Question about Dryers
I.e. ore Elite Dryer HE4 will not start after cycle is selected and pressed start. Hear a beep and nothing.
Belt looks good, tested door switch, thermal fuse and thermistor...all good.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 19 Answers
At the top there is a computer take it out and then take it out of its white plastic cover look at the board and see if there burn mark on it anywhere
Posted on Jan 01, 2017
Troubleshooting kenmore elite H4 dryer
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ut push start button for continuity with a meter when pushed in the on position, it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Aug 06, 2014 | Kenmore Elite HE4 Electric Dryer
Kenmore elite he5 dryer has no power or start up
If you hear a humming sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings on motor.
Jun 21, 2014 | Kenmore Elite HE4 Electric Dryer
Kenmore elite smartheat quiet pak 9 will not start or power on
Dryer will not start. I hear a click when I push the start button but then nothing
Jun 01, 2014 | Kenmore Elite HE4 Electric Dryer
Why won't my dryer won't start, it just beeps?
May 23, 2014 | Kenmore Elite HE4 Electric Dryer
Why won't my kenmore elite model 110.68062801 turn on?
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
May 21, 2014 | Kenmore Elite HE4 Electric Dryer
I have a Kenmore Elite HE4 smartheat quiet pak 9 that has power but will not start.
Sounds like the belt that turns the drum could be broken. I'd check that first.
Oct 12, 2017 | Kenmore Elite HE4 Electric Dryer
Kenmore elite HE4 dryer 3 rapid beeps when pressing start button
the machine is in lock mode made for children in mind so that they do not touch any cycle while on,, look for lock icon hold 3 seconds and u will hear beep and that its it u r done ,,,,
Oct 20, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer won't run
take a look at your start and door switch
May 24, 2008 | Kenmore Elite HE4 Electric Dryer
HE4 Elite dryer beeps
The Thermal fuse is most likely the problem.
Nov 27, 2007 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
Top Dryers Experts
