When will the remote be available for my days on heater
Need new remote control
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site Check this site too. Universal remote controls are available at most of the electronic spare part selling shops.
Oct 29, 2014 | Lasko 751320 Ceramic Tower Heater Black...
Heater manual
I would contact the manafacturer. They are also available on-line.
Jan 11, 2014 | Water Heaters
What is the use per KW Hr on the Honey well HZ 519-20
This unit uses 1500 Watts (1.5 kW) in one hour at its maximum setting. (12.5 A * 120V AC) The total cost will depend on how long the heater is on each day and the utility charges at the time of use (for example, if you have day/night rates).
The manual is available here: .
I hope this helps.
Apr 04, 2011 | Honeywell HZ519 Baseboard Heater
Water won't get hot, code c2 11
Available between 7AM - 7PM Central Time
7 days a week
Feb 02, 2011 | Rheem Tankless Hot Water Heater...
I am looking for a replacement remote for a Hitachi tv/vcr combo. Model number is 19vr7B. What is the model number of the remote I should be looking for?
The original Hitachi, model UREMT32SR013 remote for your TV, is no longer available but a
suitable replacement is available at the website listed below.
If I have answered your question correctly, please provide some feedback.
Thanks and have a Nice Day!!
Jan 24, 2011 | Hitachi Televison & Video
Cars rpms goes extremely high, have to shut off engine unhook battery to reset computer, remote start, then works ok for a while. I noticed the problem more often if temps out side are extremely cold. ...
The problem you have described do not sound remote start related. A remote start unit does not have the ability to alter the RPM. The remote start system only replicates the process of turning on the ignition, starting the engine and keeping it running for a predetermined length of time.
The heater temperature problem should not be remote starter related either.
As for the day time running lights, although rare, if wired inproperly there is the possibility that the remote starter has caused it to fail. This will have to be determined by a qualified technician.
Jan 23, 2011 | Remote Start System
Just under two year old C-4 76 CODE SOME WATER
the 76 code is a code for the remote control. if you have a remote installed check for loose wiring or it could be a fried remote disconnect it and see if it runs then
Jul 08, 2009 | Rheem Tankless Hot Water Heater...
Some of the remotes that originally came with those units did not work or last very long. The manufacturer then later offered another remote to replace the first units. It looks like the model number you provided is a serial number, not the actual model number. I suggest that you contact Master Parts at 800-446-1446 with your model number (you should be able to find it directly on your unit with the serial number you provided) and they should have that replacement available for purchase. You also can find them on-line at I hope this helps you!
Oct 18, 2008 | Vanguard International Blue Flame - Medium...
Help me
Try Their website says they have a replacement for your original remote model # KKY223 with a model # KKY223A. Call to verify availability. Other sites I have checked state that neither of these is available anymore. In addition, you may want to consider purchasing a generic or universal remote for every day usage to save the factory unit from the day-to-day abuse that all remotes suffer.
If you go shopping for a universal remote, be sure to verify that it specifies that it will work with your particular Konka model. There are a # of people writing to this site looking for remote codes because they didn't verify that the universal remote they purchased would work with their TV.
Feb 25, 2008 | Konka FL2792U 27" TV
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
