Question about Kenmore Kitchen Ranges
Kenmore C970-440725 one of the top burner is not warking, is that a fuse not working , where is the fuse box, or it had no fuse box, and fuse to replace it.
    Top Expert:
  • Kenmore Master
  • 12,962 Answers
The burner element is open and needs replacement.
Posted on Dec 29, 2016
My Kenmore oven won't come on but the top burners will
If the top burner is working sounds like the heating element in the oven has gone bad. I don't know if you know how to use a volt meter but you can test to see if there is voltage at the element connections. Should be 220 volts. If you have voltage there you have a bad element.
Jan 31, 2015 | Kenmore Kitchen Ranges
Where are the fuses for the Sears Kenmore stove to elements located on Model C880 675080L0
Most likely no fuses. Either the element or the switch that turns it on is bad. If lighat comes on when you turn on burner the switch is probably ok and the burner went bad.
Jan 02, 2015 | Kenmore Sears Electric Range Surface...
Kenmore Electric Range Model #911 9237313-All burners quit at once?
Have you checked your fuse box. The Electric Range is on a separate circuit. Check to see if it is tripped or off.
If it has tripped and you reset it, that usually means there is a problem with the electric range.
Let me know if that helps.
Jan 22, 2012 | Kenmore Kitchen Ranges
Radio and clock not working
ceck the fuse in the fuse box and the fuse on the back of the stereo, conect the sterio direct to the batery if is warking you may have a sort cirkuit.
Dec 17, 2009 | 1997 Ford Escort
Older oven stuck on Clean and door is locked.
does your oven have a lift up top if does. lift up burns and silver box open box and you can unlatch the lock. hope workds
Apr 23, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Jan 29, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
Kenmore Range
Try just unplugging the unit for about 5 minutes. That will reset the clock and hopefully fix the problem. If not you probably need to replace the clock.
Nov 15, 2008 | Kenmore 46564 / 46565 / 465 / 6646569...
Need advice on Kenmore electric range
turning frot burner on sparked and now all 4 burners don't work any more
Jan 03, 2008 | Kitchen Ranges
Kitchen Ranges Logo
46 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
