Question about Mitsubishi Televison & Video
Does 276P595010 Dlp fit a Mitsubishi 65"dlp - Mitsubishi Televison & Video
premtech
  • 934 Answers
SOURCE: mitsubishi wd-62825 dlp
The WD62825 has a Digital Module located on the left side of the chassis looking at it from the rear of the set. It's housed in a metal box that can slide out of its holder after removing the trim screws.
The module has its own power supply board and there are a group of 16v/1000uf caps on that board which commonly fail causing the constant flashing standby light. Further back on the module is a small board about the size of a matchbook called the E2P module. Its SMT (Surface Mount Technology) caps also commonly fail which can cause the same symptoms. Techs can tell whether the E2P has failed by simply removing it, hooking the DM back up and trying to power the set. If it powers on the picture won't be much good - but at least you can tell what's keeping it down...
Back to the caps on the pwr board. If they've failed they usually will buldge visibly on top. And ESR is almost not necessary. In any event that's the nuts and bolts on this model.
Is it a job for a layman? Yes and no - you might strongly consider a tech if you don't feel comfortable removing all the connections that the DM has with the signal board. There are about six - multi-pin - wired connections to unplug and then sliding the DM out of the unit and carefully removing the screws and latching to take the DM top cover off...
Hope this helps.
Bill
Posted on Nov 10, 2007
  • 58 Answers
SOURCE: Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
that means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
Posted on Apr 18, 2009
CaptainHawk1
  • 345 Answers
SOURCE: My mitsubishi 65-inch dlp tv
It's either mirror hinge fatigue or dust on the inside.
Mirror hinge fatigue can be fixed by putting a solid color picture (white or gray works best from what I understand) on the display and letting it sit for 20 minutes.
If it's dust, someone is going to have to go in there and clean it out.
Also could be a defective micromirror device.
Try the first suggestion and if it doesn't work, you're going to need a technician to take a look at it.
Posted on Nov 23, 2010
ladywinn
  • 5138 Answers
SOURCE: We are having white dots
That means you need to replace the Optical Unit Block/Light Engine.Dmd board has been known to cause this also, but most of the companys replace Dmd and optical unit.
PTS rebuilts Light Engines 1-800-844-7871
Encompass Parts Distribution List this Model /Parts 1-800-638-3328
Posted on Jun 27, 2011
Testimonial: "Thank you so much. I will follow up. We love this TV and can't imagine just having to toss it out. I'll let you know how we make out. Gratefully, es"
gopakumarg43
  • 74887 Answers
SOURCE: TV is 73" DLP Mitsubishi.
Hello
There are tow reaons for this fault. The first one is with the colour whell as you mentioned here. The second and most importan one is with its bulb itsef. Colour wheel won't cost too much. Just replace it first and see whether it helps you. If not, bulb may have to be replaced.OL
Posted on Jul 31, 2011
Model WD-65737. How can I fix dlp chip, part 276P595010?
Replace whole board. The BGA is nearly impossible to replace without special jigs and machines. Regards.
Nov 24, 2015 | Mitsubishi WD Televison & Video
Dlp chip replacement
The Mitsubishi part number for the DMD is 276P595010
Aug 14, 2014 | Mitsubishi WD-60735 Projection Television
1910-6003 Does not look like a good part#
The correct part# 276P595010 Dlp 1910-6143W
www.aaatvservice.com
Wd-65734 dlp chip can't find part for can we change it or better off to buy a new tv?
The part# for this DLP chip is: 276P595010 ( DMD-CHIP:IC-1910-6143W)
http://www.shopjimmy.com/mitsubishi-276p595010-dlp-chip-dmd-ic-new-original.htm
$189.99 + shipping you can shop around for better pricing
I DO NOT recommend this to be replaced by a DIY. I highly recommend an experienced technician replace this as you could make matters even worse if you don't know what you are doing.
so consider your labor costs involved & you may want to invest that money in a NEW LED or LCD TV.
Jul 22, 2014 | Mitsubishi Televison & Video
What does light engine cost and how do I replace it?
If you have the white dots issue, you can replace just the DLP chip. I did it, took about 45 minutes after watching a youtube video. Here's the one I bought. Been about a year and no new problems. http://www.shopjimmy.com/mitsubishi-276p595010-dlp-chip-dmd-ic-new-original.htm $189.
Sep 10, 2013 | Toshiba 65HM167 65" Projection Television
Mitsubishi tv 65 dlp chip
If you want to buy it, contact the authorized service center for Mitsubishi.
May 12, 2013 | Mitsubishi WD65737 65" DLP TV
Mitsubishi no power only the amber indicator light is on
Go back and check all your board wiring. sometimes j1 can be reversed with a fan.
Mar 02, 2013 | Mitsubishi 276P595010 DLP Chip 1910-6143W,...
White spots
Replace the DLP chip at cost between $160-$300 for the part and about two hours of your own time to do it.
http://www.shopjimmy.com/samsung-mitsubishi-toshiba-4719-001997-dlp-chip.htm/
Jan 24, 2012 | Mitsubishi WD-65C9 65" DLP HDTV
Televison & Video Logo
19 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
