Question about LG Televison & Video
Lg ld550 6 yrs 0ld ,how to get audio to earphones without using earjack as it cuts sound to tv speakers
    Top Expert:
  • LG Master
  • 77,499 Answers
The TV is wired that way so you can' do that, one or the other.
Posted on Dec 29, 2016
chrispurs1
  • 372 Answers
SOURCE: no sound coming through tv speakers
Hi.
Some Large flat panel tv sets have seperate speakers that clip on to the side of tv set if you got the manual with the tv does it say about seperate speakers.
Or if it does have speakers with the tv set check that the audio frequency is set to your countries transmission frequency.
Example UK is PAL (I) If your not in uk try and find out what yours is.
http://dysonmanuals.llc.nu/
Chris..
Posted on Dec 30, 2007
falter
  • 245 Answers
SOURCE: 32LG3000 No sound,no DTV
check ur sound volume also if sound is muted this all can be done by ur remote controll
Posted on Nov 20, 2009
bshldn
  • 736 Answers
SOURCE: can not get my surround sound system to work with
The way to turn off the tv speakers is to press the menu button scroll to the option category navigate to output select and choose variable. However just turning off the tv speakers will not cause the surround sound system to work with this television. Connecting the red and white composite audio cables to the television's OUTPUT will get you stereo sound. Some people opt to keep the tv's speakers turned on when doing this. In order to get the digital optical out to work between the television and the surround sound system you will have to be using input tv. You will have to be using the television's tuner with digital cable no cable box or with an over the air antenna. Did you make sure you connected the red and white cable to the surround sound aux or any composite input and choose the right function on it?
Posted on Dec 03, 2010
kerguney
  • 577 Answers
SOURCE: want to connect pc speakers
Your TV should have an AUDIO OUTPUT other than optic..at least " Headphones" output..
You can connect TV audio output with a RCA cable.
white and red audio jack....
since SUB has both RCA and "3,5mm Headphone female Jack"..here are the options;
** you need to buy a cable one end 3,5mm MALE headphone jack and the other end 2xRCA stereo (or 1x RCA for mono or you may need "Y cable " ) to be connected to your TV...
** or 2x RCA
white and red audio jack and connect from your TV..
**" "Headphones" output to SUB with 3,5 male-to-male cable ( the least recommended)
And you need to connect front,centre and rear speakers to your SUB as well...
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Posted on Jun 23, 2011
jdvillanueva
  • 2098 Answers
SOURCE: i am plugging in a
Hi Jason,
To hear the sound to your Bose Audio system from LG 37LH20 you must have an optical cord, and your bose must have an optical audio in.
RCA Jack of LG37LH20 is only for audio IN, there's no RCA Jack audio out from this model that's why you can't hear the sound even you hook up the Bose from that jack.
To make it possible, hook up the optical cord to your TV and then the other end to Bose Audio system.
Let me know if you need further assistance.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Jul 01, 2011
How to undo earphone/earjack for cell phone
You may be having a faulty earphone jack... try plugging in and out... then restart your phone and reset it
Jul 25, 2014 | Verizon Communications LG enV Cell Phone -...
No sound without headphones? lg dp173g dvd
Open the Control Panel , select Sounds, choose the speakers, Apply. Unplug the headphones and reboot.
May 12, 2013 | Computers & Internet
The sound on my symphonic 19" personal television can not be heard but the picture is fine. How do I get sound back on my tv without a remote control?
The earphone jack may be damaged. This takes the audio from the set and provides either a path to the speaker or when plugged in to the earphones. Try the earphones - if they work, the jack may be at fault. If the remote has muted the sound, turning the TV off then back on should reset the mute.
Sep 23, 2011 | Televison & Video
No sound/audio while playing tv.
Hello
If there is no audio output from your tv, either your TVs speaker or its audio output IC has damaged. You just check it with an earphone/headphone, if there is an earphone or headphone socket in front panel of your TV. If there is sound from the headphone/earphone, and not from the speaker, means the speaker has damaged. You have to replace it with same type and number. Just check your set's audio out socket, if any provided, connet it to any external audio sourse, like amplifier or so, and check whether there is sound output from it. If not, your Tv/combos' sound processing IC inside has some trouble.
most common fault is related to sound output IC or speaker itself. If speaker is found OK, go to the sound output section. This section can be easly located as speaker wire goes to that section, and follow it. Before replacing the IC, check its leads for any loose or bad soldering. i advice you to resolder all the terminals of that IC, by applying a little more solder, without making any solder bridge loose contacts between them. If this does not helps, replace the IC with an identical type and number. OK.
Dec 24, 2010 | Panasonic PVQ-M2509 Combo
No sound
Hello
If picture is OK and there is no sound output from your tv, means either its speaker or the Sound output Ic is not working. The case of speaker fault can be easly detected without opening the TV. You just place your ear very near to the speaker side and switch on the TV by AC mains [not with remote control]. You may hear a "thumb" SOUND OR A "HUM" sound from it. If any one is there the internal speaker is working fine. The fault lies in audio output Ic stage. If there is no sound said above, speaker can be suspected. Befor confirming that the speaker is faulty, if your TV has an earphone or headphone jack in front, insert the earphone or headphone socket into it, and check whether there is any sound heard from it. If there is sound from headphone, means that the headphone socket is faulty, it does not bypass the sound to the speaker. When head phone is connected, the connection to the speaker will automatically cut of. When it is pulled out from the socket, the speaker connection will resume. If the changeover switch inside the earphone socket also show this kind of trouble. If the speaker inside is found faulty, unscrew it out of place after opening the TV, go for a same type and number, impedence and shape.
If there comes the above said "HUM" sound from the speaker, surely the Sound Output Ic is faulty. Replacing it will solve the probelm. Before replacing it, check it soldering points for any loose contact. It is best to resolder all suspected point is sound section before replacing the ic.
Note: In modern TVs there will be any trace of sound, without a video signal. Without video, sound is muted. ok.
Nov 07, 2010 | Toshiba CF19H25 TV
No sound from speakers, loose connection in green jack wire.
Yeah man I have the same problem!
I guess I will just buy a new jack!
May 27, 2009 | Logitech Z-640 5.1 6-Piece Home Theater...
Connect 2.1 Logitech to a TV
if you have an RCA output for your audio. you can buy a lead that goes from 3.5mm headphone jack into 2 RCA phono plugs.
Feb 25, 2009 | Logitech X-530 Computer Speakers
Connect Logitech 2.1 to TV
i dont know how ur tv does not have a earphone jack i wonder now a days how they make such tv's , pls try to take sound from audio LR if it helps other wise no hope to get sound on speakers sorry pls try to find in manual if there is any hidden headphone jack some where see in manual
No sound
is there sound at  AV OUT  pins  check  with any  amplifier ,  if sound is coming  then  there should be  AUDIO AMPLIFIER IC gone . and  replace it  with same number....
if sound is not coming   then  inside TV kit there should be CHROMA IC gone   and replace it with same number,
this will solve  ur problem
thanks
Oct 25, 2008 | Symphonic SC309C 9 in. TV/VCR Combo
Televison & Video Logo
43 people viewed this question
Computer Repairing
Computer Repairing
