Question about GE Hardware & Accessories
How to set my GE digital timer model number 3151831
    Master:
  • 504 Answers
Get an owners manual on the internet.
Posted on Mar 09, 2017
SOURCE: My GE 7-Day Digital Timer model 15086 flashes on
I just bought one today and installed it. It does the same thing - flashes the lights off and on. After some research on the net, it seems that the problem is that an old house is wired with two pole wiring and the new fixtures, (timers included) are 3 pole. The conclusion I have found is that it will not work in a 2 pole wired house. There supposedlly are timers available for 2 pole wiring. I hope this helps. If you find out anything different, please let me know.
Posted on Oct 19, 2009
SOURCE: how do I set the ge timer model #15119. husband
I tried to pull the whole dial and doing that I discovered that the border of the dial is composed by pins that you can pull it up each independently, with your nail or with any pointing device. The rest is easy: get sure the switch is set at "timer on", turn the dial to the current time using the black triangle mark and pull the pin up in the time you want your device to disconnect.
Posted on Dec 21, 2009
SOURCE: GE digital timer model 15086 doe not work
This timer requires a neutral wire, it may or may not be present in the back of your box as a group of wire nutted whites. It is NOT the single white switch leg.
Posted on May 27, 2010
SOURCE: ge digital timer how do i set
http://www.jascoproducts.com
select support and enter the model number (15079) in the search field. the manual is downloadable. One thing the manual does not make clear is that the two plugs in this timer cannot be set independently of each other. Whatever two devices you plug in will go on and off at the same programmed setting.
Posted on Oct 04, 2010
SOURCE: Can GE Digital Timer model 15086 be used for two way switch?
GE 15086 can replace single pole switch only.
If you have "3-way" switch, that is when 2 switches control same light, for example in a hallway.
Open link below to identify GE15086 timer, see wiring instructions, on-line manual <> and see list of timers that can be used for 3-way switching with links to those timers and manuals:
http://waterheatertimer.org/GE-timers-and-manuals.html#15086
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Jan 27, 2011
How do I set Intertek 3151831 timer?
Try Googling (Intertek)(3151831)(manual) without parens.
Jan 15, 2018 | Hardware & Accessories
I have a Intertek 3151831 timer and need to know how to set it
Nov 30, 2017 | Hardware & Accessories
Set clock on ge profile gas range
Didn't give a model number, but try the following:
For a mechanical clock, push the center knob in and turn the clock hands to the correct time. (If the Minute Timer pointer should move also, let the knob out, turn the Timer pointer to OFF.)
For a digital clock, push in the center knob of the Minute Timer and turn Knob in either direction to set the Digital Clock numerals to the correct time.
For an electronic clock, touch the Clock pad. Touch the number pad. Touch the start pad until the time of day shows in the display. Note: On double wall ovens, you can only set the Timer for one oven.
(From the GE website)
Nov 06, 2016 | GE Kitchen Ranges
Set the hour on clock on GE electric stove
I need a model 15440, GE heavy duty digital timer manual
I do not recognize that timer model number.
The only place the model number appears is on link to fixya... indicating that the model number does not correspond to known product, or that some seller has renamed a timer so his product cannot be comparison-shopped.
Re-post question and attach photo
Most GE manuals appear on following link: open link to find same-similar timer
Gene
Water Heater Timers Save Money
Mar 13, 2015 | GE Hardware & Accessories
GE plug in mechanical timer model 15417
Copy following links to identify timer and setting analog timer by experimenting with features.
GE timers change appearance as model numbers are upgraded, but all 24-hour analog timers have same basic features.
http://waterheatertimer.org/GE-timers-and-manuals.html#15119
http://waterheatertimer.org/How-to-set-timers.html
Sep 23, 2012 | General Electric Ge 24-hour Mechanical...
Ge smart timer-won't work after I changed off/time-no voltage to light
Hello Terry. Which GE digital timer do you have?
Copy following link to identify timer, and download manual.
Reset timer using reset button.
If timer has no voltage, then check outlet.
Check circuit breaker.
Check that light bulb is good.
If timer is plug-in type, then test outlet with circuit analyzer. Try timer in different outlet with different light.
Re-post question with timer model number, and things you have tried so far.
Jul 15, 2012 | Hardware & Accessories
Manual needed
You can download your manual from the following site as a pdf file. It lists as an install guide but has the set up information. You may need to do a search using your model number.
http://www.jascoproducts.com/support/timer-quick-start-guide.asp
May 29, 2010 | Jasco Ge 7 Day Digital Timer 1 Outlet...
Hardware & Accessories Logo
375 people viewed this question
Top GE Hardware & Accessories Experts
George Nalley
Level 1 Expert
Paul Bade
Gene Haynes
Are you a GE Hardware and Accessory Expert? Answer questions, earn points and help others
