Question about Samsung Televison & Video
Samsung plazma tv will not turn on, makes loud popping noise when it tries. It started this several days ago but when it did go on the picture was fine. Can this be fixed at home?
No noise other than the pop.
    Top Expert:
  • Samsung Master
  • 78,010 Answers
Do you have electronic test gear and the knowledge required to diagnose these types of products?? Can it be fixed is a very broad question. If the answer is no sure or no then have it repaired (expensive) or replace the TV.
Posted on Dec 29, 2016
Loud noise then lose picture
The green power LED probably is merely indicating that power is getting to your TV but the internal power supply is failing as evidenced by the loud "pop".
Dec 31, 2013 | Vizio P50HDTV20A 50 in. Plasma HDTV
Samsung HLS5086WX/XAA made popping noise and shut off, then made whirring noise.
When my TV did this in the past it ended up being the color wheel. I had someone replace it and it worked fine. I asked it if had to be calibrated after it is installed and he said no. Also make sure the door switch is pushed down when you install the back bulb door. Sometimes this switch can go bad as well.
Jan 10, 2013 | Samsung HLS5086WX/XAA
I have Samsung DLP TV 50 inch HL-P5063W
First thing to look at is the color wheel this model uses--usually it will make a high pitched fan like sound but can make a grinding sound also.
If it slows down from the 12,000 or so RPM speed it will cause color issues.
Apr 02, 2012 | Samsung Televison & Video
My Samsung's picture is starting to fade and all the colors are turning a reddish color. Does this mean I need to change the lamp? I just did that about 6mos ago. What now?
with TV on bring up the menu. If the menu screen is NOT affected, the DMD board should be fine. It menu is affected, DMD board is likely the reason.
Also check the color wheel, sometimes when they are going bad they will translate the wrong colors or even make a loud pop and shut TV down. If the bearing is going bad on color wheel, it can make a grinding/squealing kind of noises and sometimes even make the TV vibrate.
Im not a TV specialist. Just trying to help with what I have experienced with this set.
Feb 27, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
Picture went out on p50hdm Vizio Plazma tv after loud POP
It's either the backlight lamp or backlight inverter is busted due to a power failure or fluctuation. Here's how to determine which is which:
  1. Grab a flashlight.
  2. Turn on the TV.
  3. Shine the flashlight onto the screen.
  4. If you cannot see any display even a faint one, the backlight inverter is dead, else the backlight lamps are busted.
  5. Replace which ever is the culprit.
Sep 26, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
3 loud pops and picture faded away
ours was off all day and it pop 2 times and now no picture at all.
Jun 01, 2008 | Zenith Z50PX2D 50 in. Plasma HDTV
Making Loud noises
Got the same problem with my second TX-S3082WH Slimfit...the first had the same was deemed unrepairable and I was advised to return it to Circuit a year and five months later Samsung support has been less than helpful as I am 5 months out of warranty...don't know what I'm going to do...any advice would be appreciated
Dec 02, 2007 | Samsung TXR3079 TV
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
