Question about Winter Sports
I have a 87 340 yamaha entecer it will ilde no problem but when tring to drive it, it strats to bog & just quits when hot? what could be the problem?
This motor has the elec start on it too, cleaned carb, new plugs, ckecked fuel filter clean
  • 682 Answers
Check the compression on the engine, maybe losing compression?
Posted on Jan 03, 2017
What would cuz gas to shoot out of my exhaust on my 85 Yamaha virago 750
Timing, plugs or plug leads faulty, be careful of fire on hot pipes.
May 30, 2013 | Yamaha Motorcycles
I have a 2003 yamaha yz 85 . I have doin everything i can think of to try to get it to quit bogging ,I have put a new top end rebuilt carb put a new silencer change the fuel mix to 32.1 36.1 & 40.1...
Hi, Crazycowboy1 and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
Dirt Rider Magazine
YZ85 cutting out at WOT Yamaha 2 Stroke
YAMAHA YZ85 Owner Manual
OEM parts for Yamaha
YAMAHA YZ85 LC Owner Service Manual
Mar 23, 2013 | 2005 Yamaha yZ 85
Off idle bog slow roll on
Hi, Anonymous for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
YZ250F Throttle Response Trouble WR YZ 250F
Yamaha yz250f bog off idle
YAMAHA YZ250F Owner Service Manual
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Sep 09, 2012 | 2004 Yamaha YZ 250 F
My '94 yamaha waverunner 3 runs great for the first 30 minutes. After that it will run fine at idle and just above but the rest of the throttle it just bogs, like it is running out of gas or has some kind...
Could be a bad temp sensor. The bog is a rev limiter to keep engine from running full throtle when hot or when there is another problem. You can bypass the temp sensor and see if that takes care of problem. The parts about 100.00. I disconnected mine a now run a temp gauge which I mounted on the right side just above oil gauge.
May 31, 2010 | Yamaha 12V Air Pump
Throttle bog out
hi,this may help,check the inline fuel filter and the air filter,if it has been sitting that long the fuel filter may have gummed up(a slightly gummy residue left behind after fuel evaporates) the engine will run ok at low and medium throttle but the filter will be quite restrictive once the load goes on,change the filter and clean the air filter and you might find the problem disappears...hope this helps...cheers
Jul 28, 2009 | 2001 Yamaha WR 426 F
Bogging out
The TPS after installed must be adjusted and that is a delicate procedure so you better take it to a dealer's workshop.You should also check the fuel pump if it works properly.
Jun 01, 2009 | 2000 Yamaha YZF-R6
Winter Sports Logo
718 people viewed this question
Top Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Winter Sport Expert? Answer questions, earn points and help others
