Question about Sears Drills
Removing chuck from a sears & roebuck model 113.24611 drill press
    Top Expert:
  • Sears Master
  • 75,797 Answers
It is a morris taper wedge fit, so just tap it out.
Posted on Dec 29, 2016
  • Sears Master
  • 14,793 Answers
Most drill presses have the chuck held by a 'Morse taper'. The socket in the drill and the shaft on the chuck are tapered and hold purely because of the fit. To remove, you will see a slot in the side of the shaft that holds the chuck. You insert a tapered bar and tap it gently and the chuck will drop out.
Lost the chuck for my master force 12" drill press where to get replacement part
[PDF]12" Drill Press - Menards
https://www.menards.com/main/store/...Tech.../240-0064.pdf
Menards12. REMOVE ADJUSTMENT TOOLS. Always make sure all adjustment tools are removed from ... Should any part of the drill press be missing, damaged, or any electrical component fail to ...... Use only MasterForce™ replacement parts. Use of ...
MasterForce 12" Drill Press Repair Questions, Solutions and ...
www.fixya.com > Forum > Drill Presses > MasterForce
Free expert DIY tips, support, troubleshooting help & repair advice for all Drill ... Lost the chuck for my master force 12" drill press where to get replacement part.
Lost the chuck for my master force 12" drill press where to ...
www.fixya.com/.../t23651560-lost_chuck_master_force_12_drill_press
Feb 24, 2014 - Lost the chuck for my master force 12" drill press where to get replacement part Where to get spare parts - MasterForce 12" Drill Press question.
Drill Press Parts & Coring Drill Parts ' Tool Parts Direct
Feb 24, 2014 | MasterForce 12" Drill Press
113.24520 chuck replacement
most drill press chucks are installed and locked on by a male / female taper fit. Tap chuck assy. downward with a soft hammer to remove. install new chuck tapping it upward.
Oct 28, 2013 | Craftsman sears 15" 1/2 Heavy Duty Drill...
How do you remove the drill chuck on a vintage delta 14 inch drill press model dp-220
Thread Changing chuck on older Delta drill press This site speaks on the subject of changing chucks. It may be helpful. Also if you search;' how to remove a jacobs chuck from a delta drill press' , you should get several hits I hope this info is helpful....
Oct 17, 2013 | Delta Woodworking Drills
Removing chuck from Sears 8
Ours was a press on,I used a wedge between the chuck and the shaft housing.Couple of hits and it came right off.It's a tapered shaft,we used a dead blow hammer to tap the new one back on.Haven't had a problem sense!
Jan 12, 2010 | Garden
How to remove chuck from drill press
I just looked at a breakdown for this tool and it is not that clear. But to get an owners manual you can go to Searspartsdirect.com and type in your model number and look at the same schematici I did and also order a manual for about 7.50. Usually though on a drill press like that it would be a morse taper. Do you see a slot cut thru the spindle on both sides, if so there should be a tapered key that came with the unit. In that case what you would need to do it put the key in the slot and tap it with a hammer to remove the adaptor and chuck. Let me know if I can help further
Jan 02, 2009 | Drills
Drills Logo
164 people viewed this question
Top Sears Drills Experts
AZBen
AZBen
Andrew Taylor
Andrew Taylor
Are you a Sears Drill Expert? Answer questions, earn points and help others
