Question about Electric Garden
What do I do to save an electric power washer that was dropped into the pool?into pool? (Greenworks 2000psi)
I have an electric greenworks 1700 psi pressure washer that starts then stops repeatedly how do ya fix it
Sounds like the thermal switch is shutting it down. It is either bad or something is causing the motor to run too hot.
Jul 30, 2016 | Greenworks 1700 PSI 1.4 GPM Electric...
Hi, water intake leaking on greenworks 1600 ele. sprayer thanks! its brand new!
Send it back - if you are in the UK the SOG act applies if in the US then Tough
Oct 23, 2015 | Greenworks 1600 PSI 1.3 GPM Electric...
I have a model 51012 washer..I need replacement nozzles. where can I get them? thanks.
Go to their website and check out support. Some outfits will only sell parts thru their "authorized" dealers.
Jul 19, 2015 | Greenworks 1700 PSI 1.4 GPM Electric...
Where can I get replacement parts?
Try Sam's Club. They sell them. If you can't get them there, they ought to at least be able to tell you where you can get them.
Jul 04, 2015 | Gentron 2000PSI Electric Pressure Washer
Wiring diagram for replacement motor
Here is a pdf file maybe this will help.
The power cord has three wires there should be a green =ground black hot white neutral.
http://www.greenworkstools.com/uploads/documents/51012_1700PSI_Pressure_Washer_E_Manual.pdf
May 15, 2015 | Greenworks 1700 PSI 1.4 GPM Electric...
How do you take the hose reel off on a greenworks 1700 psi pressure washer?
There should be a clip that holds it in place, see link.
http://www.ppe-pressure-washer-parts.com/greenworks-51012-pressure-washer-parts
Jan 12, 2014 | Greenworks 1700 PSI 1.4 GPM Electric...
Greenworks 27072 user's manual
Scroll down this page a bit and to the right there will be a link to the .PDF files for the manual.
http://www.homedepot.com/p/Green-Works-10-in-8-Amp-Electric-Cultivator-27012/203240626
Mar 24, 2013 | Greenworks 27012 10-Inch 8 Amp Electric...
Garden Logo
Top Electric Garden Experts
dannydoesita
JohnPaul Robertson
roeb
Are you an Electric Garden Expert? Answer questions, earn points and help others
