Question about Compaq Presario Notebook
Weird screen my LG LE50 laptop screen is defective
    Problem Solver:
  • 7 Answers
Re: weird screen
Your description of the problem is even more defective! How about a little more detail people, we're not mind readers!
Posted on Nov 20, 2007
0 characters
3 Points
My lg le50 laptop is nt bringing out sound
Try installing the latest audio driver.
You can download the audio and device drivers for your model LG laptopor desktop from this WEB site.Make sure you select the correct drivers that match theversion of Windows that is installed on your laptop or desktop.
You can download the drivers from this site : -
Apr 22, 2012 | LG PC Laptops
How to install sound driver for lg-le50-fine5
The following link will take you to the sigmatel audio drivers page, I think this is the correct driver for your machine. Choose the correct driver for your operating system, click the download button and follow instructions to install.
Mar 20, 2012 | PC Laptops
I have problem about the screen on my LG laptop. .it looks like a tV monitor that dont have any signal. . IT is "static". .. my eyes really hurt when I am using it. .
if you could open your laptop. here is what you can do, check on the flex or ribbon connector that connects your LCD to the mainboard. Remove it and check to defects or dirt on the terminal. Check also if the connection is not loose.
Jan 14, 2011 | LG PC Laptops
Hi, my laptop model is LE50-FINE5, LG product. My problem is its dvd rom...this few days my dvd driver could read dvd r,dvdrw, cd r, and cd-rw. then the next day i used it, there was a problem, it cannot...
Hi there its a common problem with maximum laptop. Reason is hi speed DVD. CD work but when you run DVD a bad noise is came from the Disk driver, is it? Try to clean the lens & slowly insert the DVD in laptop & then see what happens. If no changes then you need to replace the Disk Driver. Just Let you know I also have the same problem & i am not going to change it , because i know i will face same problem after few months. Thanks.
Nov 18, 2010 | LG X-Note LM50 Notebook
I turn on laptop and only a white screen is displayed
A white screen usually indicates a problem with the video harness connecting the motherboard to the LCD screen, or it can be a problem with the LCD screen being defective itself. You could try to reseat the video harness and see if that helps, as sometimes the connection has just become loose.
If the video works fine (whether in the BIOS/ Safe Mode) on the external monitor then I would not see the video card as being faulty. As you said the graphics seemed "weird" however on the monitor, then try reinstalling the drivers and see if that helps with that issue. If you cannot access the BIOS on your laptop, then it seems likely that either your video harness is faulty (you said the connection was not loose), or the LCD itself is defective. LCDs are expensive to replace, so I'd suggest ruling out other possibilities first.
Nov 10, 2009 | Dell Latitude D600 Notebook
Dell blue screen of death
posting the stop error code and what you are doing when error occurs would be helpful. If you are getting blue screens and have pixelation of video, artifacting or other Video weirdness, then you may have a defective motherboard. If you have video corruption, and the system is in warranty or if the warranty has expired in the past year, contact Dell tech support for a motherboard replacement.
Sep 30, 2009 | Dell XPS M1330 Notebook
Check this out I hope this helps
Jul 03, 2009 | Ashton Digital PC Laptops
I lost the drivers CD of my laptop GE50 of LG. please help me to download it.
Dec 08, 2007 | LG X-Note LM50 Notebook
Compaq Presario Notebook Logo
57 people viewed this question
Top Compaq PC Laptops Experts
John mullen
 Mike M
Mike M
Are you a Compaq PC Laptop Expert? Answer questions, earn points and help others
