What does e01 mean on my ninja cooking system and can i fix problrem
I have an ninja 4 in 1 cooker. it comes up with an eo1 message. what can i do?
  1. The thermostat may temporarily lose calibration due to temperature changes resulting in an E01 error message on the display. Repeat the following steps to reset the unit.
  2. 1. Unplug the unit from the wall socket for approximately 10 seconds.
  3. 2. Plug the unit back into the wall socket.
  4. 3. Press the POWER button once. Within one second, press the COOK button once. The unit should now be reset
or Cooking pot is not inside the cooking system housing. Insert the cooking pot.
Search Results
SOLVED: When I turn it on I get E01 - Fixya
www.fixya.com/support/t305866-when_turn_get_e01 Dec 19, 2007 - When I turn it on I get E01 When I turn on power it is giving me E01. ... I had the same E01 error code. .... How to fix on a ninja crockpot e01. According to the manual it means the cooking pot is not inserted into the device.
ninja cooking system e01 error Questions & Answers (with Pictures ...
www.fixya.com > Forum > Tags Find solutions to your ninja cooking system e01 error question. ... ...fix error code eo1 and err i getting an error code eo1 and err and it not cooking For one, you ...
SOLVED: How to fix on a ninja crockpot e01 - Fixya
www.fixya.com/support/t17203774-fix_ninja_crockpot_e01 Mar 19, 2013 - how to fix on a ninja crockpot e01 - NINJA SEARious Slow Cooker question. ... According to the manual it means the cooking pot is not inside of the device. Same thing happened to ours .... you can use it. Here is a tip that will tell you how to fix the EO1 error code. ... ninja cooking system e01 e01. Feb 07 ...
Ninja cooking system e01 - Fixya
www.fixya.com/support/t23385060-ninja_cooking_system_e01 Feb 7, 2014 - ninja cooking system e01 e01 - NINJA SEARious Slow Cooker ... I have an E01 error code on my West Bend slow cooker, how do I fix it?
[PDF]3-in-1 Cooking System - The Home Depot
www.homedepot.com/catalog/.../3f/3f5a04f4-303f-482a-a702-eeb5ecab0bdb.pdf In the event of a loss of power, an error .... The Ninja® 3-in-1 Cooking System Steam Oven offers a revolutionary new way to cook your .... "E01" Appears on the.
ninja 4 in 1 cooker eo1 error - Google Search
Apr 02, 2017 | Kitchen Appliances - Others
What does e01 mean on ninja 3 in one cooking system
EO1" occurs when the unit is still on but the pot has been removed from the cooking housing system. Place the pot back in the cooking unit.
This can also occur for the following reasons:
-if there is food jammed in the gap between the disc and the surrounding heating plate (the blade circle).
-if there is food stuck to the bottom of the pot.
-if there is food stuck on the heating plate (yes even a grain of rice can be a problem!)
-there is mechanical damage to the unit (disc is defective for instance).
-if the handles on the pot got bent down (so the pot is not fully seated on the heating plate and disc does not get pressed)
-debris or other damage preventing the pot from make full contact with the heating plate.
A good tip is to plug in the unit and turned to any mode. Please be sure the unit is completely dry. Use your finger to fully press on the disc and see if EO1 goes way. If pressing down does not clear EO1, then unit is defective.
If EO1 does clear by finger but does not clear when pot is installed - and bottom of pot, heating element and gap between the disk and heating plate are clear, then the unit is defective.
Dec 29, 2016 | Washing Machines
How do you fix error code eo1 and err
For one, you have a multi-cooker, it is not a pressure cooker. Try posting your question in the Slow Cooker category.
Oct 03, 2014 | Euro-Pro Ninja 3-in-1 Cooking System
Kawasaki ninja zx7 wiring diagram
When you say it keeps doing the same thing do you mean the wires keep burning, sounds as though you need to be finding a new wiring loom am sorry, if you carry on riding the bike you will eventually cook all of your expensive charging/and ignition components rendering the bike as scrap
May 20, 2013 | Motorcycles
Mar 19, 2013 | NINJA SEARious Slow Cooker
Bosch Nexxt Washer Error Code E01
means that the computer is seeing the door as opened even though it may be closed, you can fix this by following this guide:
Bosch Front Load Washer Error E01
Dec 01, 2012 | Bosch Nexxt Premium WFMC6400UC Front Load...
Got carl lewis treadmill MOT566 IT SHOWING ERROR CODE E01 WHAT DOES THIS MEAN
1) this means a) problem with the speed sensor b) main motor problem c) main motor board faulty. see the block diagram attached.
God bless you
Jun 24, 2012 | Exercise & Fitness
E01 Error
The rice cooker lid has to be closed and the dial knob has to be in the lock position (turing on the pressure lamp) before cooking can start. There are two tiny wires sending signal to the main controller to indicate that the cooker is in lock position. The wires are vey tiny and they can break over the years as a result of opening and closing the lid many times. When these wires are broken, the main controller cannot detect the lock position and will give E01 Error.
Feb 02, 2009 | Panasonic SR-PRA18N 10-Cup Rice Cooker
Dec 19, 2007 | West Bend 84496 6-Quart Slow Cooker
Washing Machines Logo
98 people viewed this question
Top Washing Machines Experts
