I have a 50 in model #DP50741. You can hearvthe static but when connected no tv shows. Anyvideas?
  • yadayada
    yadayada Dec 29, 2016
    What is the source of the TV signal? Antenna? Satellite? what?
3 Suggested Answers
  • 7 Answers
SOURCE: I need a repair manual for a Sanyo tv model
Go on sanyos website and download the manual
Posted on Oct 31, 2014
  • 9783 Answers
SOURCE: Sanyo 50 tv DP50741 speakers quit working
Make sure your audio setup hasn't changed. You can select where the audio goes in setup. If everything is correct, then the main board needs to be replaced. You can get it here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Posted on Dec 06, 2016
Dec 05, 2016 | Sanyo Dp50741
Have LG plasma tv model 50PG20 static on audio all the time.
If you wish to get advice over phone; visit https://www.6ya.com/
It's an absolutely free service, and so many experts are online. a 24hour/365day service.
Nov 22, 2016 | LG 50PG20 50 in. Plasma HDTV
Sanyo DP50741 50" Plasma TV - After a power failure audio no longer works on any input however video is fine. What is the likely issue/component?
Are you speaking of audio through the TV speakers or through your sound system? If through your TV speakers , I would go into menu and make sure speakers are set to ON or TV. Settings can sometimes be reset or changed due to spikes or surges. Recheck all settings to eliminate the obvious. If everything is fine then it's possible an electronic component such as an IC is blown. This would not be very expensive to fix. Hope this helps.
Oct 01, 2015 | Sanyo Televison & Video
I need a repair manual for a Sanyo tv model dp50741 j4jf
Oct 30, 2014 | Televison & Video
Lost 50 in.tv audio
Check audio connections if it is an external source and also check other input sources like a DVD player to see if the audio comes from that. If you never get any audio it could be a power supply issue or a amplifier that has broken solder joints on the board. I have had to repair many wave soldered boards over the last 40 years due to little solder on the component leads and then some parts that handle power or get hot develop what is called a thermal break in the soldering that connects the component lead. If it is not a bad setting or cable into the display device then you might need to consult a Technician.
Aug 10, 2012 | Sanyo Dp50741
Model # F32649- TV has static, no picture no
RESOLDER LOOSE CONNECTION IN THE TUNER OR YOU NEED TO REPLACE THE TUNER
Aug 23, 2009 | Televison & Video
Picture becomes fuzzy in different areas of the screen
sounds like a splitter problem try replacing splitters
Mar 24, 2009 | LG 50PX5D 50 in. Plasma HDTV
When I turn on the TV the screen has static
Static usually means that the tuner is not working. Chack all of your cable connections first. As a quick test of the tuner itself, remove the cable from the exterior antenna connection and insert a small paper clip. That will act like an antenna and if you scan for channels, something should be seen. If not, then you probably have a bad tuner or have lost the source power for the tuner.
Dan
May 07, 2008 | Toshiba 50H81 50" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
