How to open the case of the phillips dcm250/37?
ASUS ET27001 hard drive failure. Need to remove the hard drive. HOW TO OPEN THE CASE.
You need tools to open the computer case with Phillips screwdriver with appropriate size. Unscrew the 2 or 3 screw at the back of the case and then slightly slide the cover of the computer case to open. You will see the the hard drive screwed on the inside and unscrew and detach the power cord and data cable.
Sep 21, 2013 | ASUS P4GE-MX Motherboard
How to clean the fan in my laptop
As with any hardware on your laptop, the fan may stop working. Your laptop's fan serves as the dedicated cooling system for the CPU. If your CPU overheats it will cause severe damage to the motherboard. It may also cause electrical damage hardware devices nearby the CPU. Most HP laptops are designed with CPU fan located on the top side of the motherboard. There are a few HP laptops with the CPU fan located on the bottom side of the motherboard.
Shut down your laptop, and fold down the LCD screen. WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Disconnect the AC power cable and any external devices. Place the laptop face down, and rotate the computer so the front opening is facing forward. Locate the battery pack in the upper right or left corner of the laptop. The location depends on your laptop model. Press on the battery's release button, and then lift the battery out of its compartment. Place the laptop face up and open the LCD screen all the way. Insert a flat-head screwdriver into the right side of the keyboard cover. The keyboard cover is a thin strip of plastic situated between the keyboard and LCD. Gently pry the cover from the laptop, and set it aside. Remove the Phillips-head screws located above the top row of keyboard keys. These screws secure the keyboard in place. Grasp the top edge of the keyboard, and then place the keyboard face down over the palm rest area. Disconnect the keyboard's large ribbon cable from the motherboard. Remove the keyboard from the laptop. Locate the small circuit board near the top of the laptop's upper casing above the keyboard compartment. Disconnect the cables from the circuit board. Remove the Phillips-head screws securing the circuit board in place. Close the LCD screen. Place the laptop vertically. Position the laptop with the back of the LCD hinges facing upward. Remove the single Phillips-head screw from the back of each LCD hinge. Place the laptop face up, and open the LCD screen until it is in the 180-degree position. Locate the LCD video cable extending from the left side of the LCD panel. Disconnect the cable from the motherboard. Remove the Phillips-head screws from each LCD hinge. Lift the LCD screen panel off of the laptop. Set it aside. Locate the CD/DVD drive inside the right section of the laptop's upper casing. Remove the Phillips-head screws securing the drive in place. Grasp the face of the drive and slide it out of its compartment. Place the laptop face down. Remove all remaining Phillips-head screws from the bottom casing of the laptop. This includes any screws inside the battery compartment, and on the back panel of the laptop. Flip the laptop over, and remove the remaining Phillips-head screws from the laptop's top casing. Locate the touchpad cable situated just above the touchpad area. Disconnect the cable from the motherboard. Remove the top casing from the laptop's base. Locate the CPU fan in the upper left corner of the motherboard. Remove the Phillips-head screws securing the fan to the motherboard. Disconnect the fan's power cable from its connector on the motherboard. Lift the cooling fan out of the laptop and set it aside. http://www.youtube.com/watch?v=qcy0YSOmX4E How to Clean the Fans on HP DV4 - Overheating This might not be you laptop but it might give you some insight. Hope this helps.
Jan 09, 2013 | Computers & Internet
How do i safely remove the cable that attaches to the motherboard on my toshiba laptop
Toshiba satellite motherboard removal.
A motherboard is usually replaced for one of two reasons. You either replace a motherboard because it has gone bad, or you replace an older motherboard with a new or upgraded motherboard. In either case you will have to completely disassemble your laptop to even gain access to your motherboard. Fortunately, the Toshiba Satellite laptop can be completely disassembled even if you don't have a lot of technical knowledge.
Turn off the laptop, disconnect the power cable, remove the battery pack and disconnect any miscellaneous cables and peripheral devices. WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Attach an antistatic wrist bracelet to prevent shock from static electricity. Static electricity can harm your computer's internal parts. Place the laptop face down, and remove the single Phillips-head screw attached to the hard drive cover. Remove the hard drive cover, then set it aside. Remove the single Phillips-head screw attached to the wireless card/memory cover. Remove the cover and set it aside. Slide the hard drive out of its compartment. This will disconnect the hard drive from the computer. Set the hard drive aside very carefully. Push on the ejector tabs on either side of each RAM module. Slide the RAM modules out of their compartments at a 45-degree angle. Remove them from the laptop and set them carefully aside. Disconnect the antenna cable from the wireless card, and then lift the wireless card out of the laptop. Remove the four retaining screws from the modem card. Lift the modem card slightly out of the laptop, and then disconnect the modem cable from the motherboard. Set the modem card aside. Remove the single Phillips-head screw securing the DVD/optical drive. Slide the DVD drive out of the laptop's frame and set it aside. Remove all marked screws from the bottom casing of the laptop, and then place the laptop face up. Open the laptop as far as it will go. Use a small flathead screwdriver to pry up the keyboard bezel. The keyboard bezel is a small plastic strip sitting between the keyboard and the LCD display. Remove the two Phillips-head screws securing the keyboard in place. Lift up on the keyboard and disconnect the keyboard's ribbon connector from the motherboard. Remove the keyboard from the laptop and set it aside very carefully. Close the laptop. Place the laptop vertically so the LCD display hinges are face up. Remove the two Phillips-head screws from the hinges. Set the laptop down and open the laptop as far as it will go. Remove the four Phillips-head screws securing the LCD display. Lift up on the LCD display, and then disconnect the video cable from the motherboard. Remove the LCD display from the laptop and set it aside carefully. Disconnect the DVD control board cable, the touchpad cables and speaker cables from the motherboard. Disengage the plastic latches on the rear of the laptop casing near the hinges, and then remove the top casing from the laptop's base and set it aside. Remove the two Phillips-head screws securing the CPU fan and heat sink in place. Disconnect the fan cable from the motherboard. Remove the fan and heat sink from the motherboard and set it aside. Remove the single Phillips-head screw securing the motherboard to the bottom laptop casing. Disconnect the USB port connector from the motherboard and remove the jack from its housing. Lift the motherboard from the bottom laptop casing and very carefully set it aside.
Hope this helps.
Dec 13, 2012 | Computers & Internet
How do I open the housing to rplace the drive? Many thanks.
If you don't see any screw holes, look around for some rubber feet, chances are the rubber feet are hiding some screws. If you remove those carefully enough, you can easily put them back in. Once all the the screws are removed carefully pry open the case and remove/replace the hard drive inside.
May 08, 2011 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
How would I open the case? I would like to see if a larger HD can be put inside.
I found this video if it helps you i would be glad
http://www.youtube.com/watch?v=EIBLphaRcHQ
Nov 16, 2010 | Acomdata (HD060U2FE-72) 60 GB Hard Drive
How do i disassemble to access motherboard and DC jack
Me too, need to get inside to clean and remove dust and see why my video is gone after about 10 minutes of operation or so, good chance it is an overheating problem, but I cant get the case open.
May 19, 2010 | E-Machines M5414 Notebook
Navigon 2100 - need to open the case to replace usb port,do not want to brake the case, don't see screw holes - help
To open the case you will need a very small flat screw driver to pop off the back of the case (be very careful as the clips holding it together are very small). You will then have four small phillip screws to remove, so that you can remove the front of the case. To remove the circuit board, there will be two very small phillip screws holding it in place once you've remove the front case.
May 17, 2009 | Navigon 2100 Portable GPS Receiver
How do i disassemble apple ipod housing model a1236
If its the square one then you need to get a plastic ipod case opener (So you don't wreck it) and pry the case open, Then the rest is either a very small phillips screwdriver or a stupidly tiny star driver.
Apr 21, 2009 | Apple iPod nano
How to open the case of rz 32g
phillips if it is like any other case. Look at the screw and compare to you screw drivers.
May 24, 2008 | Sony Computers & Internet
Can't open case--screw holes are too small
Is it a Torx head - sort of 'star' shaped? Though a fine Jewelers x would have done it. There are also machine type screws that have no manual equivalent it seems, - just screwed for life- perchance these cases are of that type.
Jul 14, 2007 | Creative Labs Creative I/O SY-U2F-5PL-SIL...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
