Question about JVC Televison & Video
Hello my jvc d series projection TV when i turn it on it only stays of for a second or 2 then turns off how do i fix it?
mistersony
  • 320 Answers
SOURCE: Hitachi rear projection lcd lp500 series
It is likely the projection lamp is weak, causing the picture to cycle on and off. Take the lamp out and examine the reflector. If it is dull and cloudy, it's time to replace the lamp. A new lamp will have a reflector that is shiny and looks like a mirror. Be sure to rate this solution. Thanks!
Posted on Nov 08, 2008
karthik1989
  • 46 Answers
SOURCE: JVC AV48P575 projection TV turns on then turns off
you need to change your trigger circuit
Posted on Apr 05, 2009
dsacco86
  • 1077 Answers
SOURCE: New TV 9 mos old, Won't stay on after power up? Remote or manual turn on, set keeps turning off after 1-2 second green on and brief screen flash.
I would try leaving the TV unplugged for 30mins so the TV can reset itself.
If that doesn't work, your TV should still be under warranty. I know 95% of come with a 1 year warranty.
The most common problem with Sylvania TVs made by FUNAI, the Backlight Inverter board fails to early in life. ( That's the part that powers the screen)
The Tv can't power up the screen and it turns off automatically. Basically called "Protection Mode" so it protects the other parts inside the TV.
Posted on Jun 01, 2009
welcomejee
  • 10594 Answers
SOURCE: Tv turns off randomly but turns on after 35 seconds.
How old is this TV and when did you replaced lamp last time?
Posted on Jun 09, 2009
  • 257 Answers
SOURCE: I have a JVC LT-42X579 TV. I got home tonight and
This is common problem of the failure of power supply board inside TV. You need technician to figure out this problem.
Posted on Aug 13, 2009
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Jan 18, 2016 | JVC Televison & Video
"Fan lock"
Use the below link to locate ur nearest service centers ...
its an hard ware cognitive factor u alone cant rectify it ..
http://maps.jvc.com/cAscList/index.asp
Dec 23, 2007 | JVC HD-56FN97 56" Television
Tip
To Clear Green Screen Problem
Here are the proceedures for taking care of this problem:
1) Turn on TV
2) Make sure the remote toggle switches are set to "TV" and "VCR" respectively
3) Press the "Sleep" button
4) Simultaneously press "Display" and "Video Status"
5) Press "2" (Self Check)
6) Turn off the TV
7) Wait for fan to turn off (30 seconds or so)
8) Unplug TV
9) Wait for 30 seconds
10) Turn TV back on
Hope this helps
on Feb 21, 2008 | JVC HD-56G886 56" Rear Projection HDTV
Set turns on then turns off a few seconds later
Set have the tv projection lamp problems.Tv have a "LAMP"LED light indication on the tv front screen panel are flashing are staying on lite?Yes,than the tv projection lamp life are ending.Tv have been on and used like 4 or 5 hours a day and the tv projection lamp been on the tv like a 1 1/2 or 2 years?If it is a new tv projection lamp,than ur tv might have a problem with a board call a Ballast board.This Ballast board job are to help to ignite the tv projection lamp.
Dec 06, 2010 | JVC HD-61FH96 61" Rear Projection HDTV
My tv will not turn on and the on timer light is
Try the following blog. It has detailed instructions on how to fix a common problem on this JVC TV series. I did and I fixed my TV for 2 bucks at home.
Good Luck...Kim
http://brentlavelle.blogspot.com/2007/12/i-fixed-my-jvc-av-36980.html
Jan 14, 2010 | JVC AV-36950 TV
Please help!!! Problem with JVC DLP TV
You need to replace the power supply board. The new ones have a bigger heat sink - obviously JVC knows about the problem because they made the new ones bigger. It cost $250 from JVC and I installed it myself - took about 3 hours to do. If you are not tech savvy call a repairman. Hope this helps.
Feb 03, 2009 | JVC HD-52G786 52" Rear Projection HDTV
How old is your TV?
Lamps in DLP TV has specific working hours and physically lamp will look good but won't give light ( actually consume more current and protection circuit stops power supply)
Thank you.
Dec 04, 2008 | JVC HD-52G786 52" Rear Projection HDTV
Tv troubleshooting
I have a 61" JVC that just stoped working. I turn it on and nothing bu the blue light stays on and the red light blinks 8 times and then the blue light joins in.
Oct 30, 2008 | JVC HD-61Z575 61" Rear Projection...
Horizontal Lines
The unit most likely has a short in the horizontal section and would require repair by a service center. Go here to find a JVC repair center in your area http://maps.jvc.com/cAscList/
Sep 18, 2006 | JVC AV-56WP74 56" Rear Projection...
Televison & Video Logo
27 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
