Question about Cameras
A battery for an 7505 - Cameras
  • Cameras Master
  • 5,412 Answers
7505 - what ? Please specify make and model of camera.
Posted on Dec 30, 2016
Senator dvd 7505
Hi I gave a senator 7505 dvd radio , it will not play or reject cds or dvd can you help
Apr 03, 2014 | Car Audio & Video
I need a new battery for this razor. I know its replaceable, but where dose it go and how do you get the cover off?
You will find the correct battery type for model 7505 at shaveroutlet.com. See link below.
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
You will need two batteries. Scroll down the item page for videos showing disassembly and installation tips
Jun 21, 2011 | Braun Syncro 7505 Electric Shaver
I HAVE A BAILEY SENATOR CARAVAN TITH A FACTORY FITTED SENATOR DVD-7505 THE CONNECTOR FROM THE UNIT TO THE VAN IS SCREWED UP CAN YOU PROVIDE WIRING CONNECTION DETAILS
I HAVE A SENATOR SERIES 6 CARAVAN FITTED WITH THE 7505 SENATOR DVD BUT WE ARE HAVING PROBLEMS THE SOUND KEEPS FADING ON THE RADIO THEN SUDDENLY COMES ON FULL VOLUME WITHOUT BEING TOUCHED ANY IDEAS WHAT THE PROBLEM MIGHT BE
Mar 30, 2011 | Car Audio & Video
Batteries run down faster (Braun 7505)
You will find batteries at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
To open the shaver body, you will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out. Reassemble in reverse order
Jul 14, 2010 | Braun 7000 Series Foil and Cutterblock
Braun 7505 switch won't slide down to off position. battery has to run down to stop. What can I do?
Guest solution (2008) to Pry out the blue button worked great for me. Not sure what the semi-circular shapes under the button were for but the switch works fine now. The only down side was that prying the button off broke the tab holding it, but this is no big deal. Saved me the cost of a new razor and I like the Braun 7505 model because it works great and is smaller than some of the newer models.
Jul 11, 2010 | Braun Syncro 7505 Electric Shaver
Shaver not charging.
The batteries should not really get warm. You may not have a good solder connection
Assuming that the batteries are in correctly with good solder joints, the problem is likely the motor. With the shaver fully assembled, remove just the foil and cutter and then turn the unit on. Use your finger to push the piece of plastic that the cutter fits into back and forth. If it starts and moves slowly or if it stutters, the brushes in the moto are probably bad. Because the motor is a sealer unit, the motor will need replaced. If you require this part, you will find it at shaveroutlet.com. See link below.
http://shaveroutlet.com/braun-7000-series-syncro-motor-drive-unit-p-110.html
Jan 31, 2010 | Braun Syncro 7505 Electric Shaver
Braun Syncro 7505 Shaver, Need Power Cord.
If you just need a eplacement cord, you can get one at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-charger-cord-for-7000-syncro-8000-activator-360-complete-p-120.html
If you need batteries or PC board, this will raise the price considerably and you may find a less expensive option of buying a replacement. You will also find similar replacement units at shaveroutlet.com
Jan 14, 2010 | Braun Syncro 7505 Electric Shaver
What command will show the maximum bandwidth a
The command is : bandwith ?
will show you the maximum bandwith
Jun 23, 2009 | Cisco 7505 Router
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
