Have to push fill button at start of every wash On auto chlor a4
3 Suggested Answers
  • 91 Answers
SOURCE: washer won't run , push start button just beeps
in order to determine what is the cause of your problem , please provide the error codes an model number so we can figure out what is wrong with it, has anyone set anything heavy on top of the machine if is a top load machine, first guess if you have power to the machine would be look into the lid swtich an go from there....
Posted on May 28, 2009
SOURCE: I have a auto chlor model a4 dishwasher and when I
The Auto-Chlor A4 dish machine requires that you push and hold the Fill switch until the water reaches the desired level. There are several reasons that the machine does not refill for the rinse part of the cycle. It could be a defective fill switch on the 90 sec. timer which is located in the box that is down by the pump. This switch gives power to water inlet valve while the switch actuator is in the valley of the adjustable cam. Also, the drain solenoid might be sticking in the up position allowing the rinse water to drain from the sump. There is not a float or a water level sensor in this machine.
Posted on Nov 14, 2015
I have a auto chlor model a4 dishwasher and when I push the fill button it only fills for 3 seconds and stops and if I fill it up by holding the button down and run it threw it's cycle when it goes into...
Hi John,
This sounds like a misadjusted water level sensor. This is a commercial dishwasher but the principles are the same. I would check the water level sensor to make sure that there is no debris under it or a leveling sensor bent causing the machine to think it is at the proper water level to begin washing when it is not. This may be a mechanical lever float type switch or an actual electronic sensor that will detect where the water level is. Most household DW's will have the mechanical float switch that will float with the water level and shut off the fill solenoid when the proper level is reached. You are having to defeat this process by holding the button in to override either a faulty sensor (replace it) or a misadjusted float switch. These would be the too most likely causes of this problem. I hope this helps!
Jun 04, 2014 | Dishwashers
Washer will not fill with water when the start button is pushed.
Have you checked the water pump? I would say it is that or the button may be defective.
Feb 26, 2011 | Maytag Neptune MAH5500B Front Load Washer
Washer start to run water the it just stop
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Feb 20, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
McClary washing machine won't spin. A technician
washing machine fills up to much with water on med fill and not enough on min fill
Nov 03, 2009 | Washing Machines
Washer won't run , push start button just beeps
May 28, 2009 | Bosch Washing Machines
AUDI A4 AUTO
In the gearbox sump is 2 plugs. one small to drain the oil and a big on that fits a 17 socket l-key .start engine in neutral ,turn out the :17" nut and fill with pump until oil overfills. I dit mine this way and got the advice from a good geeerbox rebuilder in Pretoria. NOW HELP ME AND TAKE A PHOTO OF YOUR SPEEDO PIPES AND E MAIL TO ME I CHANGED THE PIPES AND MIXED THEM UP AND NOBODY HAVE OR WANT TO SHARE THE INFO PLSE vmd.bakker@vodamail.co.za
Jul 11, 2008 | 1998 Audi A4
Dishwasher fills with water... wont wash
usually if the motor is not kicking in then it is a blocked/seized wash motor or a broken wire somewhere from the timer to the motor. either will mean a stripdown. try checking out the motor first.
Jun 13, 2007 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Washing Machines Logo
73 people viewed this question
Top Washing Machines Experts
