Question about JVC HD-52Z575 52" Rear Projection HDTV-Ready Television
Lamp says lamp needs to be replaced.does this mean the lamp is going?tv still works as of right now!
  • WildTwinkie May 01, 2008
    The TV works like it always has but the message to "replace the lamp and reset the timer" comes on about 30 secs after I turn on the TV. I've never replaced the lamp before. So does the message mean that the lamp is going to go out? Do I need to order a new one now, and is it something I can fix? Thanks for your help!
  • 934 Answers
It means the counter hours have been reached... Is it possible that you've had the lamp replaced once before and didn't reset the counter??
Posted on Nov 21, 2007
I was given this model tv. The green and red lights on the front are flashing. Says to replace bulb and close lamp cover correctly. I am missing the lamp cover. Is that going to be a problem?
U mean the Lamp door cover?Yes?Tv might work,might not.Don't know never tries to turn the tv on before without a Lamp door cover close before.There is a blue safety switch though must be press down when the Lamp door cover is close.Test it out.Why don't u just take a piece of tape and tape that blue safety switch down tightly,than turn on the tv.If the tv message that said close lamp cover correctly disappear.Than yes the tv will work,without the lamp cover closed.Now u just needed to do a replacement of the tv projection lamp only that all.
Sep 24, 2011 | Toshiba 62HM95 62" HDTV
When you turn of the TV the POWER indicator flashes green for several minutes. The TV never comes on. After the several minutes of the POWER indicator flashing green, it stops, I hear a click and the...
A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
May 11, 2011 | Panasonic PT-52LCX66 Projection Television
TV won't turn on - the front blue power light and red lamp light blink. Does this mean the lamp needs to be replaced?
Yes.The tv projection lamp inside the tv right now it is been inside the tv like a 1 1/2 or 2 years already.The tv been on daily and in used like 4 or 5 hrs tv watching daily?Yes,than the tv projection lamp life are ending and the causes.
May 08, 2011 | JVC HD-52G886 52" Rear Projection HDTV
My tv turns on, but there is no picture. The two green lights and one red light are flashing on the button in front. What do I do?
That means that the lamp may be defective and the TV needs service. You can replace the lamp yourself. The code is on the right side of the TV and on the lamp case. Get a replacement using this code from the store where you bought the TV or a Samsung Service Center.
Once you have the correct lamp (the wrong one may damage your TV), make sure your TV has been off for at least 30 minutes (cool down). The cool down will not happen properly if the TV is plugged into anything other than a wall outlet.
Open the lamp case and take out the old lamp and replace with the new one. Do not touch the glass with your hands and do not insert any objects into the case. Do not leave the old lamp near flammable objects or where children can access it.
I hope this helps.
Apr 13, 2010 | Samsung HLS4266 TV
Says lamp problems
Without more information it is going to be hard to help you. I assume you mean the TV has a warning of lamp problems. Means you need to replace the lamp. Go to and put in your sets information. You should be able to find the lamp you need. Get it. Your owners manual should tell you how to replace or at least where the lamp housing is. Open the housing, remove the old lamp, install the new lamp, close properly and you should be good to go. Let me know how it works out.
Jan 31, 2010 | Panasonic PT-50LC13 50" Rear Projection...
My panasonic LCD TV's lamp light is flcikering.
Sounds like the lamp. Turn the TV off, unplug the TV from wall, wait for half hour. Remove the lamp and see, if it is fogy looking, this will give you an idea if the lamp is going bad.
Good luck
N Sabre
Nov 08, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Need to understand what to order. TV will not go
Actually you need just the lamp, I mean you can get the housing also, but it's not necessary. WIth the lmap itself you'll be just fine. It's not hard to change, there's this page where they have video guides of how to replace them.
Jul 30, 2009 | Sony Televison & Video
Blue spots
its the lamp problem that needs replacent.if replacing the lamp does not solve the problem.its also the light engine problem on beside which the lamp is seated.but if lught engine is faulty it has to be replaced the engine cannot be instead of replacing the light engine go for new liught engine replacement means the tv can face any other major problem soonso first replace the lamp and check out.
Apr 02, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony KDF-E50A12U TV Swith on ok, after about 30 seconds the tv goes into standby mode, green power light on with 3 rapid red flashing lights. Any assistance appreciated
red light flashing means it can't dectect lamp housing. you can try and take it out (door on side of TV to the right hand side) and reinsert. But it probably means your lamp has blown. Replacement xl-2400 lamp is east to replace. Search ebay to buy one (about £100) and youtube has a video showing how to do it.
Dec 22, 2008 | Televison & Video
JVC HD-52Z575 52" Rear Projection HDTV-Ready Television Logo
158 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
