Question about HP Designjet T610 InkJet Printer
How to override the expiration date for ink cartridges in designjet t610?
5 Suggested Answers
SOURCE: 8250 HP INK EXPIRED MESSAGE
I had same problem, and i solved it.
I opened my hp 8250 and removed it`s battery. It is located on left side of the printer, on the main board. You need to remove plastic covers , and then remove 3 screws holding board. You can move board just enough to get damn battery out of there. Now it works perfect!
I can send you some piccs if you need help.
Regards
Sasa
Posted on Nov 02, 2008
  • 16 Answers
SOURCE: mu HP Designjet T610 get mistake 21.13
Service Station error. Switch the power OFF from the back of the Printer and disconnect the power cord. Check the Primer Tubes. Reconnect the power cord and power On the Printer. Make sure that the Service Station path is clear. Remove any visible obstacles (e.g. screws, plastic parts, etc...) restricting the movement of the Service Station. If the System Error continues, replace the Service Station. If the System Error continues, replace the PrintMech PCA
Posted on Aug 18, 2009
SOURCE: HP Designjet T610
NECESITO UNA SOLUCION PARA MI PLOTTER T610 CODIGO DE ERROR 22.1:10
Posted on Nov 14, 2009
  • 48461 Answers
SOURCE: Is removing a cmos battery or its wires the same thing? For overriding ink expiration date?
LOL good luck with that one .
Posted on Mar 08, 2015
How do I reset or replace ink cartridges for hp designjet 2500cp
if you deal with accredited ink supply shops you will not have that problem either on line or in a shop
accredited shops have phone numbers and addresses that you can check up on
Aug 09, 2016 | HP HEWC1806A - C1806A Ink
Expired ink cartridge
You will have to buy a new cartridge Ink cartridges will eventually dry out and that's why HP puts a date on them so they can insure that they will work when you buy them.
It's best not to purchase more cartridges than you need at any one time - that way your cartridges will always be fresh.
Jul 06, 2014 | HP DesignJet 800 Printer
How do I bypass the expired cartridge on a HP DesignJet T610?
The dates are on the package for a reason. The ink dries out or changes viscosity over time and will likely clog the printhead.
My advice is not to stock up on cartridges because of this problem.
If you look online, you can find replacement chips or instructions on how to reset the chip on the cartridge.
Jul 06, 2014 | HP DesignJet Office Equipment & Supplies
HP Designjet 800 - Magenta cartridge
Check the expiration date in the ink menu of the printer
Mar 13, 2013 | HP DesignJet Office Equipment & Supplies
My hp design jet t610 is making a loud sound sometimes when starting. the sound seems to come from behind the ink cartridges. what could it be ? (sorry i am not used to speak english)
What kind of sound? Kind of high pitched? It's probably just the motor checking the printhead assembly. It typically moves around a bit on power up. It's part of the boot up diagnostic check.
Jan 18, 2013 | HP Designjet T610 InkJet Printer
Is it possible to override the expiry date on the ink cartridges for a Z6100 in order to use cartridges purchased with the plotter at the time of original purchase, and have simply not been used?
Well my friend its a little next to impossible but still try this.
1. Set the date to a little before the cartridges should be installed.
2. Insert the cartgs. in the plotter and wait for the plotter to recognize it.
3. Remove and keep it and use when ever you want.
Regards
Saleem
Aug 05, 2011 | HP Designjet Z6100 InkJet Printer
Keeps stating ink expired
i guess your printer has reach the printing warranty.. try to search in the web on how to reset your printer, ^^
Feb 15, 2009 | HP Photosmart 8250 InkJet Printer
HP Designjet T610 InkJet Printer Logo
51 people viewed this question
Ben Johnson
