Question about Epson Office Equipment & Supplies
I have a Epson perfection 2450 and my scans lately are coming out like Warhol screen prints with high contrast and lacking subtle tones as before. No amount of adjustment seems to help.
  • 5 Answers
SOURCE: scanner not scanning
Your 'transportation locks' may have been engaged. (Check lower-left-hand-corner of the inside the scanner cover and the left-back side) See the manual: http://files.support.epson.com/htmldocs/pr48ph/pr48phrf/maint_3.htm
Posted on May 27, 2007
  • 556 Answers
SOURCE: Get into service mode
if it cannot be adjusted then there is a problem in tv. as your green color is absent you will get red+blue=purple your problem is in green video ckt please check 1 sypply to green cathode ckt 2 loose contact in crt base 3 loose signal connector 4 check components related to green cathode& green video tr. itself 5 check for green signal is coming to green video section from processor. 6 signal processor ic if you are not tech person get it done by skilled tech. it is a common problem. it is a not a major problem. please check
Posted on Oct 01, 2007
SOURCE: E173FP 17" LCD Monitor Problem
I have the same problem. It seems like a virus to me, but my anti-virus doesn't find anything. I went to the main menu on the moniter and changed the display time to five seconds and locked the OSD display. Now all the appears is a smaller box showing a lock which goes out in five seconds. It is still annoying, but less intrusive then before. Hopefully, some one will determine a permanent fix for this problem.
Posted on Dec 13, 2007
  • 11 Answers
SOURCE: hitachi 50v500a high definition tv
I had whole redish/pinkish screen on my 50v500 starting a few days ago, then I read through each of the threads on this site for the samilar problems on my model. I found TVtechmaniac's solution (pasted below) solved my problem. Thank you TVtechmaniac!
Enter the I2C Service Menu, be sure the power is OFF.
1. On the front control panel, press and hold the INPUT button.
2. Then press the POWER button for two seconds.
3. You may keep the INPUT button depressed until you see the OSD with the Service Menu displayed.
4. If you don't see the service menu, please repeat Process making sure you wait until the Power blinking LED stops.
5. Execute the Memory Initialize operation after the adjustment values have been written on a sheet of paper. Highlight “MEMORY INTI”, arrow to the right and hold the button to the right (approx 5 sec.) until a check mark appears in the box. This activates the Memory Initialization.
6. After the Memory initialize operation has finished (10~15 sec, the channel will revert to CH 3.) the pink image symptom should be fixed.
7. Write back the adjustment values from your notes to their respective adjustment parameters in the adjustment mode. (In other words, set the Data Values back to the the Data values written down before the Memory Initialization procedure). NOTE: Make sure the SELECT Button is pressed on remote after every change to the values. Failure to do so will result in the data values not being changed.
8. Exit I2C menu. Press exit repeatedly until you go back to the normal picture.
9. Turn the set off-on and Confirm the picture remains in a good condition.
BE SURE TO COPY DOWN DATA SETTINGS BEFORE INITIALIZING I2C SETTINGS
Posted on Aug 31, 2008
SOURCE: Yellow streak through color image scan
I think your flatbed lamp is damage
if u replace or color it pure white ink
Posted on Jun 02, 2009
Epson Perfection 2450 Photo scanner won't run on Win 7 Ultimate.
is windows 7 32 bit version or 64 bit version . Suggest downloading drivers that match the windows 7 operating system and installing them.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=14558&infoType=Downloads
Mar 22, 2015 | Epson Perfection 2450 Photo Flatbed...
Hi, and thanks for your help. sad little noises on start up
Hello b3toed - sorry you're having problems; let's see what can be done.
First, there is a transportation lock on the scanner. (If you have a manual, it will tell you more about this.) Make sure it is unlocked.
Second, test the connection between the scanner and your computer -- make sure it's snug (well connected).
Third, if you were scanning a transparency just before this happened, make sure you've removed the reflective document mat.
After checking these things, turn it off - pause - then turn it back on. Best wishes for good results! -- ambssdor --
Jan 14, 2010 | Epson Perfection 2450 Photo Flatbed...
How open case to Epson Perfection 2450?
go to Epson.com tghey should have the solution if not email me at mike.athome@vodafone.co.nz
Feb 05, 2009 | Apple Epson Perfection 2450 Photo Flatbed...
Slide scanning with Epson Perfection 2450
I don't know if this is truly a "solution" or not, but I get the same thing on my HP 4850 scans. After scanning, I just crop the pictures to remove the black borders. Can you do that?
Dec 08, 2008 | Epson Perfection 2450 Photo Flatbed...
35 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
