Question about Humidifiers
My built in furnace humidifier sounds like crickets, can i oil it, and how?
Furnace tries to come on then .... hold -AC.
When the thermostat says AC it means there is no power to the thermostat.
Apr 16, 2009 | Honeywell Power Humidifier: Furnace...
My oil furnace is locking out what do i do
You need to change out the burner orifice, change the filter and make sure there is pkenty of oil. Bleed lines at brake like valve until there are no bubbles present.
Mar 02, 2009 | Honeywell Power Humidifier: Furnace...
The fan or blowwer on my furnace is to loud. how do i fix this?
Hi!!! your fan blower has a capacitor right next to it change that first and test it.If sound is still there then your fan blower windings are getting bad..Good luck..but first change run capacitor .
Jan 05, 2009 | Honeywell Power Humidifier: Furnace...
Fan shuts off too soon after oil burner stops
That is an old style t-stat i would replace it with a more up to date model. Your problem may be in the limit switch. But yes to answer your question most fans can be adjusted just depends on if it has a manual limit that looks like a silver box on the interior of your furnace or if it has a mother board control system.
Jan 04, 2009 | Honeywell Power Humidifier: Furnace...
Cleaning a furnace humidifier steel filter?
Most water panels are generally replaced once a year on flow through humidifiers.
Dec 20, 2008 | Honeywell Power Humidifier: Furnace...
Furnace pilot is not igniting.
the first blower you hear is the inducer motor it pushes the exhaust out. sounds like abad gas you have a standing piloit light or is it eletronic ignition. if electronic and there is no glow you have a bad ignitor
Oct 04, 2008 | Honeywell Power Humidifier: Furnace...
Wiring problem
Sounds like you may have put 120v through a 24v solenoid and humidistat.
Is the HUM terminal on the furnace 120v or 24v?
If it is a 120v terminal you will need a 120x24v transformer and a new solenoid and maybe a new humidistat.
Dec 19, 2007 | Honeywell HE360A1027 Whole House...
I would guess from the info provided that you only have two wires going to your thermostat which would explain why the fan switch doesn't work on the thermostat. You can bypass the thermostat as a first step in troubleshooting. After that it depends on the type of furnace, standing pilot or electronic ignition...
Nov 29, 2007 | Honeywell Power Humidifier: Furnace...
Humidifiers Logo
46 people viewed this question
Top Humidifiers Experts
Paul Carew
Are you a Humidifier Expert? Answer questions, earn points and help others
