I have a BLP155AT propane torpedo heater that won't lite. The fan kicks on and I can hear the box click and then smell gas but the igniter never comes on. Already tried new igniter.
  • 3 Answers
SOURCE: Dyna Glo Pro RMC-KFA70TDGP 70,000 BTU Torpedo heater not igniting
The main circuit board supplies ac power to the ignitor ( black transformer looking device) and the transformer increases the voltage that is supplied to the sparking device. Make sure the wires are connected to the sparking device and the ends of this device are approximately 3mm apart and that it is in the general position near the end of the nozzle. If you do not hear a "clicking" sound it could be the main board, wires or sparking device.
Posted on Dec 17, 2008
godtech
  • 51 Answers
SOURCE: the heater won't stay lit
CHECK YOUR EXHAUST VENT MAKE SURE THAT IT IS NOT PLUGGED OVER HEATING THE UNIT.ALSO IF IT HAS A FLAME SENSE BAR CLEAN IT AND CLEAN ALL SENSOR OFF.AND MAKE SURE ALL WIRE CONNECTIONS ARE PLUGGED IN TIGHT.
Posted on Jan 16, 2009
SOURCE: Century Dyna-Glo Propane Construction Heater, fan stays on?
The heater is designed to continueously run the igniter , so as if there is a flame-out ,it will reignite the burner,and not dispurse unburned gas into your enviroment.
Posted on Jan 17, 2009
clyde2j2
  • 137 Answers
SOURCE: can i convert my dyna glo 75000 btu propane
I'm sure you can, contact the manufacturer and ask if they have a natural gas jet or orfice for your model heater, these are usually very easy to replace.
Posted on Feb 28, 2009
  • 9 Answers
SOURCE: HEATER WAS WORKING FINE TILL I HAD PROPANE TANK TOPPED OFF
The Pressure Regulator may be stuck, Try closing the propane valve releasing the pressure,, gently tap the regulator( on the propane inlet side) and Very Very slowly open the propane tank valve, and attempt to light
Posted on Aug 14, 2009
Master blp155at propane heater. Why does it smell like raw propane and burns your eyes?
Either the heater was installed incorrectly or some element has failed.
Dec 29, 2015 | Heating & Cooling
The hot tub Hester will not light up pilot but does turn on and bow cold air
Glenn,
Many things could be wrong. First off, the exhaust fan turns always goes on when you turn on(up) the thermostat. It does that to suck out any residual gas in the combustion chamber. After about 10 seconds you should hear a click which is the gas valve opening to let the gas into the chamber. You should also hear a series of clicks for about 10 sec, which is the electronic ignition firing. If you hear the clicking of the ignition, but do not smell gas from the exhaust, then the gas feed is being blocked. If you don\'t hear the ignition clicking then the computer board is detecting a fault condition by one of its sensors: over-temp, water flow, exhaust fan . These are all in series and if one doesn\'t pass then the ignition won\'t fire.
Jun 08, 2013 | Pool & Spa
Laars lx won't ignite
hot surface igniter may not be hot enough to ignite the burners
Jan 09, 2013 | Teledyne Laars Laars Lx Pool Heater /...
Gas is on can hear ignition. Doesn't light. May not have gas to heater. Air in line?
Check also to see if the valve on the gas valve itself is in the "ON" position. Is it on or off?
If it is on, then you may in fact have air in the gas line that needs to be purged.
BE CAREFUL WHEN PERFORMING THESE STEPS!! ESPECIALLY IF PROPANE GAS - LPG!!!!!!
Have a large piece of cardboard or the front cover/door of your heater will suffice.
If solid pipe to heater, then there is a union, if you have flexible gas line to heater then you have a flare nut.
With NO flames or sparks even close - NO SMOKING !!!Carefully & slowly loosen either the union or the flare nut with gas valve open. You will hear hissing sound. Leave open for about 30 seconds, until you smell the gas. Carefully & slowly tighten either the union or the flare. Take the cardboard or door, and fan towards the heater to push away and fan away any gas fumes. Do this for about a minute or so. Very Important you do this, again especially if Propane. Propane is a very heavy gas & it will linger in a "Puddle", unseen puddle near the heater. If you did not fan away these fumes, when the heater starts to ignite - .... not so pretty.
Anyway, if you had air in line, heater should fire. If it didn't try above steps one more time. If it still does not fire, possible bad gas valve.
Dec 16, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
York furnace won't ignite
Is the igniter receiving 120 volts after the pressure switch closes? If not, either the board is bad or the pressure switch is open
Nov 27, 2012 | Heating & Cooling
Jul 30, 2009 | Hayward H Series
Jandy Lite 2 does not ignite
burners are plug with spider get a wire and bended get it inside the orifices where the gas come out every single one than try now ? magic heater comes on
Jun 17, 2009 | Jandy Lite2 175,000 Btu Propane Gas...
Jan 11, 2009 | Century Tool 2320I Heater
Heating & Cooling Logo
55 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
