Question about Kenmore 72059 Air Conditioner
10000 BTU Fedders. Thermostat set to 66. Only cools to 73.
It's a nice unit and more than enough for my wife's 200 sq foot flower work shed. But it needs to be cooler in the room for the flowers and the compressor kicks off when it's 73 even though the digital thermostat is set at 66 (as low as it will go). If I slide the filter out, I can get 2 more degrees out of it, which is telling me that the unit is not sensing the room temperature properly.
Can I correct this by finding and re-locating the thermostat sensor? Is it a capillary bulb?
Is there a way to adjust (lower) the bottom setting of the temperature control?
  • christoph60 Jul 23, 2009
    Insulate the bulb! As Larry would say, "Why didn't I think of that"... or was it Moe?
    Anyway... BRILLIANT!!! I can't wait to try it! (My wife says, "I've got a wedding this weekend... you're not fooling with the A/C now!")
    Many Thanks, 2rns4u!!
  • 22 Answers
Dear friend If you have a capillary bulb on the the front of the A/C you can trick it. You can experiment with masking tape covering the bulb thereby insulating making the unit think that it has not satisfied the temp requirement. It is not easy to move the tstat on a window unit as I am sure that you have figured out by now. I hope this helps, 2rns4u <*{{{>(
Posted on Jul 23, 2009
  • 614 Answers
Just move the Tsat. But you have a chance of icing the unit if you are not careful. Good luck. Russ
Posted on Jul 22, 2009
I have a Maytag window unit and i am trying to find out how many btu is has. right now it is in a small room and i want to know if it will work in a bigger size room. MODEL M6Q1OF2A SERIAL CR 264327...
that is a 10000 btu unit and a good rule of thumb to go by when 'sizing' a unit is 12000 btu for every 600 sq ft of cooling space (if the place is well insulated) or 400 sq ft (if not well insulated).
So, you have a 10000 btu unit which is 5/6th of 12000 btu - so - can reasonably expect that unit to cool approximately 500 sq feet.
In other words the room it's in now could be only - say - 300 sq feet (and well insulated) - in which case the AC unit is cooling it - well.
However, if you try to cool a 800 sq ft room - it will not work as well.
Hope this has helped.
Aug 05, 2011 | Maytag M6Q10F2A Air Conditioner
Not cooling room
Assuming the unit is 'cooling' but not cooling it 'well,' I would think the unit is too small.
NOTE: 2000 Btu for every 100 sq ft of cooling space if the room is well insulated. If not - then 2000 btu for every 66 sq ft.
For example - a 12000 btu AC unit should cool 600 sq feet of cooling space if well insulated.
or
400 sq feet if not well insulated.
hope this has helped.
Aug 05, 2011 | Danby DPAC12031 Air Conditioner
It is 106 degrees outside, I have a a/c unit which is cooling at 75 degrees in a 1180 square foot townhouse apartment, this seems like the unit is doing all it can with the excessive heat, is it
Unfortunately, 7000 Btu's will not cool 1180 sq ft. At best, it's rated for 400 sq ft, as it's only rated as a "Room Air Conditioner". To cool 1180 square feet, you'll need at least 30,000 Btu's (like in Central Air Conditioning) or 4 more window units spread out throughout the condo. It takes more Btu's to cool, than it does to heat.
I really sorry. I wish I had better news for you. Thanks for choosing FixYa.
Aug 02, 2011 | LG Heat cool Window Air Conditioner
My landlord installed this brand new out of the box. Our apt is 900 sq ft tops. This unit can't even cool down our living room and kitchen. If the whole 2 bedroom apt is 900 sq ft, you can imagine how...
The AC your landlord installed is rated at 8000 btu which is way too small for 900 sq ft. You need at least a 15000 Btu Air conditioner and a 'well insulated' house to be cool.
A good rule of thumb in the AC business says you need 1 ton (12000 btu) of Air conditioning for every 600 sq feet (if the house is well insulated) - if not - then you will need 1 ton (12000 btu) for every 400 sq feet.
So, if you have 900 sq feet and the house is well insulated you should have at least a 15000 btu unit.
If it's not well insulated you will need 24,000 btu.
Jun 07, 2011 | Maytag M6X08F2D Air Conditioner
How many BTU's does model AEJ12E7AG have?
Ronnie,
You have 12000 BTU/Hr Cooling and 10000 BTU/Hr Heating
Tim
May 29, 2011 | Fedders AEJ12E7AG Air Conditioner
230V FEDDERS I HAVE 110V AND 20AMPS COMBINE HOW MANY AMPS DOES 230V NEEDS
I give simple formula to determine amps:
I (amps or current) =watts/volts.
And with above formula,you can calculate volts and watts too.
Helpful?
Jan 05, 2011 | Friedrich X-Star XQ10L10 20" Air...
Hitachi Madris ac console
Hitachi is a good brand, I wouldn't be afraid of it.
As to the size, it seems a little 'oversized' for the room you're talking about.
24x12 = 288 sq ft. As a general rule you need 12000 btu for every 600 sq ft.
I'm thinking between 6000 -10000 btu ought to be big enough.
Lots of things go into sizing, and the size of the room is important - but the 'heat load,' needs to be considered too. For example - will there be a lot of people in this room, or is there a lot of windows, is there electrical equipment in this room that will be putting off heat, and how well is it insulated? So you need to consider all of these things when deciding what size unit to buy.
For example - if this room is a bedroom and used primarily for sleeping - I wouldn't be afraid to put a 6000 btu unit in it - but if it was going to be used as a place with tv's, computers and other electrical equipment I might want to put a 10000 btu (or larger) in it.
Good Luck!
Generally speaking, it sounds like 18000 btu is too much AC here, and there's no reason to spend more money than you need to and you can 'oversize' just as easy as you can 'undersize' when it comes to Air Condtioning.
May 05, 2010 | Heating & Cooling
I need an idea of square foot coverage
There are more factors than sq ft. You have to factor in window surface and R factor of insulation.
Aug 18, 2009 | Heating & Cooling
Need the BTU rating for an old Kenmore K948991 a/c
Your model number is not complete enough for a model check.
However, 18,000 btu in todays' units is what you need.
Mar 28, 2009 | Kenmore Heating & Cooling
Kenmore 72059 Air Conditioner Logo
356 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
