Question about Miscellaneous
Would like a replacement card issued for **********894 name Carolyn eades
Kenwood ka 996 integrated amp. The standby light will dont turn off. I also need to see if someone will tell how everything should be hooked up.
the standby light should be on if the unit is not 'ON' if you want the 894 to turn on when you power up the 996, then you will have to plug the ac for the 894 into the 'switched' ac outlet on the back of the 996
what specific problems do you have with this system
Mar 07, 2013 | Audio Players & Recorders
I Just replaced the toner in my CANON IR1600 PHOTOCOPIER and now have the Error code E100. I put the old one back in to see if it was different but it still said E100. How can I fix this? Thanks
Hi carolyn ,
I am a professional canon service eng . My Name Is D K Kumar . e100 is not related to toner at all . it is the indication that the develper unit has not been detected . remove the left side cover . you will be able to see the top of the develpoer unit. On the left top portion of the developer unit u can see a white coloured accuvator . it is a small white plastic piece ..whhen the side door is closed te white piece should get pressed or should move forward . if the moving action is not happening then the m/c will give u E100 error. in your case the reasons /problem could be :
!) The spring connected to the white plastic accuvator is missing or spring action is not happening.
2) the white accuvator it self is broken or missing.
3) the plastic stick /piece which protudes from the side door and pushes the accuvator is broken.
4)lastly you have not closed the side door properly or not closed at all.
Carolyn if u r able to understand my above tips thn u can do it your self , if not call a your local canon enginer.
best of luck God Bless u
P.S. Carolyn if my solutions have helped u then i request u to kindly reply to me at my enail id: narkumar81@rediffmail.com
Apr 10, 2011 | Canon Office Equipment & Supplies
Hi I have a Canon 500D and the camera, not the sd card, is is on card lock and I do not know how to remove it. I have looked in menu and gone to 'protect Images' and it says "Card write protected'. ...
Hi Carolyn. There could be several reasons for locked card. 1. pin on side of the SD card must be in UP position, not DOWN2. Reformat your card via computer to FAT323. Card reader inside camera has one "little piece" inside for monitoring if the pin on SD card is pulled down or not. If this "little piece" is bent or broken, your camera could mean that SD card is locked. In this case easiest way is to return camera back to shop. Or if you like, disassembly camera, but you will lost your warranty.
Apr 06, 2011 | Canon Photography
I have a Canon Ixus 851s. I deleted all the pictures by accident and wondered if they were retrievable in the depths of the memory anywhere like on a computer??? Please help. carolyn Davenport
Hello
Download THIS.
Download this free tool and run it on you card and it should be able to recover all pictures provided that you have not used the card since formatting. I recommend using a card reader for this.
After downloading and running (no installation required) , simply select deep scan and your memory card and it will start scanning, To recover a found file , right click it and select save.
Please note that the file names will probably not be available and also that some of the properties of the photo like date taken could be lost.
Please let me know when you have recovered your pictures safely or contact me if you need further assistance.
Regards
Andrea
Sep 02, 2010 | Cameras
My Dell monitor, #CN-OM1618-46633-44N-069T, just went black. Can it be fixed? Carolyn
does it have power? if yes try to unhook the video card then insert it again.
if no try to replace the adaptor
Mar 15, 2010 | Computers & Internet
The DVD ead wite no longer apears on my system.
GO TO CONTROL PANEL>SYSTEM >DEVICE MANAGER..ON TOP LOOK FOR ACTION BUTTON..CLICK SCAN FOR HARDWARE CHANGES..THATS IT YOUR DISSAPPEARED HARDWARE WILL APPEAR.GOOD LUCK
Sep 12, 2009 | Dell Computers & Internet
ATI 3D RAGE LP PRO
If you do not see your graphics driver listed on this ATI link;
http://support.ati.com/ics/support/default.asp?deptID=894
You'll have no choice but to download from this other site;
http://www.driverfiles.net/Video-Adapters/ATI/3D-Rage-LT-Pro/download/page,sh,1485,254,5,.html
The card is just too old. There are no updated drivers around.
Either of these two cards listed on this link can replace your old AGP 4x card;
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=879
DF.NET (Above), will charge you a fee to download the drivers you are looking for & there is no promise they will function correctly.
Mike
Jan 12, 2009 | ATI 3D Rage II, (2 MB) Graphic Card
Miscellaneous Logo
14 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
