Question about Nokia 5320 XpressMusic Cellular Phone
Set up fix dial - Nokia 5320 XpressMusic Cellular Phone
  • Nokia Master
  • 805 Answers
For set up fix dial u need pin2 code. press that and active that
Posted on Jul 21, 2009
Getting a new password for my voicemail.
It sounds like the voicemail system isn't recognizing your phone, have you updated the IMEI with Verizon?
May 05, 2017 | LG Cell Phones
Do you have any volt,amp meters, that can tell where I can set the governor to? These dials are fixed to the generator. Hum...
No gauges can set the governor . The governor controls the engine at a set speed, as the load on the generator varies so does the engine speed ,the governor tries to keep the engine speed constant.
Oct 29, 2014 | Coleman Powermate Premium Plus 6250W...
How do I reset a 4 dial Samsonite combination lock
Hello sstacy1,
You can follow the steps below to fix your problem on how to reset your 4 dial Samsonite combination lock:
  1. Set the dials to 0-0-0. Find the lever or button next to the dials.
  2. 2If your lock has a lever, lower it and turn the dials to the desired numbers. Return the lever to its starting position.
  3. 3For locks with a button, push the button towards the dials and turn them to the desired numbers. Release the button.
  4. 4The lock is now set to the new combination.
Read more: How to Reset Samsonite Luggage Combination Locks ' eHow.comhttp://www.ehow.com/how_4761466_reset-samsonite-luggage-combination-locks.html#ixzz157Q4Ap
Hopefully it helps.
Thank you for using fixya
Sep 08, 2011 | Health & Beauty
How to disable or cancel the speed dial in nokia 1100 mobile set especially for no 1 key.
You can't cancel this speed dial, it is fixed for voicemail.
Just go to voicemail number option and remove this number.
Jul 22, 2011 | Nokia 1100
Setting the clock
hello,
simple to fix up your self please follow this instruction below
  1. Pressing the clock button will display the time. You can also use this to know what time it is while cooking.
  2. Step 2 Set the clock by pressing the "Clock" button.
  3. Step 3 Turning the dial on the sensor microwave oven will display the hour of the day. Once you have found the correct hour, press the dial in.
  4. Step 4 Again, turn the dial to set the minutes of the day. When this is completed, you will need to press the dial in again on the sensor microwave oven.
  5. Step 5 When the time and minutes are set, turn the dial again for a.m. or p.m. Then you will need to press the dial in to save the settings.
  6. Step 6 Press the "Start" button to allow the clock to begin on the sensor microwave oven.
thank you for using fixya.
Jul 31, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
My TP100 snare pad is very glitchy. Often when I hit it, it makes no sound at all, or it misses hits. I suspect something is wrong with the small sensitivity dial (not the big red dial), because the...
The dial could have a desoldered pin or oxydized slider contacts. Try to resolder the pins, but if that doesn't solve it then you would need to disassemble and clean the internal slide contacts on the dial which can be a bit difficult, so the alternative is to replace the dial if you can find a spare one.
To bypass the dial (with fixed resistances) you need to know the resistance at each side of the dial when it is in the position that suits your needs (connect the snare to a working input, set the sensitivity as needed, mark the position of the dial).
The resistance can be measured with an ohm meter.
To be sure that the measuring will be accurate, it is ok to remove the dial from the circuit board (adjacent components may affect the measured value).
You should do the measuring on a dial that is good.
After you've removed the dial, set it to the position that you marked previously.
Measure the resistance between left and middle pin of the dial - this will be the value of the fixed resistor which you need to connect to the left and middle hole on the circuit board.
Now measure the resistance between middle and right pin on the dial - this will be the value of the fixed resistor which will be connected to the middle and right hole on the circuit board.
Now you need to get resistors which have the values that you've measured and solder them in place of a bad dial.
It is likely that the measured value will differ from the standard fixed resistor values. To achieve the exact measured value, you can connect two or more fixed resistors in series, just make sure that the added value of the fixed resistors for each side is the same as the measured value on each side of the dial.
Now you need to solder the fixed resistors to the circuit board and the modification is complete.
If you actually decide to do this modification and you're unsure about anything, just post me some feedback, i'll be glad to help.
Anyway, hopefully it is just a desoldered pin that you need to reflux.
Regards,
Triarcuate
Oct 10, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
Setting time and date
From the manual:
1. Press the MENU button to open the menu.
2. Turn the SET dial to select [SYSTEM] and press the
SET dial.
3. Turn the SET dial to select [T.ZONE/DST] and press
the SET dial.
4. Turn the SET dial to select the setting option that represents your time zone and press the SET dial. To adjust for daylight saving time, select the time zone with the * next to the area.
5. Turn the SET dial to select [D/TIME SET] and press
the SET dial. The year display starts to flash.
6. Turn the SET dial to select the year, and press the
SET dial.
• The next part of the display starts flashing.
• Set the month, day, hours and minutes in the same way.
7. Press the MENU button to close the menu and to
start the clock.
Jan 15, 2009 | Canon Video Cameras
How to set up speed dial?
Here is the link to your phone user manual. Please see page 2 for setting up speed dial:
http://service.us.panasonic.com/OPERMANPDF/KXT7720.pdf
Please don’t forget to rate the solution as Fixya if it helped you in any way, or leads you to a fix.
Thank you for using FixYa!
IrishDruid
May 21, 2008 | Panasonic KX-T7736 Corded Phone (KXT7736)
No dial tone
and does your line to your computer have one of the filters installed going to your modem line?
check your computers warranty here 4 FREE
Mar 18, 2008 | Symantec WinFax Pro 10.0 for PC
Dial-up: Internet Connection
do your pc have a dial-up modem card?
What's the brand? Go to download the latest driver for the modem and try and see.
If not, right click on my computer icon, go to hardware tab, select "device manage", see does it detect any modem driver or not.
If after installing the driver still the same and can't be detected, most properly your modem is going to "heaven".....
Try to change another modem, see whether it can work or not.
Dec 14, 2007 | Computers & Internet
Nokia 5320 XpressMusic Cellular Phone Logo
149 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
