Question about Miscellaneous
Whirlpool Washer/Dryer Combo Water Inlet Valve
How do I get to it
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 106 Answers
Unplug the machine, turn the shut off valves off then disconnect the hot and cold hoses and take off the back panel. It should be labeled on the back panel.
Posted on Feb 03, 2017
My stackable unit quit filling with water. It still spins and drains. I have cleaned the screens out for the water hoses. I have unplugged it for a few. What else can I do to fix my washer?
Use a meter to test the water valve solenoid coils, make sure nobody turned the supply hoses off without you knowing. Did you recently replace the fill hoses or have work done on the machine? Maytag Washer Dryer Combo Water Inlet Valve WP22001274
Jul 29, 2016 | Maytag LSE7806A Top Load Stacked...
I have a combo washer/dryer whirlpool machine, hot water come out instead of cold water does the timer faulty?
Check and see the program that is selected. now check the inline water flow of the cold water and also the hot water.IF there is no cold water in the cycle there is no output to the inlet valve from the controller, check voltage to the valve, if present the valve is faulty. If not the timer is faulty.
Jan 17, 2013 | Whirlpool LTE6234D Top Load Stacked...
Replacing water inlet valve for Whirlpool Duet
Thats a two man job that you are trying to do yourself. The top of the washer has to be removed to replace the valve. Get some help to remove the dryer from the top.
Mar 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water in the drum
The water valve where the hoses connect to the washer is bad.
A new water inlet valve will solve the problem.
Jan 17, 2010 | Whirlpool Washing Machines
LTE6234DO Whirlpool Thin Twin-No hot water
The inlet valve that the hoses attach too the solenoid for the hot side may be stuck closed or clogged with sediment. May need new inlet valve.
Mar 18, 2009 | Whirlpool LTE6234D Top Load Stacked...
How do you easily clean inlet valve?
First check if your faucet has good pressure (clean small screens); if this does not solve your problem simply change your inlet valve.
May 04, 2008 | Whirlpool AWZ410 Front Load Washer/Dryer
Washing machine
Check the filter on the inlet holes, if that is good. Replace the water valve. hop this will help you.
Apr 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer
Check first the filters on the inlet water line (both sides). Then, if problem still exist - check that the inlet water valve works(it is an electromagnet valve, located at the pipe's entrance to the machine)). If it doesn't work, test that it get power. In case it get power and doesn't work - You can easily open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace it for a new one. Good luck !
Jun 26, 2006 | Kenmore 45081 Front Load Washer / Dryer
Miscellaneous Logo
13 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
