I have my cable box hooked up to my tv has been for 4 years all of a sudden the tv remote wont work & the cable box remote only turns the cable box on it will not turn the tv on or work the volume
    Top Expert:
  • Televison & ... Master
  • 77,932 Answers
Replace the remote first, if that fails to correct the fault then other repairs are indicated
Posted on Dec 29, 2016
Can't turn off the closed captioning
I had the same problem. Okay, First get the TV remote. not a cable box remote. Next, switch the input to an Analog input. (TV or input one if you have the RC red, white and yellow hook up. or, just hook up the coax cable straight to the TV..
Now, use the TV remote to operate the closed caption. It will work like it should.\
Briefly, closed caption works on the TV with a straight hook up to the TV. It will not work with a cable box.
Good LUCk
Aug 21, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Suddenly my yamaha Rx-v2300 only works to provide sound at nearly full volume to get any sound at all. This then comes with a background buzz. This only occurs while getting cable TV signal, using other...
I'm assuming you have a cable converter box (set-top box) that you have hooked to your receiver. Check the box volume using the cable company's remote control. These boxes frequently have variable audio output, and if you turn the volume down on the box you'll have the symptom you're describing. When you press the volume up or down buttons on the remote, you'll usually see a volume bar on the TV screen. As you raise the volume, there may be a point marked by an arrow, which is where you should set the volume. On some boxes, when you get to a certain level the words "best stereo" appear, and that's where to set it. If your box doesn't have some indication like this just leave the volume set 3/4 or full up. Then the volume on the receiver should function properly with the cable TV input.
Jan 12, 2011 | Audio Players & Recorders
Hitachi DV-PF 2U dvd player works fine when hooked directy to TV (channel 3) but won't work when connected through the new COX digital cable box. TV is set to channel 4, dvd player turned on, disc...
If the cable box needs to be set to 4, the TV will need to be set to 4 as well as the dvd player. The hookup should be cable box to dvd player to the TV for your system to work. Let me know if you have any other questions. Thanks.
Dec 30, 2010 | Hitachi DVD / VCR Combo
Samsung LCD TV ''Weak or No Signal''
try swicth cable box for testing....if sam problem..need replaced tv main board
Jan 01, 2010 | Samsung LN32A330 32 in. LCD TV
We have a combination TV/DVD player made by Bush. Model number DVD1401TV which has suddenly gone completely dead. Can't do anything with it at all. Won't turn on, doesn't make any noise. I have checked the...
the remote will not change channels..i have a 15'coby flat screen which was hooked up with a cable box..the cable remote changed that i put this t.v. in my daughters room without the cable box we cannot change channels on it...the remote it came with does not work..and a universal will not work..the universal works on all t.v's in the house except that one..
Oct 02, 2009 | Televison & Video
LCD TV is hooked thru cable box. When you use the
Try this (may not work):
1. UNPLUG power from TV at wall outlet.
2. Turn ON the TV (with no power cable plugged in).
3. Plug power cable back in (at wall outlet)
4. Turn ON TV (don't use remote this time).
Hope this works!
Sep 03, 2009 | Televison & Video
Video 4 not working properly
9 out of 10 times, the problem is the device that is hooked up to the TV, and not the TV itself. This is especially true in the case of cable boxes, which have a long history of failures.
Temporarily, you can probably hook up the composite (yellow red and white) cables to get a picture and sound on a different input.
You can try to hook up a DVD player on the inputs (component, I'm guessing) and it will probably work. Then you get to call the cable company!
Hope this helps...
Jan 09, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Closed captioning wont turn off
Go to the local Walmart and buy a generic controller and program it to your set. Go to MENU and follow the prompts. The remote will be less than 20 bucks, and you will have a remote that handles the TV, the VCR, the DVD, and the cable box. We go through roughly ten remotes a year. They all make the closed caption go away. One tip: don't lose the manual, or you will need to buy another remote. If the batteries fall out, or go dead, the remote will have to be reprogrammed. Underline the code numbers that work.The black box goes away when the info button on the remote is pressed.
Aug 25, 2008 | JVC AV-27D302 27" TV
Orion tv model 1934 only 3, 4 and aux no pic or sound!!!!!!!!!!!!!
Turn the set on, hook the cable directly to the TV, take the remote control and press 1 - 1 and if the TV tunes in channel 11 then your set is fine. If the TV was autoprogrammed when hooked to a cable box then the only channels that will be stored in memory are 3, maybe 4 and AUX. To correct this simply go back into the menu and look for the "autoprogram" option and perform the autoprogram while the cable is directly connected to the TV, without a cable box.
Jul 29, 2007 | Orion1934 19" TV
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
