Question about Philips Audio Players & Recorders
Fixing loose wire on philips headphones - Philips Audio Players & Recorders
2 Suggested Answers
chrisy3000
  • 63 Answers
SOURCE: loose/broken wire
the best way to check if the head speaker is ok, is by opening up the headphone bit and disconnect the wires and make a new connection with a naked end , and test it in a stereo, if that still works the you wont have to buy new headphones you can just disconnect all the wires and buy or make you own connection again. let me know if you help making a new connection. cheers
Posted on Dec 12, 2009
I just got an electro brand mp3 player model #MP2408CP and when i plg headphones or speakers into it, i have to push up on the wire to get sound. How can i fix that?
Your wires in your headphones are probably loose/detached. Best solution is to just buy new headphones. If you don't want to buy new headphones, open your headphones up and solder or tape the wire back the metal/wire.
Mar 03, 2011 | Audio Players & Recorders
My left earphone does not work and I just bought them today
Unfortunately quite a common problem with all headphones this!
It is caused by a faulty wire in the headphone. It can be fixed by resoldering/replacing the wire.
However it is normally cheaper (and easier) to return the headphones to the shop you bought them from. Especially if they are new like yours are.
I would advise you to return the item to the shop as faulty and ask for a replacement.
Regards,
sjstore2
Dec 20, 2010 | Philips SHE2647 Headphones
My dog chewed through the cable of my Philips shp2500 headphones, I have reconnected the all the wires but they still don't work. any help guys?
Feed the dog some good food next time...you might need to solder the wires and make sure the ground is not cross wired to any signal wires.
Dec 08, 2010 | Philips (33-01-031) Headphones
No audio thru the speakers, headphones only
you answered your question. let me explain: the head phone plug is a switch- that disconnects the speaker and only allows sound to the headset. the switch is either broken, loose-wire or dislodged.need to get inside the unit, You could of course get creative. put an adaptor to the headphone jack;the adaptor can now allow you to run wires to the speakers. adaptor is avail from radioshack-same size as on the headset.
Mar 04, 2010 | Philips MCM530 CD Shelf System
Loose/broken wire
Dec 12, 2009 | AKG K-416 P Headphones
Can I take apart the logitech A-00006 headphones easily.
The padding comes of easily, hook your finger under from the inside and push out gently. Once removed reviles 2 philips screws. Once they are removed you have to pry the 2 plastic disks that form the swiveling ear piece apart. Then you have access to the speaker, which is glued down with a still very sticky substance but will come up quite easilly, then remove the screw from directly under the center of the speaker, then you can pop off the swiveling earpiece that is on a kind of ball and socket joint, this took quite a bit of force. This is as far as i'm going as I now have access to the damaged part of the wire! And also the 4 screws mentioned in the original question. Hope this helps.
Dec 08, 2009 | Logitech Bluetooth Wireless Headphones
Philips Headphones SBCHL155
Yes they can be fixed. Hopefully the break is inside and not somewhere in the cord. Remove the foam pad being careful not to tear it. Look for small "phillips head" screws which holds the two halves together. Sometimes the halves snap together. Gentally pry apart. Simply resolder the wires, and put halves back together. You may have to "re-strip" the wires. If you do they are very small gauge wires and delicate. Use a small tip soldering iron.
Jul 19, 2007 | Philips SBCHL150 Consumer Headphones
26 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
