Question about Seiko Watches
Bought a Seiko 6N42 for my husband.We cannot get it to start.We've shaken it and the hands will not move.We were given a manual for a 5 so we're not sure these instructions work for his 6.Can U help
  • Seiko Master
  • 19,083 Answers
Take it to a jeweller, it sounds like it needs a new battery. $6 to $8 whilst you wait.
No point shaking it as it OUGHT to be electric quartz movement.
Posted on Dec 29, 2016
Testimonial: "Thanks! We will do that tomorrow for sure."
  • Andrew Taylor
    Andrew Taylor Dec 29, 2016
    My pleasure. I have one, they are a great watch.
How to set alarm on seiko chronograph sports 100
pull the crown out to the first click press the reset chronograph button until the hands on the small alarm dial start to move.set the alarm time press the crown back!
Jan 15, 2010 | Watches
I have a seiko chronograph sports 150 watch; had the battery changed a few day ago and just noticed that the second hand & stopwatch hands are not 'centered'. is ther a way to reset this ? cheers
As jimmyguru said.
1. Pull the crown to the second position (all the way out)
2. Push and hold the reset button and allow the chronograph hand to rotate near the 12 o'clock position.
3. Release the reset button.
4. Repeatedly push and release the reset button to find tune the hand position until it is right at 12 o'clock.
5. Push the crown back in.
Nov 05, 2009 | Seiko SNA553 Alarm Chronograph
My watch constantly stops
check for automatic winding offcentre disc clutch mechanisum fault
Aug 24, 2009 | Seiko Watch SNXJ89K1
I have not worn my SEIKO kinetic wrist watch for a
Here is the information from the website. The link to the manual is provided below. HOW TO CHARGE AND START THE WATCH Swing the watch from side to side approximately 50 times. * Before swinging the watch, check and remember where the minute hand is so that you can tell if the start-up indicator has worked or not. First, check that the crown is at the normal position. * If the crown is pulled out and the watch is swung, the start-up indicator will not work even if the watch starts operating. * Swing rhythmically at a rate of twice a second. * No additional benefit is obtained by swinging the watch more quickly or with greater vigor. * When the watch is swung, the oscillating weight in the generating system rotates to drive the mechanism. As it rotates, it gives out a sound, which is not a malfunction. 1 2 The minute hand moves quickly and stops as the watch starts operating. (Start-up indicator) Then, it will move at 20-second intervals. 3 After checking that the minute hand has done this, pull out the crown to set the time. 4 After pushing back the crown in to the normal position, swing the watch further approximately 350 times to reserve one day of power, and then, put the watch on your wrist. http://www.seikowatches.com/support/ib/pdf/1m20_e.pdf Good luck, Techjoel
Jun 05, 2009 | Seiko Kinetic watch
My seiko orange monster gains about 5 min every 30 min
dont do anything!the watch needs service.perhaps somehow the watch fallen in a hard surface and something moved or broke in the balance wheel.the hairspring the pallet or the wheel have serious damage.to have your watch healthy wateresistance and accurate try to find a seiko authorized service center to repair your watch!
Apr 15, 2009 | Seiko 100m Diving Watch SKX033K2 Watch
Can't set Seiko Yacht Timer Sports 150
Turn knob to set on "Match" Pull out crown knob. Press both buttons for 3 seconds. When you release both buttons it will beep and both hands start moving. Press either button to stop movement. Then press the top button to set the minute hand to 12 oclock. Press the bottom button to set hours to 12. Press in crown and turn to "Time" Pull out crown and set time the same way.
Mar 01, 2009 | Seiko Le Grand Sport SDWF73 Wrist Watch
Seiko SNA413P1 second hand not on 0 exactly
It is probably the way the second hand was placed onto the watch when the watch was put together. The hand will only move in a set interval so if it's "off" you cannot fix it unless you have someone take the watch apart. I would not worry about it being a fake because honestly Sekio watches are not expensive enough to fake. Here's a good rule of thumb, if the watch cost under $1000 then it is probably not going to be something that people will make a counterfeit model of. Finding a "fake" Seiko, Citize, Bulova, or any mid-level watch is not likely.
Jan 02, 2009 | Seiko SNA413 Wrist Watch
How to adjust alarms
moz-screenshot.jpgSetting the alarm:
1. Pull the crown to the 2nd "click" (the possition you adjust the time) (Carefull: The seconds hand has to be on "12")
2. Press repeatedly button "B" to set ALARM hands to the time indicated by the main time hands (The ALARM hands move quickly if button B is kept pressed)
3. Push the crown to normal possition
4. Pull the crown to the 1st "click".
5. Press repeatedly button "B" to set the desired alarm time. (The ALARM hands move quickly if button B is kept pressed)
6. Push back the crown in to normal position.
At the designated time the alarm rings for 20 seconds, and it is automatically disengaged as it stops. To stop it manually, press button A or B.
Oct 15, 2008 | Seiko Le Grand Sport SDWF73 Wrist Watch
Seiko chronograph alarm
Solution #3 (Posted by Guest on 5 Mar 08) is spot on. Quick and easy method to reset the chrono hands (it was not in my Seiko manual).
Interestingly, this can also be used to set the chrono ahead (or behind--with a little math) for offset timing measurements.
Jan 13, 2008 | Seiko SNA553 Alarm Chronograph
Watches Logo
55 people viewed this question
Top Seiko Watches Experts
Jerry Greenberg
Jerry Greenberg
just-ice
Are you a Seiko Watch Expert? Answer questions, earn points and help others
