Question about The Toys
My egofly helicopter wont start up. the propellers move then stop.
    Top Expert:
  • The Master
  • 77,939 Answers
Battery issue most likely.
Posted on Dec 29, 2016
When I start my helicopter the propeller moves but stalls, what could be the reason for that?
If you engage the helicopter and the propeller moves but stalls, feel the starter solenoid and the battery. If they are cold the battery is most likely bad but if they are not there could be a problem with corrosion in the electrical system.
Sep 10, 2012 | Champion Sport & Outdoor - Others
On my rc volitaion remote on the top the gauge what dose it mean when it flashs
It's in a safety start up mode so there is no accidental start up of the helicopter
while holding model in your hands to turn it on or plug battery in. When ready to fly move throttle
gimble to full up then back down to stop. Light should then stop blinking and the
next time you move throttle gimble up the helicopter rotors should begin to turn.
Oct 06, 2011 | xheli 9053 Outdoor Volitation Metal...
I recently got a DH-1 AeroQuest Mini Helicopter. It was working fine until I crashed it against the wall. So now the top Propeller spins but the bottom propeller does not and the helicopter just spins...
I had the same problem. Bottom blade would not spin. There are 2 shafts that spin 2 gears. The outer shaft that spins the bottom blade has 2 set screws and my set screws got sheered off. I replaced both set screws and everything works now....
Sep 04, 2011 | Toys
My rc heli wont go up
Are you missing any parts? make sure its charged, i know if you are missing a stabilizer it wont go up the stabilizer is what holds the two propellers together and when the helicopter takes a hard impact it usually comes off so check for that hoped this helped
Feb 12, 2011 | xheli 3 Channel Alloy Falcon Aluminum RC...
I just got the new s032g . i can't stabilize itand it's lookl ike no gyros installed. when it's come up it's start to move forward. any help? thanks, Erez
Make sure that when you turn it on, you place it on a stable and LEVEL surface until gyroscopes sync up and internal red light (not red/blue flasher in nose) stops blinking. This sets level heading for helicopter. If gyroscopes sync when craft is not level it will be trying to correct and will move forward or backward. If helicopter is level and blinking red light inside stops blinking after powering on and it still moves and wont hover. Then you have a defective board and I would return it to retailer and ask for replacement.
Hope this helps, let me know
Jan 23, 2011 | SYMA Toys industrial Syma S032 Ready to...
I cHarged the helicopter and can get the directional Propeller to spin but cAnnot get the main throttle proPellers to spin. Help
try to play around with the trimmer.. i had the same problem but then guessed it was the trimmer and iwas right!
Dec 25, 2010 | JCPenney Gyropter RC Helicopter
My helicopter wont fly the main propellers on top of the helicopter stopped working
either stripped the main gear inside the heli or the main blades where they slide on the shaft. you should be able to buy a replacement set of blades. try that and see if it'll fly.
Apr 01, 2010 | Air Hogs Havoc Heli Helicopters
The two bottem blades on my ocean rescue helicopter wont spin
There are several reasons for this
1. Is it fully charged
2. Make it go with the romote and move the propelers by your hand (DONT LET GO OF THE ROMOTE) if it moves and tiy bit then stops there is a problem with the motor.
3. Go to the mechanics
Mar 19, 2010 | Toys
Heli max hicro helicopter just keeps spinning in circles
Spinning is caused by one of the main propellers rotating faster than the other. If both propellers are secured tightly to their drive shafts, the spin control knob on the remote control can be used to stop the spin. However, if one prop is slipping with respect to the other, the spin control knob will not fix the problem.
I've found that the set screws holding the propellers to the drive shafts tend to loosen after a while. If one prop is a bit loose and the other is tight, the relative slippage will cause the helicopter to spin.
To check, turn off helicopter power and manually rotate each propeller separately, watching the nylon gears in the body. If the propeller is moving and its drive shaft gear isn't, the propeller is slipping because its set screws are not applying enough pressure on the propeller's drive shaft.
Carefully tighten the set screw and the problem should be fixed. DON'T OVERTIGHTEN, or the plastic threads for the set screw will be stripped and the propeller assembly will be ruined.
Apr 10, 2009 | Max Heli- Axe CX Micro Electric Rc Mini...
Toys Logo
Top The Toys Experts
Paul Carew
Lawrence Oravetz
Are you a The Toy Expert? Answer questions, earn points and help others
