Question about Ricoh Office Equipment & Supplies
How to fix toner delete on a Ricoh MP3353 machine
3 Suggested Answers
  • 42 Answers
SOURCE: Ricoh 1035 Display Messages
Empty waste toner in transfer unit on the right side door.
Posted on Jul 04, 2008
  • 263 Answers
SOURCE: MPC2500 my machines are saying INDEPENDENT TONER.
This happened when you take of the toner bottle, replace a new bottle and that put it again the bottle that as bean there before.
You can enter in SP mode and disable this messages.
Try this:
press yellow key
press 107 in the key pad
Old the red key at least 3 sec.
After that press "COPY SP"
Press on the key pad 5051001 and than #.
Press the OFF button and than press OK on the bottom.
Exit all the way out and reset your machine by turning OFF and turn ON.
Hope that helps.
See you
Posted on Apr 23, 2011
Testimonial: "Thank you so so much for your help. I didnt know that i couldnt put the bottle again. Thank you and thanks Fixya to provide this tec support."
How do i fix problem Add Toner
The Ricoh has toner and developer. When the developer is depleted it can not get to the right density when toner is added so the machine keeps saying to add toner. You need to clean out the developer unit and put in new developer. Depending upon your model you may need to install a drum and blade too. Ricoh technicians are trained to dissemble the unit and just replace the parts needed instead of getting a whole drum/developer unit. If you live in Southeast Florida Advanced business computers is a great source for help. Computer network repair, printer and copier maintenance repairs, leasing and supplies.
Oct 28, 2015 | Ricoh Office Equipment & Supplies
Add black toner but still empty
Is it a genuine Ricoh Toner or a equivalent refill, if it is the latter then my machine would say empty when actually full. Just keep on using the machine, and have another toner on stand by.
If its a genuine Ricoh toner suggest the machine needs a clean around where the built in (toner) chip is located.
Jun 03, 2014 | Ricoh Aficio SP C820DN Laser Printer
My Ricoh CL7000 is saying add toner magenta. But there is plenty of magenta in the cartridge. I've added toner and cleaned out everywhere I can get to. Any suggestions?
It could be a clog in the toner tube, but the most likely (and easiest to fix) problem is the magenta DV unit. Replace the magenta DV unit, turn the machine off and back on, and if it still says add magenta toner open and close the toner cover so that it can load toner, then your problem should be gone.
Nov 08, 2010 | Ricoh Aficio CL7000 Laser Printer
I have 2 problem for Aficio 3045 i) the copier alway show toner sign on when i fill the toner or change the developer also the same. ii) B5 paper cannot be use,always jam when i using drawer or multiple...
most of this add toner problem came from the toner hopper, this need to be checked by a technician to fix the four plastic mylars to see to it that they are attached and properly scrapped the toner. next is the B4 fist do you set or is the right paper size is set on the drawers? what is the jam code so we can see if were is the fault of the machine?
Sep 09, 2010 | Ricoh Office Equipment & Supplies
RICOH AFICIO 2022 I got an error with the cartridge. machine says that there is no toner, put PCU
If it says there is no toner but you have toner in there, pull out the toner bottle and feel in the hopper (where the toner bottle sits) -- sometimes the gray cap from the old toner bottle gets left behind, and that will block the machine from pulling toner from the new bottle. Remove the cap and your copier should be fine.
If that doesn't fix it, you might need a new PCU. Once they start to get old, the developer gets bad and they don't have the right mix of toner and developer.
May 26, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
Which toner to use for the ricoh savin 2555? 5105D or 5770?
If you have a Savin 2555, you need type 5570.
If you have a Ricoh 1055, you need type 5105D.
They are both the same machine, however the toner cartridge is model specific. ie; use the Savin type toner for Savin machine only and Ricoh type toner for Ricoh. There is a difference between the cartridges and the way each fits the feed mechanism.
May 07, 2009 | Office Equipment & Supplies
Jul 03, 2008 | Ricoh Aficio 1035 Copier
Add Black Toner Msg.
Try taking out the cartridge and reinstalling it. Was this a original ricoh toner cartridge or a el cheapo cartridge off the internet?
Mar 19, 2008 | Ricoh Aficio CL2000 Laser Printer
Ricoh 1018d won't add toner after installing toner bottle.
the part numbers are different for each toner from ricoh, Lanier, Savin and Gestetner. From what I recall is the bottles are different, check the old bottle vs new. Also if the machine had run very low you may have to open and close the fron cover several times, this intiates a toner feed program.
Feb 26, 2008 | Ricoh Aficio 1018D All-In-One Laser...
35 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
