Question about Tablets & eReaders
My Alcatel Pop 7 LTE screen is not showing anything, there is just a little light around the edges.
My Alcatel Pop 7 LTE tablet's screen is not working, it shows light around the edges but an actual picture is not there. It also responds to all buttons but there is just no screen showing up... is there any way I could fix this?
SOURCE: tablet crashed won't do anything
plug it in for 5min.then hold the power button for about a min. I hope it works it did for mine.
Posted on Dec 01, 2012
  • 340 Answers
SOURCE: have a 10 magni tablet model SYTAB10ST screen shows sorry! the process android.process.acore has stopped unexpectedly please try again . it has a force close tab on screen but the error still pop up t
this means that the program you were running has crashed. If it happens everytime you launch a particular application then I would advise removing the program from the tablet and then reloading it
Posted on Dec 20, 2012
  • 183 Answers
SOURCE: I have an Asus Memo Pad HD 7 which I purchased 3
the more programs you install and run in the back ground the more the battery is drained. It comes to a point where there are so many programs running the gadget cannot run & charge at the same time. It might charge better if you uninstall a lot of programs or do a factory reset but that is drastic
Posted on Oct 30, 2013
Testimonial: "I did do a factory reset but the icon is still not showing and it still is slow at recharging. I didn't really have many programs anyway, a few simple card games, crossword puzzles and some weather apps. Right now, I think I have maybe 4 simple apps on the tablet and it is still not charging when on. I checked the battery status in settings and it says "not charging". However, if I turn it off and then plug it in, a red battery indicator shows it as charging."
cougar123
  • 77 Answers
SOURCE: the 7 inch tablet when you turn it on shows the 2 dogs then goes to rca logo and nothing else. tried to reset by holding power & volume button at same time, did not work
contact vendor mfg - shoulds be under warranty
Posted on Jul 11, 2014
SOURCE: How do I fix my proscan tablet
What happens when you hit the internal reset button?
Posted on Jan 19, 2015
A verizon tablet. I don't find or see a model #
Search Results
    Verizon Ellipsis 8 4G LTE Tablet, Black 8-Inch 16GB
    www.amazon.com > ... > Mobile Broadband > Tablets
    Amazon.com, Inc.
    Rating: 2.3 - ‎46 reviews
    Ellipsis 8 Tablet 16GB, Wi-Fi + Verizon 4G LTE, 8in - BlackNetwork Type: CDMA .... After only one charge, I don't find either inferior to other android devices I've used. .... the worst mini tablet possible they would be well advised to model it after this ... Check out these pages to see more: verizon tablet, case eclipse 7, verizon ...
    Verizon Ellipsis 7 4G LTE Tablet, Black 7-Inch 8GB
    Amazon.com, Inc.
    Rating: 2.3 - ‎178 reviews
    See all Open-Box & Preowned offers from Amazon Warehouse Deals. ... Ellipsis 7Tablet 8GB, Wi-Fi + Verizon 4G LTE, 7in - BlackNetwork Type: CDMA ... Learn More; ASIN: B00GJ3MF9Q; Item model number: Ellipsis 7; Average ... it...guess they don'twant people to know the truth about their first foray into the tablet market.
    Verizon Ellipsis 8 Support ' Verizon Wireless
Jan 22, 2016 | Verizon Ellipsis 7 Tablet for Wireless
How does the back of my tablet come off & can the batteries be replaced
for the time , effort , and price of replacement, if it was even available, you would be better served to buy one of the new amazon kindles
Dec 02, 2015 | Tablets & eReaders
How do i fix my nextbook tablet when it has been dropped in water
I hope it was clean water! You should be able to pop the screen off by using a knife on the edge and gently pry all the way around until the screen comes loose, then dry out. Whenever anything electronic is soaked in water, the first thing one should do is disconnect the battery; too late now, but perhaps it will not hurt. If power is connected, electrolysis takes place which can ruin the circuit board and/or components. Dry naturally, or with a hair dryer (not a lot of heat), and you may be okay. Do not power up until it is completely dry. I hope this helps. Good luck and God bless you.
Feb 09, 2015 | Nextbook Tablets & eReaders
Where would the antenna be on my RCA 7 inch tablet?
It is on the back along one of the edges, likely. There does not seem to be any listing that shows the component locations. If you download a Wi-Fi signal sniffer you may be able to twist the tablet around while pointing it at your ripper to determine which angle gets the best signal.
Dec 27, 2014 | Tablets & eReaders
Supersonic 7" Touch screen MID tablet was dropped now touch sensor not working
This may or may not be fixable without replacment parts. The hopeful solution would be to open the tablet and take a look at the ribbon cable for the digitizer to see if it was moved. Check all the cables to make sure they aren't damaged, and are seated properly. You can get parts online such as ebay if you suspect a damaged touch screen. I think these are around $25-$30.
Need tablet repair help?
http://forum.wasatchtechies.com/
Wasatch Techies Smartphone Tablet and Computer Repair in Utah
Feb 11, 2014 | Supersonic 7" Touch Screen MID Tablet
How to put in sim card
Assuming you mean the 2013 version but I'll try both,
so for the 2013 version
  1. Turn your tablet off and place it on a flat surface with the screen facing up.
  2. Tilt the right side slightly up to find the SIM card tray near the bottom right and the small hole in the tray door.
  3. Insert a paperclip into the hole in the tray door, and push firmly but gently, the tray should pop out.
  4. snp_8a30b60eaed5a3a37f46a8c715167552992e_3271601_en_v0Remove the tray and place the micro SIM card inside it, the angle corner fits with the angled indent
  5. Push the tray it gently back into the tablet.
  6. snp_8a30b60eaed5a3a37f46a8c715167552992e_3271604_en_v0
Activate SIM card
  1. Open the Settings app snp_2918920_en_v1 and turn off Wi-Fi after completing the set-up instructions. Once Wi-Fi is off, you'll see a notification at the top of your screen.
  2. Swipe down the notification shade and touch the notification.
  3. Follow the activation instructions provided by your carrier.
For the Nexus 7 (2012) 3G use the same process noting that the tray slot and pinhole is on the left side of the device when its facing up.
*Note* : Only the Nexus 7 (2013) LTE & Nexus 7 (2012) 3G can accept a SIM card. Wi-Fi versions of the tablet can't.
Dec 10, 2013 | ASUS Google Nexus 7 8GB Tablet Unlocked...
My nexus 7 will not turn on
You can try a hard reset. Hold down the power button and the volume buttons at the same time. The device should then power on and you can follow the on-screen prompts.
Hope that helps!
Mar 18, 2013 | ASUS Google Nexus 7 8GB Tablet Unlocked...
I have forgotten my pin code for my supersonic SC-74MID tablet. How do I reset it?
I don't know which OS your tablet uses... perhaps Jelly Bean. If so, if you push the Power button and the "Power Off" option shows up on the screen press the selection of "Power Off" and hold your finger down on it until a pop-up screen shows a selection of: Boot into "Safe Mode". Choose that and what happens is it boots up with no applications loaded. You should then be able to access the "Settings" and then choose "Factory Data Reset" option. Hope this works
Jan 08, 2013 | Supersonic 7" Touch Screen MID Tablet
Pen not detected on especific zones of display
it's a digitizer (hardware part of LCD screen) problem, U can try to buy that part and replace it or just squeeze a little bit LCD screen on the edges around (don't squeeze the screen itself but just black plastic frame around the screen) - it helped my Toshiba for a while :)
May 18, 2009 | Toshiba Portege 3500 Tablet PC
Tablets & eReaders Logo
24 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
