Question about Westinghouse Televison & Video
Try find the codes a 1999 white westinghouse tv and vcr
    Top Expert:
  • Westinghouse Master
  • 75,178 Answers
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts. .
Posted on Dec 30, 2016
How do I connect my Sylvania DVD VCR Player to my Westinghouse LCD TV?
Your Sylvania player probably has three outputs: right audio (red), left audio (white), and video (yellow). Use a corresponding three conductor cable to connect to corresponding inputs on the rear of your Westinghouse TV (if it has them).
Sep 19, 2015 | Sylvania Televison & Video
Looking for codes for White Westinghouse TV VCR
Visit these sites. Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 21, 2015 | Westinghouse Televison & Video
Tv codes for westinghouse
To program your universal remote control ... for a Westinghouse TV,
try these codes (on your universal remote control)...
00451, 00885, 00889, 01282, 01300, 01577, 01712, 01755, 01826, 02293
If it is a White Westinghouse (TV), try these: 00463, 01661
May 23, 2014 | RCA RCU600M Remote Control
Need code to westinghouse tv
Hello
Three digit universal remote codes for White Westinghouse TV are:
097/ 100
Four digit codes are:
0100 0130 0138 0136 0227 0279 0080
Four digit codes for Westinhouse TV are:
0143 0114
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
Oct 08, 2011 | Televison & Video
I cant find the code for ld-425
Hello
Three digit universal remote setu codes for White Westinghouse Tv are:
097/ 100
Four digit codes for White Westinghouse TV are:
Four digit codes for Wastinghouse TV are:
0143 0114
OK.
Aug 31, 2011 | Westinghouse Televison & Video
WHAT THE CODE TO PROGRAM A WHITE-WESTINGHOUSE OLDER MODEL TV
Hello
097/ 100
0227
0279
Direct Code Entry
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
OK
Aug 05, 2011 | Westinghouse Televison & Video
I have white westinghouse tv/vcr the urc-4021b00 does not program
Helo
Westinghouse TV/VCR combo is not lited with One for all URC-4021 codes. OK.
Jul 06, 2011 | One For All URC-4021 Remote Control
White Westinghouse sk26h240s remote codes
Goto this page:
http://www.comcast.com/MediaLibrary/1/1/Customers/Customer_Support/Digital_Cable_with_OD/Digital_Cable/remotes/grayokselect.pdf
follow the instructions for "Searching For your Code " This worked for my White-Westinghouse (though it takes about 20 repetitions to hit the code!)
Hope this helps
Nate Wells shoplifted@gmail.com
Jan 10, 2009 | Televison & Video
WHITE-WESTINGHOUSE TV/VCR COMBO NEED CODE
The code for the TV is 0623 but to use the TV/VCR button to change mode from line to TV the code is one of the following 0179, 0451, 0463, 0624 or 0278. The 0623 only activates the menu but doesn´t let you change Air/Cable mode without first changing the Line/TV mode by pressing the TV/VCR or Line input button on your universalk remote with one of the other codes.
Oct 28, 2007 | Zenith ZN110 Remote Control
Televison & Video Logo
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
