with an USB port, and connect it that way. gl
Mar 23, 2013 | HP NetServer LC3
Please i want to know if konica minolta magicolor 1690mf is wireless printer? and how do i set the two sided print.
The Konica Magicolor 1690MF Printer/Copier/Scanner is connected with an Ethernet Cable or USB Cable. It is not equipped to operate as a wirleless printer. It has a 10Base-T/100Base-TX Ethernet interface port and a USB Revision 2.0 High-Speed compliant port.
To do two-sided printing you must have the duplex (double-sided) option installed. This also requires either Tray 2 or the Attachment to be installed underneath your machine. Tray 2 is the optional lower feeder unit which increases capcity of your machine to 500 pages. The Attachment comes with the Duplex Unit.
Only Letter and A4 plain paper (16-20 lb bond) can be autoduplexed. With the duplex accessory installed you can do duplex or double-sided printing automatically.
From within Printer Preferences select Two-side Printing > Automatic. Shoud have choices of Off, Manual or Automatic. Within the Layout Tab for your work you may also be able to specify duplex (double-sided).
Should you have continued difficulty, please reply and advi e if the duplex option is installed and with which software and operating sysytem you are using.
Thank you for using FixYa!
Sep 19, 2011 | Konica Minolta magicolor 1690MF All-In-One...
I have the same problem. The wireless printer can't be recognized on the network even when plugged in via USB and the buttons are frozen. Have tried reinstalling multiple times. Now I'm dead in the water.
run this http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-77759-1&lc=en&dlc=en&cc=us&product=3795406&os=4063&lang=en
then run this: http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-74066-3&lc=en&dlc=en&cc=us&product=3777182&os=4063&lang=en
should clear up your problems :) good luck!
Dec 30, 2010 | HP Officejet 6500 Wireless All-in-One...
I've installed the AL-1540CS but I'm having trouble figuring out how to scan documents and load them onto the computer with the Parallel interface. Can you help me out?
Scanning is not possible thru the parallel port. You must use the USB1.1 port in order to use the scanning feature.
The parallel port is only used for printing.
If you hook up the machine with a USB cable you can print and scan using USB. This includes color scanning.
Thank You for using Fixya.
Jul 13, 2010 | Sharp AL-1540CS All-In-One Laser Printer
Wireless printing
not possible... kodak all in one esp-7 and esp-9 support wireless printing. what u can do is, u can connect ur printer and computer through usb cable and then give a print command from ur computer. be it internet or any document on ur computer. kodak printer will give u high-quality prints,but ur printer does not support wireless printing.
Jul 28, 2009 | Office Equipment & Supplies
Printer and computer no communication
Unless you have a wireless router to conduct traffic, you won't be able to print wirelessly to the AIO 966.
You will need a cable (and it's possible the printer didn't come with one). You'll need a USB A-B cable to do this. You can find one at any office supply store, Radio Shack, Target... it's a common part.
Then with with laptop and printer on, plug in the cable to each and Windows should recognize the device and you'll be able to print.
Jul 01, 2009 | Dell Inspiron 6000 Notebook
Printer won't print.
If the cable you are using is USB.
Try these steps.
1.Right click on MY computer ->Properties->Hardware->Device manager.
2.You will get Device manager window popping out.
3.Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:WE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for what location says, Eg -LOCATION : HP Office jet 7400)
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get pop up "Found new hardware".Then the Drivers will be installed Automatically.
Thanks
Riz
Mar 16, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Oct 05, 2007 | Lexmark X4270 All-In-One InkJet Printer
21 people viewed this question
Top PRINTER Office Equipment & Supplies Experts
Gene
Hardeepak Bhambh
Hardeepak Bhambh
Are you a PRINTER Office Equipment and Supply Expert? Answer questions, earn points and help others
