Question about Acer Tablets & eReaders
Acer Iconia One 10 B3-A20 tablet, faint blue screen, no icons, android OS.
brimknows
  • 10 Answers
SOURCE: my android tablet is "frozen". Will turn on but
has anything been deleted from it when it has been plugged into a computer or has anything been deleted from the device itself from its root directory? if not and its gone like that by itself, it could be corrupted software or a missing root file which is usually bad at first, now what i know about some tablets is if it wont work theres a recovery file usually internally but this is in some tablets only that ive read about, i also have one but havent needed to try to restore it and it can be done from an engineering mode, this is possable by pressing the power button and another button like the home button at the same time once the unit is off untill it turns back on with options, but as for some models im not sure of but i will have to look this up at some stage as i am working on tablets at this time so unless you know what you are doing i wouldnt attempt it, once i have gotten through some tablets ill be able to give a better resolution on this subject with others. the advice ive given wont work for all as pressing power and home will start different options up on different tablets and versions.
Posted on Oct 26, 2011
  • 99 Answers
SOURCE: HP tablet OS is android
As far as I knew hp was running windows on it's tablet line.
Posted on Oct 13, 2010
em_br_dj3
SOURCE: I HAVE A PANDIGITALSTAR ANDROID TABLET WHEN I TURN IT ON IT STAYS ON THE WHITE SCREEN AND SAYS PANDIGITAL WITH THE BLUE DESIGN BUT I HAVE NO ICONS AND WHEN I PRESS THE BUTTONS AT THE BOTTOM NOTHING HA
had same problem. I figured it out. While pressing the home key on the bottom of the tablet, press the on/off button until a black screen appears with green words on the side, which says upgrading...please wait...wait. It should take you to the Pandigital screen with a small bar underneath it with green going across. It should work.
Posted on Jan 18, 2012
  • 339 Answers
SOURCE: have a 10 magni tablet model SYTAB10ST screen shows sorry! the process android.process.acore has stopped unexpectedly please try again . it has a force close tab on screen but the error still pop up t
this means that the program you were running has crashed. If it happens everytime you launch a particular application then I would advise removing the program from the tablet and then reloading it
Posted on Dec 20, 2012
scamper_69
  • 11 Answers
SOURCE: Android tablet stays in Android screen
Try to do a hard reset on the tablet. Since you cannot get to the menu options, you are going to have to do it through external keys. Here is how to do a hard reset using the external keys:
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the manufacturer logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up)
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections
6. Use the volume buttons to move up and down through selection in this menu
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option
9. Scroll down to select "Yes, delete all user data"
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Posted on Feb 27, 2013
Acer b3-a20 tablet keeps crashing to black screen
IF this on battery power only ~ suspect the battery. IF you have AC/Charger connected ~ ALSO suspect a faulty battery!
Anthony
Feb 10, 2018 | Acer Tablets & eReaders
How do I get the Gallery icon back on my Acer 7inch tablet?
Go to the list of apps, and select Gallery icon and drag it on to the desktop.
My list of apps is a circle with six dots in it.
Sep 17, 2014 | Acer Iconia TAB A100-07U08U 7-inch Android...
How do i take a screenshot on an acer tablet
I'm not certain, but I believe that is a function of the Android OS. Mine has an icon which takes a screenshot... and I often do, even when I do not want to. I found nothing about screenshot in the Acer manual, so I am not sure how you can make this a function. The manual is at:
http://www.cellphones.ca/upload/manuals/acer-iconia-a3-manual.pdf I hope that perhaps this can help steer you in the right direction.
Mar 28, 2014 | Acer Iconia A3-A10 10.1" Android Tablet -...
Acer iconia a700 tablet
Hi there if you follow this link http://www.acertabletforum.com/forum/rescue-squad-guides/5168-how-perform-factory-reset.html It will walk you through the reset process :)
Jan 26, 2014 | Tablets & eReaders
Will not power up
Connect your tab to computer and do a firmware reset, in android term reinstall the rom.
Jan 09, 2014 | Acer Iconia A100 Android
NEED SCREEN UNLOCK CODE FOR ACER ICONIA 200 TABLET
Well, the only way to unlock your tablet is to factory reset tablet.
To reset tablet start the tablet, then hold volume up then select factory reset.
Sep 15, 2013 | Acer Iconia Tab A200-10g16u XE.H8QPN.001...
My acer iconia android tablet refuses to startup
Perform a Factory Data Reset of Acer ICONIA
The following steps will erase all of your personal information, all stored contacts and any programs you have installed on your tablet.1.Power off the tablet.
2.Press and hold the Volume up button, which is located closest to the touch screen lock switch.
3.With the Volume up button held, press and hold the Power button for 3 seconds then release it. Continue holding the Volume up button.
4.Once the tablet vibrates, switch the touch screen lock switch on and off repeatedly while still holding the Volume up button.
5.Release the Volume up button and stop switching the touch screen lock switch once the "Erasing Userdata..." message appears in the upper left corner of the screen.
6.Once the factory reset has been completed your tablet will load to the Welcome screen. 7.Your Factory Data Reset has completed now follow the onscreen steps to setup your tablet.
Aug 24, 2013 | Acer ICONIA Tab W500PC52G03iss
Acer tab A200
You may have to perform a reset if your tablet fails to respond when buttons are pressed or the screen is tapped. To reset your tablet use a small thin object (such as a paperclip) to press the recessed reset button.
Or do Clean Boot to restore the Acer Iconia Tab A501 factory default settings.
  • Open Settings from the application menu, then tap Privacy > Factory data reset.
  • Click Reset tablet and then Erase everything to format your tablet.
Jun 29, 2012 | Acer Iconia Tab A200-10g16u XE.H8QPN.001...
Tablets & eReaders Logo
82 people viewed this question
Top Acer Tablets & eReaders Experts
Nicola Conroy
Are you an Acer Tablet and eReader Expert? Answer questions, earn points and help others
