Question about Refrigerators
My freezers ice is not forming well and the water leaks when refilling the ice
I'm pretty sure the water leaks only when the ice maker is refilling
    Problem Solver:
  • 12 Answers
The ice petals are on a timed rotation. To turn the water on after the Ice evacuated from the trays and shut it off before the paddles return to its home position. If there is something blocking the rotation it will slow rotation and cause the trade to overfill
Posted on Dec 29, 2016
JSI-26 icemaker leaking water
You're ice maker is located on the left hand side of the freezer, if I'm correct.
Look to the back of the freezer slightly above the ice maker and you will see what they call the fill tube. Chances are ice has formed inside and when the ice maker goes to fill water sprays instead of flows out. In some models you can take the fill tube out from the back by removing two screws that hold it in, located at the upper right side if your behind it, and some you may have to pull out from inside.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 07, 2012 | Kenmore 21.9 cu. ft. Side-By-Side...
Water freezing on floor of freezer and leaking on to floor in front of freezer?
I have narrowed my similar problem (with a KitchenAid) down to a leak in the ice maker refill line. To test if this is your problem also, scrape the ice out, then turn off your ice maker (raise the lever as if it is full) and see if ice no longer forms down at the bottom over the next few days.
Feb 18, 2011 | Jenn-Air JSD2789GES Side by Side...
Ice Maker leaks water inside the freezer
I see you said you looked and the water valve is off but the only that I know of this happening is a defective water control valve. Like a dripping faucet that when off slowly drips until the ice forms and then one the ice maker dumps ice and tries to refill the water goes in every direction. Unplug water valve to confirm what I am saying, Tell me if it continues to leak. Sea Breeze
Apr 19, 2010 | GE 21.7 Cu. Ft. Top-Mount Refrigerator...
Ice maker not freezing the water. teeth still appear to be turning but water only freezing due to cold freezer. water mostly overflowing and forming icicles all over the freezer section. have removed ice...
the freezer is supposed to freeze the water, the icemaker is just the form for the ice and the motor is to free the ice from the form, make sure water supply is cold water and not hot
Oct 10, 2009 | Whirlpool Refrigerators
Ice maker is leaking water into the freezer
There should be a shut off on the copper line .cresent wrench
Nov 24, 2017 | Refrigerators
GE Monogram refrigerator/freezer problem/ice dam in ice maker
I have had the same problem with ice forming. I found the problem is from the ice maker. The water fill tube delivers water to a plastic piece that acts like a funnel. The water goes through this plastic piece into the ice maker. Ice forms in the plastic funnel piece causing the water to overflow into the ice bin and freezer.
Mar 26, 2009 | Refrigerators
Ice maler water leaking
Found that ice had accumulatd in the refill cup that prevented the water from filling the mold so that it spilled over into the frezzer compartment
Mar 25, 2009 | GE Refrigerators
Frigidaire, ice on floor of freexer
check to see if the defrost drain is not frozrn over or stopped up
this is the only way that water can get into the freezer
frost could and melt but dont think that i would check the drain at the bottom of the rear freezer panel if you see ice it is stopped up for sure
if all is clear there go to the ice maker, have had some that are overfilling and runnig over the ice maker into the bottom of the freezer
Jun 23, 2008 | Refrigerators
Leaking water
In back of the refrigerator behind a removable panel you will find a hose going into the drain pan under the refrigerator. Check and make sure there is no obstruction in the hose which would back up water into the freezer. After the drain hose is cleared the freezer should be defrosted and ice cleared from the drain area in the back. You can direct some hot water with some bleach in it through the drain to insure it flows into the pan.
Jun 15, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
