Question about Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television
Does the ws55315 have a dlp chip in it and do you know the number
Dlp chip replacement
The Mitsubishi part number for the DMD is 276P595010
Aug 14, 2014 | Mitsubishi WD-60735 Projection Television
1910-6003 Does not look like a good part#
The correct part# 276P595010 Dlp 1910-6143W
www.aaatvservice.com
Samsung hl s586wx projection tv has white dots all over screen what do i need to replace to fix this
the DLP chip needs replaced.
the part# is: I believe your model number may be incomplete,see the following website (I think they have instructions included):
http://www.shopjimmy.com/dlp-chips?tv_brands_select=Samsung
Jul 05, 2014 | Samsung Televison & Video
Little pinholes appearing on the screen that seem to be letting light through
Little white specks? Is this a DLP set? (I'm betting it is...) If so, those are "dead" pixels on the DLP chip, which is not something you're going to be able to fix yourself, and typically very expensive. If it's not a DLP set (for instance DLP sets have replaceable bulbs), then let me know (Model number?) and please give a more detailed description of the problem...
May 31, 2011 | Mitsubishi Televison & Video
I have a samsung HLS4266WX/XAA about 3 years old with white dots.
This is a known issue with Samsung DLP sets. Here's a link to the solution:
http://forums.cnet.com/5208-13973_102-0.html?messageID=3162774&tag=emfrnd#3162774
Jan 01, 2010 | Samsung DLP HL-P5663W 56" TV
Had one last week and now there are 6. they are
You get white spots inside the samsung DLP tv due to bad Digital Micromiror Device , or bad DMD board .
What is actually the problem is the DMV chip connected to this board . Inside this chip are 3 million tiny mirrors ,and when they physically get stuck , they either show black or white instead of a color
This is well know problem with SAMSUNG DLP...
The DMD chip is failing.If not under warranty expect to pay a few hundred to several hundred to get it fixed
The mirrors on the DLP chip are slowly sticking either fully open (white) or fully closed (black). The part that contains the DLP chip is the Light Engine. It is the most expensive part of the TV.Only the Samsung TVs has this issue.
Replacing the DLP chip and the micro mirror would solve this issue...
Pleaserate this solution,
Rnj VINODKUMAR
Nov 11, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
White dots on my samsung dlp tv
Samsung DLP Projection Tv white dots may caused by DLP Chip. Change a new DMD Chip 19106143W. The post show you how to replace it step by step.
Your chip should look like this:
Jul 11, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television Logo
22 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
