Question about Cub Cadet Garden
My cub cadet CC30 do not start, it is new, the battery is fully charged, when i try to start do not make a sound ,looks like the power does not go to the start
    Top Expert:
  • Cub Cadet Master
  • 12,962 Answers
Battery connection good, starter connection, ignition switch ok?
Also check the safety switch on the bar that you hold while running unit. If that switch is not working, neither will the mower.
Go direct from the battery to the starter motor - if it runs then the in between circuitry is bogus.
Posted on Dec 29, 2016
My 25 horse power cub cadet mower starts and runs great until you try to mow with it and it has no power. At half speed it mows fair but in heavy grass no power. Any help app. Bill
be sure the battery is fully charged. be sure the blades are sharp. be sure there is no grass or string or wire wrapped around the spindles under the deck. be sure it is firing on both cylinders . be sure the belt is in good shape .
Jul 05, 2017 | Cub Cadet Garden
I have a Cub Cadet LT 10:45 I will try and you try to start it it won't turn like it's stuck or something what could be the problem
take the cover off of the starter and see if it is stuck to the flywheel. if it is not it may be a valve issue. (out of adjustment) assuming that the battery is fully charged.
May 21, 2016 | Cub Cadet Garden
Older cub cadet mower runs fine until blades engaged starts stalling out
Check that the battery is fully charged. If the water is below the top of the plates it needs topped up. If it is old it may not hold enough charge to drive the ignition and the electric clutch. The clutch can draw so much power the ignition falters and so your engine dies. The engine charger may not be able to cope with the draw off when the clutch first comes in.
Sep 28, 2014 | Cub Cadet Garden
Cub cadet mower turns off when I slow down
one more possible check. Make sure the battery is fully charged. Then try it. You might put jumpers from the car on to do a check without doing the battery check. If it runs with the car battery, most likely in battery, or alternator.
Jun 20, 2014 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Cub cadet 2186 wont turn over or even "click"
be sure the blades are disengaged. the brake petal is depressed all the way and you are on the seat. might check the fuse. be sure battery has good connections and is fully charged. could also be the solenoid.
Feb 18, 2018 | Cub Cadet Garden
Cub cadet lt1045
Did you check voltage on the battery, and did you leave it running at a high idle? (low idle can consume battery voltage instead of charging it.
On many tractors the lights do not run unless the motor is running so don't let that throw you off.
Things to check
Make sure no fuses popped.
Makes sure you have gas
Try jumping it to see if it starts If not, it sounds like you may have a short, or may have a safety switch that is acting up. look for loose, broken, damaged wires.
Check to see if any wires are hot when the battery is fully charged. Try that and repost what you do or don't find.
May 07, 2013 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Cub cadet ltx 1045 wont start, no spark.
remove the top cover from the engine and remove the small wire from the coil if still no spark the coil is bad
Aug 07, 2012 | Cub Cadet Garden
Mower has fully charged batt while trying too start it just clicks at the solenoid and then a humming sound but nothing from the starter it self ltx 1042 cub cadet any help would be great thankyou
Sounds like your going to need a new starter. They're not to much you should be able to buy one at your local lawn and garden store, and they're very easy to replace.
Feb 07, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Cub cadet 2140 wont start or turn over
check the cilanoid or the stater , you may also have a lose conaction, try cross jumping the cilanoid
Aug 16, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
270 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
