Question about Refrigerators
My norcold frig flashing 5 times not cooling - Refrigerators
SOURCE: Norcold R.V. Frig / freezer not cooling
I have the same problem and I'm not going to pay 500 dollars to get it fixed. That's why i go to these forums.
Posted on Nov 07, 2008
  • 15 Answers
SOURCE: my norcold frig(RV) freezes food in lower level
in your refridgerator there is an internal thermostat on the cooling fan u can move up or down it should be placed on the last finn to the right looking at the fridge
thanks
cruz
cruz's mobile rv repair
Posted on Jun 17, 2009
herodog909
  • 98 Answers
SOURCE: Frig will not cool
I had a similar problem. One thing that I need to know is is it cooling at all? If everything is operating, but no cooling occurs, you may have a bad board. This controls all of the components. Getting it replaced could be pretty pricey. Good luck, and please rate.
Posted on Jun 18, 2009
SOURCE: My Norcold RV refrigator will flash 5 times every
Circuit board may need to be reset.
Posted on Aug 19, 2009
tunde007
  • 2382 Answers
SOURCE: I have a Norcold fridge
Hi, if the light is on, but flashes off 5 times about every 3 seconds. The refrigerator cooling unit has stopped cooling.
1st time - Before you reset
Check: - That the vents are not blocked. - That a door(s) is not open. Close door(s). - That the vehicle is level.
2nd time - After reset This is not owner serviceable. See your dealer or authorized Norcold Service Center.
There is a large reset button that is easy to locate and use, so the Norcold can be reset in just a few minutes, without much hassle.
Take the unit out of its resting spot and turn it around so the back is facing you.
Use a rag (or canned air) and get all the dust out of the back of the unit. Dust can hamper the reset, and can also lead to further problems with the Norcold unit.
Look for the large red "Reset" button, near the top. Pull the tab, and the Norcold will turn off for a few seconds and will then turn back on.
Place the unit back into its resting spot.
Posted on Feb 17, 2011
Won't operate in gas mode. Get code with a "wrench 3."
time to get the service person back under warranty
don't try repairs yourself as that voids the warranty
because you had to replace the regulator so early after purchase , it suggests problem in the gas lines(dirt or filings) that have blocked up the gas jets . problems on the other circuits could be again installation faults
I'm sure that you will make your dissatisfaction known to the company
May 05, 2016 | Thetford Norcold 3-way RV Refrigerator...
5 amp fuse keeps blowing on ac input into cir. brd. on norcold model 6162
shorted heater element unplug and see if it still does it if still shorted board
Jun 17, 2014 | Dometic RM2652 Refrigerator
My Norcold N611 frig code flashes 3 time every few second and doesn't go into A/C mode and will only go into gas mode when the switch is in auto mode and the interior light stays on even when the
The N611 will flash 3 times as an AC heater fault. If your AC heaters are ohming out properly (48 ohms of resistance), then you have a bad power board. If the AC heaters are not showing around 48 ohms of resistance, replace the AC heater. It's going to be one of the two. Here is an article on it:
Norcold Fault Codes AC HE or On light flashing 3 times What to do
Aug 16, 2012 | Refrigerators
Freezer works ok but the fridge doesn't
are you running gas to oper the frig in the rv or electricty if only using the heating element for the frig RV STYLE ONLY maybe starting to make and break causing intermittent cooling or not enough cooling in frig but at all thing concerned try to increase you temp setting higher if you have that option
Aug 19, 2009 | Refrigerators
RV model norcold n811rt not cooling
I have a norcold fridge model #N811RT and the flash code blinks 5 times then stops then repeats. both fridge and freezer are not cold were are currently living in are 5th wheel and it was currently -30c for 3 days any help would be of assistence.
Colin
Aug 03, 2009 | Migali Refrigerators
Frig will not cool
Jun 18, 2009 | Dometic NDR 1292 Refrigerator
My norcold frig(RV) freezes food in lower level
thanks
cruz
Dec 16, 2008 | Thetford Norcold RV Cooler/Freezer
Norcold RV Refridgerator N611
Go to www.bryantrv.com and go to "service documents" and download the manual for your model "Norcold N Series". It says that 5 blinks then a pause means "no cooling detected by controls" see page 21 & 37.
Jul 08, 2008 | Refrigerators
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
