Question about Kodak EasyShare LS755 Digital Camera
Am using kodak easyshare lss 755 can i use it without memory card. can it work without memery card
Agent Allan
  • 480 Answers
SOURCE: Memory Card Requires Formatting
Hey B418,
Formatting will delete all your pictures on your camera or memory card. The camera might be prompting you to format because the the camera's memory is full. To avoid losing your pictures I would connect your camera to a computer, download your images to your computer first, and then format the memory.
Sincerely,
Allan
Go Ahead. Use Us.
Posted on May 01, 2008
SOURCE: kodak easyshare cw330 new memory card reads full....
Camera doesn't support more than 1GB memory card, so better use less than 1gb SD card
..........Prashant
Posted on Mar 13, 2009
SOURCE: memory card
I experienced the same problem with my Kodak C330. I took it to Walgreens and the tech stated that the C330 was created before 2 GB memory cards were invented; therefore, the software inside it doesn't recognize a larger GB capacity. In short, the C330 has a 1GB max capacity. Considering you can take 1200 pictures with a 1GB card, a larger size really isn't necessary.
Posted on Aug 22, 2009
SOURCE: Why can't you use 8GB memory card in Z710
I have a kodak z710 camera with a 2 gig card in it. I was wanting to get a 4 gig sdhc and i wasn't sure if the HC would work with this camera. HC stands for high capacity which means it allows the camera to load files on to the card faster. this may be the problem the kodak may not be HC compatable. but as i have said i have a 2 gig and it works fine with that. and i have a friend that has a 4 gig in thiers but once again i don't think it is HC so i would exchange the card if you can for just a regular SD/MMC card or SD card
Posted on Jan 21, 2010
t00nz
  • 4738 Answers
SOURCE: Have a Kodak EasyShare C743, bought a SanDisk, won't format
Your camera was designed before the SDHC format came out. Sorry, your camera can only use standard SD cards, those usually 2GB or less. An SDHC card will not be recognized properly by your camera. If you really want to use a 4GB card, do a Google search for SD and "non hc", with the non hc in quotes. Believe that Transcend makes one.
Posted on Apr 25, 2010
What is all the types of memory cards for a Kodak EasyShare c142
the lack of replies suggests you'd be better off putting a memory card into anything else other than a Kodak easyshare..... just look on here at the amount of Kodak & easyshare problems there are....... but for the record, "GOOGLE" mentions 32GB works fine and class 4 or over.
Jan 01, 2014 | Kodak EasyShare C613 Digital Camera
My kodak easyshare V803 camera will not read memery card old or new says unuseable
if it's not reading old or new you might have to format the memory card on your computer first... all you do is put the memory card in the computer and you go to my computer and look for the drive... if the drive is not there then you will have to go to kodak and look up there driver readers and download it then it should work... also sometimes a camera can only take certain gb so you might have to down size... i hope this helps you out
May 22, 2012 | Kodak EasyShare V803 Digital Camera
I have akodak esey share camery that has interenel memery that is full and want take any more pitchers no c182 what can i do
The internal memory of a camera is very small and is only for taking some test pictures when you first get the camera. For regular picture taking, you need a memory card.
Apr 26, 2011 | Kodak EasyShare Z612 Digital Camera
I just bought a new memory card-4 gb SD-K046. It says that the memory card is full but it is not. I have only used this memory card to scan pictures. I uploaded these pictures onto my camera and deleted...
The following information lists the type and maximum storage capacity of the memory card that each type of camera accepts.
EASYSHARE CX-, DX-, LS-Series Cameras accept:
DX3500, DX3600, DX3900: CF memory cards up to 1 GB
LS755: xD memory cards only
All other CX, DX, LS: SD memory cards up to 1 GB
EASYSHARE C-Series Cameras accept:
C300, C310, C315, C330, CD33, CW330, C530, CD40, CD50: SD memory cards up to 1 GB
C340, C360, C433, C503, C533, C603, C633, C643, C663, C703, C743, C875: SD memory cards up to 2 GB
CD43: xD memory cards only
All other C-Series Cameras: SDHC and SDHC UHS-1 memory cards up to 32 GB
EASYSHARE M-Series Cameras accept:
M590, M583, M577 TOUCH, M5370 TOUCH: MicroSD and MicroSDHC memory cards up to 32 GB
All other M-Series Cameras: SD, SDHC, SDHC UHS-1 memory cards up to 32 GB
EASYSHARE P-Series Cameras accept:
P850, P880: SD memory cards up to 2 GB
P712: SD or SDHC memory cards up to 4 GB
EASYSHARE SLICE Digital Camera accepts:
MicroSD and MicroSDHC memory cards up to 32 GB.
EASYSHARE V-Series Cameras accept:
V1233, V1253, V1073, V1273: SDHC, SDHC UHS-1 memory cards up to 32 GB
All other V-Series Cameras: SD memory cards up to 2 GB
EASYSHARE Z-Series Cameras accept:
Z610, Z650, Z700, Z710, Z730, Z740, Z760, Z7590: SD memory cards up to 2 GB
All other Z-Series Cameras, including MAX: SDHC and SDHC UHS-1 memory cards up to 32 GB
FUNSAVER FD-Series Cameras accept:
SD and SDHC memory cards up to 32 GB
EASYSHARE ONE Camera accepts:
SD and SDHC memory cards up to 1 GB
Notes:
Most KODAK Digital Cameras are compatible with SD, SD/MMC, and/or SDHC memory cards.
Most current KODAK Digital Cameras are compatible with SDHC UHS-1 memory cards.
All KODAK Digital Cameras that are compatible with SDHC and SDHC UHS-1 memory cards use cards with Speed Class up to Class 10.
MicroSD and MicroSDHC cards with SD adapters can also be used in cameras that use SD or SDHC cards if the storage capacity criteria above is followed.
KODAK Digital Cameras are not compatible with SDXC memory cards.
reference: http://www.kodak.com/global/mul/service/index.html?reqURL=http://support.en.kodak.com/app/home/src/gosupport
http://support.en.kodak.com/app/answers/list/p/2/selected/true
Phone Number for Kodak is:
800-235-6325
or try get human below for more info on support:
http://gethuman.com/phone-number/Kodak/
Jun 11, 2010 | Computers & Internet
How do i change internal memory to card memory. the camera seems to bestuck on internal memory mode.
Menu, Camera Settings, Internal Memory has to be changed to AUTO.
The camera can only detact the memery card if in the camera otherwise it will automaticly go back to internal memory.
M1033 Memory card support : SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
Pls. rate me good if you find my advice useful
Nov 24, 2009 | Kodak EasyShare M1033 Digital Camera
Memery card protected.How do you reset switch on memory card..there is no switch
All memory cards have a TINY switch along the one side. It locks the card.
Oct 18, 2009 | Kodak EasyShare C310 Digital Camera
Kodak M1033 does not recognize memory card
  1. Turn camera on
  2. Push the options/settings button (the button next to the view/playback button)
  3. On the Capture Screen move over to "Setup"
  4. Move down to "Image Storage" and make sure its set to "Auto" {if not select it and set it to Auto}
  5. If already set to Auto, change to Internal Memory.
  6. Power off and power back on then follow steps 1-4 to set back to Auto.
If this still doesn't work, backup pictures from internal memory to computer then delete all pictures on internal memery. Camera should automatically prompt you to change to memory card.
Mar 26, 2009 | Kodak EasyShare M1033 Digital Camera
New memory card says memory card full
The following memory cards are compatible with your Kodak EasyShare C330 Every memory card we offer is manufactured to the highest standard and carries a 2 year minimum warranty.Your Kodak EasyShare C330 accepts SD Card cards.The largest SD Card card you can use in your Kodak EasyShare C330 is 1GB
Jul 29, 2008 | Kodak EasyShare C330 Digital Camera
Help with kodak M753 camera and memory card!
If you format the card, the pictures are gone leaving you with a blank memory card.
Format the card in your camera, then load it up in your computer and see if the cycle goes away.
Once you get a picture on the memory card and in your computer, keep an eye on the memory specs reporting on the computer and see if there is anything unusual. I've heard of a few defective cards but its rare.
Jun 21, 2008 | Kodak Easyshare M753 Digital Camera
Memory card problems
take the memery card out, blow inside, & put it back in. it shouldwork.
Mar 19, 2007 | Kodak EasyShare V550 Digital Camera
Kodak EasyShare LS755 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
