Question about Malber P21 Front Load Washer
How do I change the door seal on a hotpoint wf540
    President:
  • Malber Master
  • 662 Answers
For most front-loaders:
Lubricate the slot which fits over the tub with washing-up fluid. Starting at the top, press the seal so the flange of the tub enters the slot on the seal. Work your way round the using thumbs to force the slot on the tub flange. When slot is on the flange all way round, fit the spring which holds it on. The spring goes into a slot on the outside of the seal. This is quite difficult and you may need another pair of hands. Fit the outside of the seal to the cabinet - this is easy and fit the plastic clamping ring.
Test for leaks before using. Use rinse to test as the water level is higher.
(There is no glue anywhere, only clamps,etc)
Pl rate me nice for the free help!
Posted on Jun 08, 2010
Hotpoint wf540
It's not pumped water out,,,so it won't spin
Jun 22, 2013 | Washing Machines
How do i put a belt on hotpoint aquarius wf540
Afternoon,
I had a similar issue myself and I found the below link quite useful
http://www.buyspares.co.uk/how-to-change-a-washing-machine-drive-belt/advice-centre.pl?article=30
I also brought the belt off the site too and arrived next day - all in all I was a very happy customer, hopefully you will be also.
Feb 23, 2011 | Hotpoint Aquarius WD640 Front Load...
When my hotpoint wma 48 is on a wash cycle water starts seaping through the front door. Gets worse when it goes on to the spin cycle. Please help
Clean the door itself and the door seal. close the door and give the glass bowl a tap at the bottom where it meets the seal with your fist this should do it.If not change the door seal
Jun 11, 2010 | Hotpoint WMA48 Front Load Washer
My hotpoint wf540 on off switch flases and the
sounds like your water pump has failed??
Try cleaning the filter first, normally accessed at the bottom R/H side of unit at the front.
If not, replace water pump (approx £35 for part) good luck!
Jan 04, 2010 | Hotpoint Aquarius WF000 Front Load Washer
My hotpoint wf540 will not start a cycle it very quicly steps to wash light showing but nothing happens door locked light is not illuminated.Just prior to this fault the fuse in the mains plug had blown.I...
1st you need to know if power is getting to machine, Next could be door interlock switch faulty the fact the fuse blew indicates possible short circuit/ excess current draw occured also check motor brushes assuming machine fills with water 1st
Nov 05, 2009 | Washing Machines
Hotpoint wf540 stopping on a rinse and spin and
check pump/filter/outlet hose for blockages. if ok, check pressure switch (disc shaped item at top of machine with 4? wires and a tube) by blowing into it gently - should hear clicks, then blow into tube to pressure chamber - should be clear.
Oct 26, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Door seal has two holes in it and leaking
Hi.
You need to remove the front console panel and then the front panel to change the door seal.
Pull the dispenser drawer out and remove the screws.
Slide the console panel to the right and support it while you remove the rfont panel.
Change the seal, and reassemble in reverse order.
Good luck.
Nov 20, 2008 | Hotpoint Ultima WF860 Front Load Washer
SMELLY WASHING MACHINE
A mouldy smell is often a sign of trapped residual water stagnating somewhere in the machine often just inside the door seal at the low point or in the filter.
Providing there is nothing like a old sock trapped in the pump or filter then there is not much you can do other than to dry the door seal and powder dispenser after use.
Please remember to rate this solution.
Oct 22, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wma46 door lock
make sure door seal is fitted correctly to the cabinet. you may find that all that is required is to push the door harder than usual till the seal beds in
Mar 29, 2008 | Hotpoint WMA46 Front Load Washer
Malber P21 Front Load Washer Logo
231 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Dan Webster
Dan Webster
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
