Question about RCA Audio Players & Recorders
RCA 5 disc audio shelf system has power but won't turn off
  • yadayada
    yadayada Dec 29, 2016
    Hi Brenda Brewer, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
shaggyrat
  • 1224 Answers
SOURCE: Bought a display model RCA RS2657 5-Disc CD Changer Bookshelf Audio System
order from remotes plus or order from rca themselves
if system is aloted a universal remote should be able to control the system with little or no hasle
Posted on May 09, 2008
  • 135 Answers
SOURCE: We purchased a used RCA
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
manual
Posted on Jan 18, 2009
  • 4234 Answers
SOURCE: Describe your RCA Audio Shelf System Problem
If you have cleaned the CD lens using a cotton swab and alcohol and it continues to skip, try cleaning the rails that the optics assembly rides on using a clean cotton swab. Sometimes the grease on the rail gets contaminated with dust and that causes the optics assembly to stick a bit. The motor that moves the optics assembly will generate more torque and when the optics finally move, they overshoot the target position. This results in a loss of information that you hear as a skip.
If neither suggestion works, please update this and we'll try another option.
Thanks,
Dan
Posted on Dec 30, 2009
  • 961 Answers
SOURCE: It is an RCA 5
http://support.rcaaudiovideo.com/manual.aspx?product=110
This is a link where you should be able to get an owners/users manual.
Posted on Mar 08, 2011
Slinteriors
  • 8617 Answers
SOURCE: My "50" RCA Scenium won't
That's usually caused by a bad lamp. However that chassis is famous for having bad caps on the power board. The repair kit is available at the following link and has repair instructions included. http://servicemanuals.vstore.ca/product_info.php/pName/rca-atc336-dlp-power-board-repair-kit/cName/repair-kits
Posted on Aug 16, 2011
My RCA audio system shelf does not power on. I changed outlet and check for a defective fuse but to no avail. Any suggestion? It's a RCA 300WATTS 5 DISC AUDIO SYSTEM RS2767I
Could be an internal fuse in the power supply area. Follow the mains cable. However the fuse blowing could be the sign of a fault. If it blows straight away again there is a fault.
Jan 01, 2017 | RCA Audio Players & Recorders
The cd trays on my rs2130i rca 5 disc audio system will not open. I can hear the motor turning when I plug in system but no tray will open.
be prepared to pay thru the nose to get fixed My panasonic did that and it was over 100.00 to get fixed and it lasted 2 more months it is a shelf item now
Jul 19, 2015 | RCA RS2130i Shelf System
A CD is stuck in disc 3 of my 5 disc changer. How do I get it out?
Disassembly may be required to get access to the stuck disc and remove it.
Mar 16, 2015 | RCA RS2664 Shelf System
Disc compartment will not open
Stretched rubber powered opening mechanism.Change the rubber.
Dec 08, 2013 | RCA RS2041 Neo-5 CD Changer Audio System...
RCA Shelf System 1285 manual
Retrevo has the manual here: http://www.retrevo.com/support/RCA-RS1285-manual/id/402ci676/t/2/ . You will need to enter a code to download the pdf.
I hope this helps.
Jun 14, 2011 | RCA RS1285 CD Shelf System
My 5 disc rca changer is not reading the disc, every time it say reading and then it say there is no disc.
Try to clean laser lens with CD cleaning disc. If it not helps, then Your lens must to be replaced.
Sep 06, 2009 | RCA RS2652 Shelf System
RCA RS 1285 5 disk audio system won t show or play
When you turn on the unit the cd draw seams to open. I hear it making a noise like if it is trying to get ready to play. When you shut the draw it won't play, change tracts, or the disc thing to put in more disc wont work. Someone please help me
May 01, 2009 | RCA Audio Players & Recorders
No audio at all and buzz in the speaker output.
sounds like an input device switch is frozen or locked up?? try unplugging for overnight and taking any clock or battys out of the unit as well.
Dec 23, 2005 | RCA RS2620 80-Watt 5-Disc Shelf System...
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
