Question about Measuring Tools & Sensors
Exelvan home weather receiver adjustment to receive outdoor temperature
  • 2712 Answers
SOURCE: outdoor pool temperature
We usually heat ours to around 85?F. In fact, in the summer, we consider our pool cool if it stays below 90?F (where we live a 115?F is normal).
Posted on Aug 27, 2008
  • 3 Answers
SOURCE: 3M Precision Digital Atomic Wall
After replacing the transmitter batteries several times, I tried replacing the clock batteries. They must have been getting low. Once I put in new batteries in the clock it worked fine. Good Luck.
Posted on Jan 15, 2009
SOURCE: Mismatch of stereo receiver outlet to connector wire.
There are adapters available at Radio Shack for connecting almost anything to anything.
Not knowing which connectors you have, I can't tell you what to get, but if you take what you can with you and explain the rest, they should be able to give you the correct adapter.
Posted on May 09, 2009
  • 30 Answers
SOURCE: skyscan atomic clock weather
Make sure the battery contcts are clean of any corrosion.
-AAT
Posted on Feb 22, 2011
walesarumi
  • 6993 Answers
SOURCE: "Protect" flashes on the receiver. Fixable? Weather related?
The receiver will go into protection mode when there is a short in the speaker wires or the amplifier was overloaded. verify that none of the speaker wire connections are loose at the back of the receiver or at each speaker. And verify that none of the wires are making contact with each other.
if it is, then remove the speaker wires and connect them again properly. After disconnection g the speaker wires, unplug the receiver for 10 to 15 minutes. This will make the overload protection back to normal
Try this and let me know. I hope this would solve the issue
Thanks
Posted on Nov 10, 2011
New la crosse technology wind speed weather station model # CA87092 set up.wind speed and outdoor temperature showed until this morning.new batteries used yesterday in setup. what is the problem?
The instructions for your station call for a specific set up procedure. Batteries should be installed in the transmitter first with time allowed for it to initialize and begin sending data. After installing batteries in the receiver, you should see wind speed and temperature displayed. BUT, here in the real world I have a Lacrosse receiver currently displaying a balmy 67 degrees inside and a not-so-balmy - - outside. I believe the alkaline batteries used in the transmitter lose efficiency or freeze at low temperatures. Warmer weather restores the outside temperature display.
Jan 05, 2017 | La Crosse Measuring Tools & Sensors
I put new batteries in Transmitter and never got any temp reading.The unit is less than 2 years old and is not working. Is there anything I can do?
  • Remove all batteries
  • Install new batteries in transmitter
  • Wait for transmitter to initialize and begin transmitting temperature data
  • Install known-good batteries in receiver
  • Observe outdoor temperature reading
If this doesn't work, the transmitter or receiver or both may be defective. I find in very cold weather the transmitter stops sending the temperature.
Dec 08, 2016 | Measuring Tools & Sensors
Model WS9611UN-IT - I am unable to receive the outdoor temperature. I have changed the batteries on the outside remote but I still do not receive the outdoor temperature. How can this be corrected
Remove all batteries, both outdoor and indoor. Install batteries in outdoor unit and wait for it to begin sending a temperature signal. Install batteries in indoor unit. You should see outdoor temperature displayed. If not, batteries, transmitter, or indoor unit may be defective.
Nov 16, 2016 | Measuring Tools & Sensors
Outdoor Temperature Transmitter not working
Sometimes, you have to remove all the batteries in the transmitter and receiver and wait a few minutes before the next step.
Then you replace transmitter batteries first and within 30 seconds, get the batteries installed in the receiver. This allows the receiver to link up with your transmitter. Both units need to be reset this way. You'll see the temperature and any other information the transmitter provides come up in a few minutes. This works with my La Crosse weather station. Using the reset buttons without removing power will not work. My nieghbour has a weather station from another manufacturer and this is also the only way that his will link up.
Oct 03, 2016 | Radio Communications
Changed batteries,now weatherstation does not receive outdoor imformation
La Crosse is very specific about what you should do and how you should do it for a battery replacement.
Begin by removing all batteries, both outdoor and indoor. Install new batteries in the outdoor unit. Allow the time it takes to get from the outside to the inside for the outside unit to initialize and begin sending data. Install batteries in the indoor unit and observe outdoor temperature. You should see indoor temperature as well. Finally, set the time. This last can be tricky as it seems difficult to set an exact time. I have two different La Crosse receivers connected to one transmitter and the one in front of me now is indicating 70 deg F indoors and 80 deg F outdoors.
Sep 11, 2016 | La Crosse Technology The Weather Channel...
What happens if two digital thermometers are set on the same channel
The same as when you have two radio stations on the same channel or frequency. The receiver wants so receive them both, resulting in a scrambled and useless signal in the receiver.
It won't work.
If the system can work with more than one (wireless) thermometer each will have an own channel number. and you will have to switch on the display to read one or the other.
Jan 05, 2015 | Springfield 91455 Wireless Digital Outdoor...
Cannot get the weather station model ws-916ou-it to show outside temperature
I have three of these WS-916OU-IT units. After a few years, the outside sensor just fails. You will get dashes and a "TR" low battery signal, even if the batteries are good
just buy another whole weather station (short money) and set both the old and new weather station unit to receive from the single new outdoor sensor.
To do this - just follow the procedure for a single sensor - that is - put the batteries in the new sensor - then within 30 seconds - put the batteries in all the weather stations - they will all pick up the same outdoor sensor.
I now have three units running off of one outdoor sensor.
Seems a bit silly, but it works.
Feb 27, 2012 | Measuring Tools & Sensors
I have a TX6470 and cannot receive the outside temp on the inside unit
Double check the batteries to make sure they are installed correctly. If one of the batteries in the outdoor sending unit is in backwards, it will not send the outdoor data. On the indoor unit, there is typically one battery that is used for receiving the signal from the outdoor unit. If all of the batteries are in correctly but that one, you will see the display and the indoor temperature information, but the outdoor information will not be displayed. If there are reset buttons, also try them.
Oct 16, 2010 | Timex TX6490 Wireless Thermometer with...
Remote sensor does not work after installing new batteries
Oct 15, 2010 | ATOMIC Digital Wall Clock With Temperature
Measuring Tools & Sensors Logo
64 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
